dbaker wrote:20mm front axles
12mm rear axles
wheels built to take major punishment.
shocks have more travel
GCinDC wrote:
chroot wrote:Someone had their hub motor holes and drove in rain day without any problem except you need keep the controller dry as possible as you can.
fizzit wrote:The down tube actually looks good to clamp on a mid-drive, the stuff on the rear swingarm is no worries if you're doing that cuz then you just use the standard chain.
I don't think the landing that guy did on the rear wheel would have worked with a standard QR rear axle. Serious downhill bikes have 20mm front axles and 12mm rear axles with wheels built to take major punishment.
GCinDC wrote:yeah, i'm with you on all these things:dbaker wrote:20mm front axles
12mm rear axles
i'm not getting another XC bike, that's for sure!
i came really close to buying one of these off ebay last weekend, but then realized a single pivot swingarm would be fine for ebike...
i doubted whether the hubbie would even fit w/ that brake stabilizer bar, and way too complicated in there for an non-hub... hell of a brute tho!
kfong wrote:Greg, was that you that tried to snipe my bike![]()
full-throttle wrote:I'd look into a 2kW, 40kph top speed, 500Wh Cyclone DH conversion for jumps and technical trails. As light as possible.
GCinDC wrote:clay, thanks for the patient counsel.
Hmm.. Cyclone numbers seem confusing too..GCinDC wrote:hey FT, your numbers confuse me, esp when i look here. 2kW/40kph? i'm seeing 1200W 70kmh... is this what folks typically buy?
GCinDC wrote:
gwhy!, i've been following your trials build ebike->motorcycle. i never found out what motor/controller kit it is. i've been looking at a lot of trials bikes lately, as they seem like such a nice blend. what's your top speed with that?
Users browsing this forum: No registered users and 8 guests
