electr0n wrote:How difficult was it to open up the motor?
electr0n wrote:How difficult was it to open up the motor? Did you open the wire side or the other? Any tips? I had some trouble getting my covers off my 400 series crystalyte. I had to use a thin bladed knife to cut the paint around the perimeter before I could get the cover off and it took forever.
I just picked up an HS3540 laced in a 26" wheel and I suppose I should open it and treat it with some stuff to avoid that rust and eventually install a temp sensor alarm. You were only running 74v 40 amps when you had your meltdown and I was planning on running 88.8v and 50 amps... hope I don't kill it. Hope you get your motor back up soon. Your thread is a great resource.
GCinDC wrote:thanks, snow. do you still first need to pry the lid up or no? got a link/pic of the puller?
sn0wchyld wrote:GCinDC wrote:thanks, snow. do you still first need to pry the lid up or no? got a link/pic of the puller?
heres the one I bought on special http://www.supercheapauto.com.au/online-store/products/Stanley-Gear-Puller-3-Jaw-150mm.aspx?pid=12541#Description
Sacman wrote:sn0wchyld wrote:GCinDC wrote:thanks, snow. do you still first need to pry the lid up or no? got a link/pic of the puller?
Yikes! $50 for one gear puller?![]()
Harbor Freight has a set of 3 them (different sizes 3", 4", 6") right now for just $16
http://www.harborfreight.com/3-piece-th ... 32184.html
adrian_sm wrote:I just take out the screws on the side cover, put the wheel on the ground, then stand on the rim.
The axle then pushes on the ground, pushing the stator up out of the rotor/wheel. Then just lift the stator with top side cover out before the magnets pull it back in to place.
adrian_sm wrote:It is doing just what the gear puller does, but in a slightly less controlled manner, and putting the stress on the stator via all the spokes, rather than three spots the puller hangs on to....
The bigger trick is reassembling it in a controlled manner. Never quite got the hang of that. But you can sort of do the reverse....
Just makes sure you hands are well away from the gap between stator and rotor, you really don't want you fingers pinched.
Sacman wrote:So the SAFEST reassembly technique I found is to put the center axle on the ground, grab the wheel with your hands on the outer rim (away from the center), then lower it slowly onto the axle. This keeps your hands away from the dangerous action at the center.
dbaker wrote:Looks like it tests OK and runs. Rim trued?
GCinDC wrote:
i'd like to be able to run as low a tire pressure as possible and still not get pinch flat for going over curbs...
Sacman wrote:You running lower pressure tires to avoid pinch flats?
It doesn't have to be messy, but you got to have a track pump or a compressor and to take your time. There are a few good videos.GCinDC wrote:stans sounds interesting. and messy?
Users browsing this forum: Brute and 3 guests
