Hyena wrote:Yeah that could be a point - bloody stealth and their obscure axle spacing!
What sort of gauge/thread size (not sure what the correct terminology is here) are you using ? I tried some nyloc nuts from bunnings and they wouldn't thread on the axle. I guess I need to go to a specialty fastener place
Kepler wrote: The Chain on a Fighter or Bomber is too wide and will bind on the adjacent gears. Alternate is to strip down the cluster and just leave the lock gear on the cluster.
Hyena wrote:I'm sure it's the regen, after tighening mine up I didnt feel the usual slight clunk I feel when engaging regen but a few minutes later it was back. I didnt check the nuts again when I got home but I'll bet they're loose again. Because I'm running a non-standard motor I have a nut on both the inside and the outside of the drop out - one tightening out, one tightening in. I'm not sure if that's better or worse...
None of these occur on stock Fighters BTWHyena wrote:Yep, I tried this the other day and found out it was too wide. So I have the stripped down larger cluster as you suggested. I found with a single speed on right to the motor that the chain kept clipping the edge of the tyre and hitting the swing arm. Of course with the smaller gear on the stripped down cluster now the chain is too long as above. It's only 2 teeth different though so for now I'm getting around it by having the axle sit right at the back of the drop out. With it sitting futher forward the slack in the chain made it skip off every few minutes.
full-throttle wrote:Hyena wrote:I'm sure it's the regen, after tighening mine up I didnt feel the usual slight clunk I feel when engaging regen but a few minutes later it was back. I didnt check the nuts again when I got home but I'll bet they're loose again. Because I'm running a non-standard motor I have a nut on both the inside and the outside of the drop out - one tightening out, one tightening in. I'm not sure if that's better or worse...None of these occur on stock Fighters BTWHyena wrote:Yep, I tried this the other day and found out it was too wide. So I have the stripped down larger cluster as you suggested. I found with a single speed on right to the motor that the chain kept clipping the edge of the tyre and hitting the swing arm. Of course with the smaller gear on the stripped down cluster now the chain is too long as above. It's only 2 teeth different though so for now I'm getting around it by having the axle sit right at the back of the drop out. With it sitting futher forward the slack in the chain made it skip off every few minutes.
It's like DIY car mods - if you don't have the skills (or tools) don't do it.
full-throttle wrote:None of these occur on stock Fighters BTW
Rix wrote:Lowbank,
I didnt' catch it at first, but on your drive side axel block picture you posted, there is only one nut (10mm?) on the axel block post. Even though you are just about out of adjustment, the chain may be loosening because there isn't a jam nut behind the adjuster nut on the axel block post. Due the pushing power of the hub motor combined with pedal power, the nut maybe slowly rotating counter clockwise which is why the chain could be getting loose on you. It might help if you put another nut on the axel post. Adjust your chain tension, then using a wrench to hold the front nut in place, put another nut on it and tighten up.
Rix
kiqnkf wrote:It's a slender, fine looking bike, may I suggest the "Stealth Bolt" as in "Crossbow Bolt"??? Probably look ok with the lightning bolt shaped "S" they use too...
That seat pole looks about 50cm too short for you Kepler....
So, anyway, Cruising down the road in the Prius, HV battery warning comes on. Off to the factory, pull the battery out - start the reconditioning process...
Using the Commodore, short of it, 3rd gear starts to slip.... Off to my trans guy.
Monaro still sitting in the factory, haven't quite finished the window reg thing... maybe in a couple of weeks.
No more cars to drive, so go to rent a bomb, hire a junker.
Get home, my kids decided we should go for a ride to the skate park, and tear it up.
Get the Bomber out of the house, start pedalling, click.....click...click..click.clickclick.clickclick.... Crap. V-boxx buggered.... Thought I could rely on the bike at least!!! NO!!! Wont be attending the ride this weekend.... Worst part about it.
Not my week.....
Does anyone have a golden egg-laying goose I can rent for a week or so?
Hyena wrote:Cool pic Mr Lowbank, only to be trumped shortly after by Kepler!
Nice work mate, 8ah is quite a small capacity. Have you enlarged the opening that the side covers usually go over ? Looks like it, but maybe I just haven't had a close look at them before with both covers off. Would I be correct in assuming with that small battery capacity and big internal space you'll be mounting a clear window in the side covers to try and maintain a hollow triangle ? That's what I'd do! and it's what I'm trying to achieve with the custom frame I'm planning - still good performance but more literally more stealth. Since riding my fighter in public alot lately I've never had so many people say "is that electric?!"
John should provide a jacket with the bike that has "YES, IT'S ELECTRIC" written across the back
Kepler wrote:True, small battery capacity. Plan is to install the batteries in the upper half of the battery cavity to optimize front to back weight distribution. The frame opening is stock Fighter and will be fully covered to stay true to the Fighter's standard look. It will look slimmer though without the controller mounted underneath. I will also use a 5ah Aux pack in a seat bag for extended range when required.
I may use the lower section of the battery cavity for a permanent mounted 240V charger but haven't made a solid decision on this yet.
voicecoils wrote:Kepler wrote:True, small battery capacity. Plan is to install the batteries in the upper half of the battery cavity to optimize front to back weight distribution. The frame opening is stock Fighter and will be fully covered to stay true to the Fighter's standard look. It will look slimmer though without the controller mounted underneath. I will also use a 5ah Aux pack in a seat bag for extended range when required.
Super nice new project, now I know of at least 3 people who own a Bomber AND Fighter. Lucky owners!
If you could run a fan-cooled controller and charger both internally, that would be sweet.
[edit: reread your post, you already planned to mount the controller internally, nice.]
Have you had a look at the zippy compact range? You could do 18S, 11.6Ah with just 4 of these packs:
http://www.hobbyking.com/hobbyking/store/__21386__ZIPPY_Compact_5800mAh_9S_25C_Lipo_Pack.html
4.5 kg for 772 Wh
Users browsing this forum: deffx and 10 guests
