GCinDC wrote:New controller issues...
I've just swapped my 846 infineon controller with a 116, bought directly from Keywin/ecrazyman, in an attempt to get higher regen. (for braking, not nec for charging...)
So first, I've performed the following mods on the 116 out of the box from Keywin:
-> jumped BK/GND (acutally put them on a switch)
-> removed R12 and soldered in 1K ohm resistor
-> soldered programming header to board (and programmed board with these
settings)
-> added power switch, or attempted to.... The power lead connector had three wires: two thick +/GND wires and a thin red + wire attached to Vcc-1.
I assumed the thin + wire was for a switch so I wired it like my 846 controller is wired: with a switch on the thin + wire from Vcc before it enters the + powerpole terminal. (as in the diagram below). Not sure what mate there should have been for this on the battery side...
So, the issues:
__ 1. When I turn on the switch (which I ran to the handlebar), the CA Voltage reads a steady 82V for 15-45 seconds, and THEN it shoots up to 93V and oscillates there, within a volt or two. Somewhat disconcerting, having lipos & all... but obviously there's no change in battery voltage. This is w/ bike at standstill, no throttle at all. I've tried timing it, but timing isn't consistent. Seems to occur sooner after depressing eBrake...
- Fullscreen capture 1242010 124202 PM.jpg (90.61 KiB) Viewed 1362 times
__ 2. The eBrake lever, when depressed, causes the CA to display only backlighting, no more characters, and have no effect on braking. The eBrake line, (YEL/BLK from controller) isn't wired to EBS, as on 846 controller. Here are some shots from top (L) and bottom (R). Is this correct??
- Fullscreen capture 1242010 12749 PM.jpg (99.8 KiB) Viewed 1363 times
Any suggestions!?
My build thread
here. Issues mentioned in last post, p. 5.
Thanks
