Lenk42602 wrote:gwhy -
thanks for the pic!
Did you come up with enough chain clearance considering your swingarm travel? I bagged this idea cause i couldn't get enough with travel and swing arm dimensions..
Lenk42602 wrote:Ahh. I was assuming an isolated pedal only drivetrain.....I meant chain "slap" based on vertical swing arm travel using a traditional pedal only drivetrain.
Hub motor/swingarm/chassis is my main concern, really just trying to get the pedal - only drive train to work fairly well around it.....
Len
gwhy! wrote:.....if you dont mind waiting to make a decision when I get the bearings fitted into the pivot point I will put a chain ring on and see if it would be a problem or not.....
Lenk42602 wrote:gwhy - PICS!
what about crank arm clearance? from the photo, it doesn't appear as though your swing arm is narrow enough for the crank set to clear it?
Len
gwhy! wrote:Lenk42602 wrote:gwhy - PICS!
Len
I will try and get some pics for you later today. crankarm clearance is ok.
John in CR wrote:
Great .... so your bandsaw was a great purchase.
Users browsing this forum: CORKY, dh-paule, richmpdx and 9 guests
