Custom 140XL X5404 CruiseMeister
Postby thewmatusmoloki » Wed Aug 17, 2011 7:26 pm
Greetings all,
A friend recently asked if I could help him put together an ebike, he had no idea where to source any parts or how to wire it up
but he's a professional sheetmetal worker and a great welder so I knew the battery box would be no problem and I am always keen to help
people get the e-grin.
It's a 2011 Merida 140 with an XL frame, pretty high quality bike, handled better than anything I'd ridden before without e-assist.
merida 1.jpg (114.77 KiB) Viewed 1721 times
merida 2.jpg (109.2 KiB) Viewed 1721 times
merida 3.jpg (81.89 KiB) Viewed 1721 times
The motor is an early release sensorless HS35 with all the axel wire problems
that these came with.
Forewarned by this forum was forearmed in this case.
Took the cover off and noticed that the wire casing was touching the rotating part of the hub (what a surprise, NOT)
Bit of dremeling on the axel channel and expoxied the wires down, chucked in some hall sensors and Bob's yer uncle !
axel (Custom).jpg (39 KiB) Viewed 1721 times
axel 2.jpg (49.36 KiB) Viewed 1721 times
axel 3.jpg (89.04 KiB) Viewed 1721 times
Last edited by thewmatusmoloki on Mon Sep 24, 2012 8:30 am, edited 2 times in total.
There is no spoon.
thewmatusmoloki
Re: Merida 140XL HS35 FrockMeister
Postby thewmatusmoloki » Wed Aug 17, 2011 7:38 pm
Powered by 12 x 6s 8a/h zippy li-poly batts in 18s4p configuration giving 75 volts and 32 A/H hot off the charger.
powerrrrrr !.jpg (78.5 KiB) Viewed 1721 times
Not sure who came up with the forward pannier battery box idea on this forum but THANKS ! :lol: (the first one I saw was dogmans, brilliant)
It's made of 1.2mm stainless steel and the batts fit snugly.
mock up 1.jpg (67.33 KiB) Viewed 1721 times
mock up 2.jpg (67.63 KiB) Viewed 1721 times
Last edited by thewmatusmoloki on Wed Sep 21, 2011 5:47 pm, edited 1 time in total.
There is no spoon.
thewmatusmoloki
Re: Merida 140XL HS35 Frockmeister
Postby thewmatusmoloki » Wed Aug 17, 2011 7:50 pm
The headlights are $30 halogen car spotties modded with cheap mr16 led globes from ebay,
lights (Custom).jpg (44.15 KiB) Viewed 1721 times
DC converter is just a $5 switching transformer (100 to 260 volts in 12.6 volts out) off ebay with the wires just soldered to the ac pins.
dc converter.jpg (31.37 KiB) Viewed 1721 times
My mate Brett fabbed up some brackets out of stainless for the lights. (his work is remarkable)
headlight bracket.jpg (26.25 KiB) Viewed 1721 times
$14 LED tailight.jpg (40.14 KiB) Viewed 1721 times
The lot of them were then powder coated.
powder coated SS parts.jpg (38.63 KiB) Viewed 1721 times
Last edited by thewmatusmoloki on Wed Sep 21, 2011 5:55 pm, edited 1 time in total.
There is no spoon.
thewmatusmoloki
Postby AussieJester » Wed Aug 17, 2011 7:59 pm
LOL@thread title, its a fine build mate good job ;-) The saddle bag type battery enclosure ous great idea, I believe Luke was one of the first to adopt this approach many have followed suit.
Hope the frock is ok been a few of that model burn up recently.
KiM
AussieJester
Postby thewmatusmoloki » Wed Aug 17, 2011 8:02 pm
Didn't really want to risk a major heat build up in the motor so it was air conditioning time for those covers
air cooling.jpg (72.01 KiB) Viewed 1721 times
The controller is an 18 fet 4110 from Lyen and fit perfectly under the battbox
The side with the fets is facing downwards for max airflow and some air gets in from the box front Ignition and light control box is also s/steel
converter shell.jpg (28.35 KiB) Viewed 1721 times
lights + ignition.jpg (32.08 KiB) Viewed 1721 times
charge socket.jpg (48.83 KiB) Viewed 1721 times
Last edited by thewmatusmoloki on Wed Sep 21, 2011 6:01 pm, edited 1 time in total.
There is no spoon.
thewmatusmoloki
Postby thewmatusmoloki » Wed Aug 17, 2011 8:10 pm
Thanks AJ, it's actually been running for about a month now and used as a high speed commuter 6 days a week for work. Everything seems to be within tolerances and staying cool (ish). My mate couldn't be happier. :D
Matt
There is no spoon.
thewmatusmoloki
Postby thewmatusmoloki » Wed Aug 17, 2011 8:26 pm
This is my 9th ebike assembly from over the years. I've never had an axel spinout yet and don't intend to start now.
These torque arms cost $180 to get made at mates rates. I think they are bullet proof !
16mm laser cut stainless steel clamping arms Scalloped to the rear dropout shape
Then of course, powder coated
Last edited by thewmatusmoloki on Wed Sep 21, 2011 6:05 pm, edited 2 times in total.
There is no spoon.
thewmatusmoloki
Postby thewmatusmoloki » Wed Aug 17, 2011 8:42 pm
Can't really say enough about how important fender's are.
Unless you live in a desert like some of the members here you're gonna get caught in the rain at some stage.
It's happened to me countless times, once, I just went around the corner to grab a beer and got caught in some kinda cloudburst :( I don't mind the falling rain but the stuff that comes up from the road is pretty horrible in the eye's and on the teeth.
Had to mod these lightweight plastic guards and it wasn't easy, but worth it I reckon.
Last edited by thewmatusmoloki on Wed Sep 21, 2011 6:15 pm, edited 1 time in total.
There is no spoon.
thewmatusmoloki
Postby thewmatusmoloki » Wed Aug 17, 2011 8:51 pm
And finally a couple of shots of the finished bike.
Just need to add some black platform pedals now. These tiny silver things are pretty bad.
Acceleration is very nice (for a hub motor), top speed is 75kph, economy cruising at about 60.
Feels superb to ride, something very nice about the way it corners.
my pedly.jpg (61.59 KiB) Viewed 1721 times
Last edited by thewmatusmoloki on Wed Sep 21, 2011 6:18 pm, edited 2 times in total.
There is no spoon.
thewmatusmoloki
Postby Whiplash » Wed Aug 17, 2011 11:41 pm
Wow! 35ah? How far can you go on that??!! My bike would do an EASY 100 miles on that battery!
Power is a fascinating thing, the more you have, the more you want, but the real power is having the restraint not to use it all at once...............Um...Yeah..
The harder you work.....The luckier you get!!
"People who say it can't be done are often interrupted by those that have already figured out how to do it!"
Email me @ currentcycles@gmail.com
OR check out http://www.CurrentCycles.net
Whiplash
Postby thewmatusmoloki » Thu Aug 18, 2011 12:19 am
Cheers Whiplash, It's only 32 a/h tho.
Don't really know the range yet the furthest it's travelled so far is 40 km and used about half the capacity
going into a light headwind at about 60kph.
I think this controller lets out a few amps.
There is no spoon.
thewmatusmoloki
Postby Whiplash » Thu Aug 18, 2011 12:26 am
That's a good speed though and mine is a pretty efficient RC setup, so the big C-Lites have a hard time keeping up efficiency wise. But you got a real nice build there!
Whiplash
Postby Bluefang » Thu Aug 18, 2011 12:48 am
Ohhh very nice, but i am sure you could try and spin those drop out clamps, but i think the bolt holes on the frame would spin out first.
viewtopic.php?f=10&t=49912 Current build, Electric flat tracker
Bluefang
Postby thewmatusmoloki » Thu Aug 18, 2011 1:10 am
Thanks Bluefang, this frock's axel ain't goin nowhere. The frame is hydroformed 6061 aluminium, I'm told it's pretty solid stuff.
Here's how it gets charged mostly. It's a 75v 11amp custom charger from an ebay vendor that I've
been getting charger's from for a while now.
75v 11amp.jpg (73.7 KiB) Viewed 1721 times
It's quite large, but still fits in the backpack Balancing is done with an eco6 200watt li-poly balance charger as needed, however it hasn't needed it yet as all the cells seem to be staying at between 4.16 and 4.18v like they are locked there or something! :D
There is no spoon.
thewmatusmoloki
Postby thewmatusmoloki » Wed Sep 21, 2011 6:37 pm
I re-up'd the photo's with some improvements.
The bike is still performing well and has recently passed 2500 km's use.
Thanks for looking. :)
There is no spoon.
thewmatusmoloki
Postby neptronix » Wed Sep 21, 2011 7:24 pm
Those are amazing torque plates. Nice mounting solution for that crapload of batteries too.
What a road eater!
ES facebook group: http://facebook.com/#!/home.php?sk=group_125035107565566&ap=1
The all-arounder: 8T MAC motor on a Trek 4500.
The girlfriend bike: 350W front MAC on a 700c Trek.
The Bus: ??? on a 'da bomb' cargo bike frame
Pro-tips for noobs: Avoid BMS Battery like the plague | Charge RC Lipos to 4.15v, stop discharging at 3.5-3.6v | Use torque plates/arms! | Rear mounted hubs are always best
neptronix
Postby thewmatusmoloki » Tue Dec 20, 2011 1:15 am
Thanks Nep, sure is or was !
Hasn't gone entirely well though, these pics are from yesterday.
The guy I built this bike for was involved in a pretty nasty accident on a bridge not far from here, 3 days ago.
He doesen't remember how it happened because of concussion, or for that matter no memory of whether he was coming or going.
Had a full face helmet on so his head is OK now.
Lost 2 fingers on the left hand which have been sewn back on, still touch and go whether they stay on. Not sure how thats going to affect his career as a first class sheet metal worker.
Broke left arm above the elbow. Bruises and cuts all over.
Nasty scar over left eye, vision not affected.
We suspect some drunk driver plowed into him from behind. They took off. No witnesses apparently.
Some pics of what left of the frockmiester ...
Mr. Damage.JPG (163.12 KiB) Viewed 926 times
nasty accident.JPG (172.71 KiB) Viewed 926 times
pedal crank.JPG (139.38 KiB) Viewed 926 times
He's currently in hospital and will be there for christmas at least.
Take it easy out there chaps.
Last edited by thewmatusmoloki on Tue Dec 20, 2011 1:45 am, edited 1 time in total.
There is no spoon.
thewmatusmoloki
Looks like he was hit from behind and was pushed into the bridge railing.
From the looks of the bike it had absorbed a lot of the shock but not enough unfortunately.
Picked up the bike from the police yesterday, Lipo's are all ok despite being left on for 2 days in the holding compound.
Some rear spokes are broken but the major damage is at the front.
There is no spoon.
thewmatusmoloki
Postby binlagin » Tue Dec 20, 2011 1:28 pm
Wow.. how terrible... best wishes to the rider. I've gotten rear ended and sent 30feet on my motorcycle.. it's a scary experience.
That's my biggest fear when riding on the street... having an accident that would prevent me from doing my every day work.
How did the battery case hold up?
Get well soon!
Greyborg Motor, 18-FET Lyen Controller
Turnigy 20C @ 30S x 2P
Giant Team DH Bike, Kiwi Dropout adapters
100km/h+
binlagin
Postby Justtoby » Tue Dec 20, 2011 3:31 pm
Get well soon to the rider....a lesson to all to wear a good helmet!
Justtoby
Postby ohzee » Tue Dec 20, 2011 6:13 pm
Damn that is just terrible at least he is still alive. Agreed on the helmet I need to get a full face one myself.
Crazy that he doesn't know what happened and no witnesses.. Hopefully his memory comes back to him.
keep us updated how he's doing please such a sharp bike also.
ohzee
Postby thewmatusmoloki » Tue Dec 20, 2011 6:14 pm
Thanks for the well wishes guys ...
The battery box & batteries remain undamaged, just a couple of scratches in the powder coating !
Stainless steel would have to be one of mankinds greatest inventions, right up there with such things as glass and language.
There is no spoon.
thewmatusmoloki
Postby GCinDC » Tue Dec 20, 2011 7:04 pm
thewmatusmoloki wrote:Lost 2 fingers on the left hand which have been sewn back on, still touch and go whether they stay on. Not sure how thats going to affect his career as a first class sheet metal worker.
Brutal. Was this his first ebike? Best of wishes to him. Hate to hear about this. Glad he's alive.
Youtube channel, 2011 Highlights vid. Ebike Nerdcast.
Giant DH Comp: 20s lipo (10Ah), hs3540, 72V 45A 12FET, 900W BMSBattery charger.
GT I-Drive, 20s lipo, 9C, 72V 45A 12FET.
GCinDC
1 GW
1 GW
Postby oatnet » Tue Dec 20, 2011 8:04 pm
Glad he is alive, I wonder what the heck he hit at speed! Heck the brake disk is as dented as the rim~
-JD
Member 117 of 16,xxx
179v VW Camper © 164v Vectrix E-Moto © 72v Norco A-line/x5403 © 60v Specialized Enduro Comp/BMC © 72v x5tracycle © 48v TF IO/BMC © 36v Kepler Friction Drive © Spot-Welding a123 © Pelican Front Packs © Vectrix Battery Replacement © MORE !!
Image大鸡巴 Motors
Knowledge is acquired through experience, everything else is just information - Albert Einstein
"Cheater?" I'm not competing, I'm Commuting!
oatnet
Postby thewmatusmoloki » Wed Dec 21, 2011 11:07 pm
Nah it wasn't his first ebike, had 2 previously, only golden motor ping powered types before though.
He's a good rider without any doubt (I will only put ebikes together for people/adults with at least half a brain).
Being hit from behind by a car dosen't make much difference to the type of pedly tho, probably. :P
He's getting his arm rebroken and set today, could be home by the weekend now, fast healer apparently, very fit.
There is no spoon.
thewmatusmoloki
Next
Who is online
Users browsing this forum: gua_rana, kelvinscott76, rusty67 and 13 guests
