Fractal's Norco A-line build
Re: Fractal's Norco A-line build
Postby fractal » Sat Jan 28, 2012 10:34 pm
My wheels are getting shipped monday :D ! In the meantime, I got my pack harness and some Method's LVC parallel boards to protect the pack. I hired Icecube57 to make my harness, since i'm so busy right now. He did a very good job and I can recommend him to anyone. To charge my pack, I read so much threads on different ways of doing it. I decided to series charge just like my friend El_Steak. I will use 2 Hyperion 1420i and 2 Meanwell power supplies. That way, you don't have to reconfigure your pack to charge and avoid dumd mistakes. I made a diagram to illustrate my setup and to make sure I fully understand how to do it. Here are some pics of the harness, parallel boards and charge-discharge diagram.
complete harness with Method's parallel boards
80 amp fuse
pre-charge resistor to avoid sparks when plugging in the controller
charge-discharge diagram_1.jpg (112.7 KiB) Viewed 588 times
Norco A-line DH bike with :
«cromotor/hubzilla» from http://www.greyborg.com/
24s 3p Lipo (100v, 15ah)
Methods LVC/HVC cell level protection system http://www.methtek.com
24 fet infineon controller made by Lyen, heavily moded by Methods
8awg harness by Icecube57
17 inch moped rims with Michelin Gazelle tires by John Rob Holmes http://www.holmeshobbies.com
other stuff http://www.ebikes.ca
details
http://endless-sphere.com/forums/viewtopic.php?f=6&t=31850
fractal
Postby oatnet » Mon Jan 30, 2012 5:23 pm
Good progress, Frac!
Standard practice is to put the fuse in the middle of the pack, not at one end. The middle position will also protect against some shorts within the pack, and to cut your voltage in half in the event of a problem.
-JD
Member 117 of 16,xxx
179v VW Camper © 164v Vectrix E-Moto © 72v Norco A-line/x5403 © 60v Specialized Enduro Comp/BMC © 72v x5tracycle © 48v TF IO/BMC © 36v Kepler Friction Drive © Spot-Welding a123 © Pelican Front Packs © Vectrix Battery Replacement © MORE !!
Image大鸡巴 Motors
Knowledge is acquired through experience, everything else is just information - Albert Einstein
"Cheater?" I'm not competing, I'm Commuting!
oatnet
Postby fractal » Mon Jan 30, 2012 5:37 pm
oatnet wrote:Good progress, Frac!
-JD
Thanks Oatnet! I will check that out.
details
fractal
Postby icecube57 » Tue Feb 07, 2012 1:19 pm
-JD
I totally agree with this. To even be more protected it should be on each parallel group for even more protection. It isnt hard to do but it creates a very bulky harness.. I can create a plug if he wishes to where he can put it in the middle of the packs as you suggest. The fuse isnt going to protect the controller if the mosfets decide to do a dead internal short the damage would already be done its just protecting the batteries and one rule of fuses is to put it as close to the battery as possible which is what i did. There are several ways to do it depending on what you are trying to protect and how serviceable you want it to be.
Putting in the middle of the pack only reduces the voltage the fuse sees so there is less of an arc incase it does blow and a better chance for the fuse to do its job correctly.... I think or thats what i read on the forum.
icecube57
1 GW
1 GW
Postby fractal » Tue Feb 07, 2012 1:31 pm
-JD
Thanks for the tips guys!!!
I have decided to get the breaker board from Methods to complete my LVC/HVC setup. Now I will have full LVC/HVC protection wich will allow me to bulk charge and balance with battery medics when needed. you can just carry the charger in a backpack and charge pretty much anywhere! Here is the diagram with the complete system. And below is the full size diagram.
bulk charging solution 1.JPG (94.39 KiB) Viewed 500 times
(232.08 KiB) Downloaded 4 times
details
fractal
Postby icecube57 » Tue Feb 07, 2012 2:17 pm
I didnt know you had dual 1420s but you got a pimpin protection system... Guess u can use my charge harness for a rainy day lol everything looks awesome.... CHEERS. What software do u use for your diagrams.
icecube57
1 GW
1 GW
Postby fractal » Tue Feb 07, 2012 7:23 pm
icecube57 wrote:I didnt know you had dual 1420s but you got a pimpin protection system... Guess u can use my charge harness for a rainy day lol everything looks awesome.... CHEERS. What software do u use for your diagrams.
i use sfx for mac(i think thats what its called) its just a sketching software, has nothing to do with electrical schematics. i just use it because its really simple. i forgot to add the precharge resistor, will have to do that to make it complete!
details
fractal
Postby fractal » Fri Feb 10, 2012 10:02 pm
!Taking shape! Its finally starting to look like a bike. I got wheels from John Rob Holmes! the back wheel with the cromotor is a 17 inch moto rim laced with 12awg spokes with a 2.5 Michelin gazelle tire. the front wheel is a 17 inch moto rim laced with 13awg spokes on a DMR hub with a 2.5 Michelin gazelle tire. I also got this really cool seat post rack for the 24 fet controller with an adjustable tilt to accommodate the seat post angle of DH bikes. Its made by pletscher. I figured out a way to securely fix the battery boxes, I also figured out a way to dish them outward a bit so that if the suspension bottoms out, the tire won't smash against them. I will finish that this weekend and post pics!
THe back wheel will be moved back about 2 or 3 inches to extend the swingarm and help prevent wheelies
DMR hub on a moto rim! gotta love it!
this adjustable seat post rack can be tilted so that its perpendicular to the ground
details
fractal
Postby binlagin » Fri Feb 10, 2012 10:09 pm
That looks so awesome! Good work, I can't wait to see if finished
Greyborg Motor, 18-FET Lyen Controller
Turnigy 20C @ 30S x 2P
Giant Team DH Bike, Kiwi Dropout adapters
100km/h+
binlagin
Postby MattyCiii » Fri Feb 10, 2012 10:27 pm
Looking good!
My A-Line is still just a frame. And a bunch of boxes of parts. And I don't even have seat/seat post nor handle bars ordered yet! But I have rear wheel built, and spokes on the way from JRH. Build thread will begin as soon as I have something/anything attached that actually rotates!
1st build: Dahon Jetstream folding bike. Quick, reliable, capable of 30mph. Light enough to lift, folds for easy transport by car/bus/train.
2nd build: RC powered 2009 Norco A-Line. Top speed 31mph. Built like a tank, it's resistant to Boston potholes, can stop on a dime, easily goes up/down curbs when necessary.
3rd build (just started): Scratch build ultimate utility bike.
MattyCiii
Postby sn0wchyld » Fri Feb 10, 2012 11:53 pm
looking good mate, particularly with the 17" on the front too. I just laced my rear to a 17" moto rim too, but it looks a bit weird/too much like a MX bike with the 26" still on the front.
Word of warning, watch your pedal clearance, particularly in the corners. Im getting way more pedal strikes now with the lower overall height. Not caused any crashes yet, but still jars your legs pretty badly. alternatively build your drop outs to raise the back by an inch or so to help compensate for the smaller wheels (I think your planning this already right?).
Any chance you can squeeze that controller in the gap between the tire and the rest of the swing arm now that there's a big gap there? Had I not mounted my 12fet already between the pedals I'd be mounting it there! 24fet's probably way to big unfortunately.
that seat looks comfy! where'd you get it/what type is it/cost?
Had a sick ride on my aline yesterday... raced a guy on a ice bike, and won easily! doing 60+km/h over speed bumps made it hard for him to keep up! :twisted: just wished I'd filmed it.
Got questions? hit up the wiki!
http://www.endless-sphere.com/w/index.php/Main_Page
My builds:
http://endless-sphere.com/forums/viewtopic.php?f=3&t=29373
Norko Aline Park DH - Clyte HT3525 - 24s lipo
http://endless-sphere.com/forums/viewtopic.php?f=28&t=33657&p=534823#p534823
'02ish Avanti D8 - 8085 170kv - 5s 40ah lipo - ple80 recution
abject failure in september
http://endless-sphere.com/forums/viewtopic.php?f=12&t=43143
RC driven Electric mountainboard - New vids up!
sn0wchyld
Postby fractal » Sat Feb 11, 2012 10:58 am
sn0wchyld wrote:looking good mate, particularly with the 17" on the front too. I just laced my rear to a 17" moto rim too, but it looks a bit weird/too much like a MX bike with the 26" still on the front.
Thanks! for the pedals, I chose a crank with 165mm arm lengths with is the shortest I could find. should help a bit. But I don't plan on pedalling at all :mrgreen: . The controller is too big to fit there, I'll have to leave it there. The seat is an Allay Nomad. Its pretty comfortable and its not too big : http://www.allaysaddles.com/products/detail/Nomad1_1_m
60+km/h over speed bumps sounds pretty exciting :twisted: I'll have to get a gopro :twisted:
details
fractal
Postby fractal » Sun Feb 12, 2012 1:47 pm
The battery boxes are pretty finished. I still need to make a few minor adjustments. I'm very pleased with the end result. I will bolt the boxes with the brackets to secure them. Check it out :
details
fractal
Postby Justtoby » Sun Feb 12, 2012 4:21 pm
It's gonna hurt if you ash your knees on those boxes, have you tried them in a wind tunnel lol
Seriously though its a nice build but I think those boxes are massive. :mrgreen:
Justtoby
Postby fractal » Sun Feb 12, 2012 4:28 pm
Justtoby wrote:It's gonna hurt if you ash your knees on those boxes, have you tried them in a wind tunnel lol
my knees dont touch the boxes, i made sure of that. dude, thats for 24s 3p, 12 bricks of lipo! you need to get creative to mount those on a full suspension bike.
details
fractal
Postby Sacman » Fri Feb 24, 2012 5:17 am
That's 7 or 8-inches of front suspension travel right?
Isn't that front tire gonna be hitting your boxes if you're turning and hit a big bump? :shock:
(Should be okay if you're holding the wheel straight tho)
Sacman
Postby fractal » Fri Feb 24, 2012 8:47 am
Sacman wrote:That's 7 or 8-inches of front suspension travel right?
yes that is correct. if the wheel is straight, no problem. if i'm turning and i hit a massive pothole, i have 140mm of clearance out of the 200mm travel of the fork. so i need an extra 60mm to get peace of mind. i think i will make another set of boxes that are 30mm shorter and mount them 30mm higher so the fork can travel the full 200mm. it will be a tighter fit for the wiring but i can mange that. eventually, i would like to make something out of fiberglass.
details
fractal
Postby sn0wchyld » Fri Feb 24, 2012 6:37 pm
hey frac
have you thought about putting some of your batteries in a hardcase box on the front of the handle bars? then you'll have a smaller # of packs to try and fit on the frame itself. Fitting 5 or 8 ah of 24s on to the front shouldn't take up much space or weigh too much, but it would free up allot of space on the frame.
I'm planning on doing the same myself, it was originally just going to be a 24s5ah booster pack to the 10ah I already have on the frame, but when I found I could fit 24s 8ah in the 25x15x10cm case I'd bought I'm now thinking of using that as my main battery and using frame mounted bats as booster packs, since 8ah is more than enough for my commute/shorter rides. its just a question now if the extra weight on the steering feels ok...
My builds:
sn0wchyld
Postby fractal » Sun Feb 26, 2012 7:51 pm
sn0wchyld wrote:hey frac
I think i'm going to get the 6s 8000mah nanos. i'll have 8 bricks, and instead of having to rows wide, i'll just have one row and I can make the boxes more compact.
details
fractal
Postby fractal » Sun Feb 26, 2012 7:55 pm
GREAT FIND!!! I found this direct mount stem made by Diety Componentshttp://www.deitycomponents.com/. Its a 2 piece stem that fits on a double crown fork (boxer race, ...etc). this means that you can fit your CA right smack in the middle of your handlebars :mrgreen: If fits like a glove!!!
check it out :
details
fractal
Postby fractal » Sun Feb 26, 2012 10:02 pm
Was thinking about the pack, my boxes, mounts, ..etc I was going to get 12 bricks of 6s 5000mah for a 24s 3p config (1332 watt hours). Screw this!!! I will get some 6s 8000mah nano's for a 24s 2p config (1416 watt hours). That way i'll only have 8 bricks and the whole pack will be much easier to mount to the frame. I'll have a bit more capacity and there will not be issues with clearance for the fork, the pedals, knees, ...etc. The whole setup will be a lot less wide (and more expensive :| ). Back to the drawing board!!!
details
fractal
Postby fractal » Thu Mar 22, 2012 1:09 pm
My torque plates are finally ready for machining!!! It has been a very fulfilling experience filles with highs and lows. Getting this design done was the most ambitious, complex and difficult project I have ever done (and I'm not even the one who designed it!!!) Coordinating evryone's skills and efforts that has contributed to this was a real challenge, and I learned so much about fabrication, 3d design, engineering, ...etc. there are 2 members of this community that have helped me with this project. MattyCiii and adam333, thank you so much for helping me with this!!! You guys are awesome! Also, the contribution of a very talented mechanical engineer Ph.D. has been very valuable in combining Matt's and Adam's design to fit my motor setup. Enough with the a** licking!!!! Let me explain the design. There are 3 modifications that I wanted to make from the original parts : wheelbase, material and axle hole. With this new design, the wheelbase will be extended 2 inches to help prevent unwanted wheelies. Its not a lot but it should help, the «cromotor» is a beast!!! Also, the axle holes are designed to be a tight fit on the axle to keep it from moving around and it will be held by big M16 bolts for an even tighter fit. the cromotor has big stiff phase wires, a channel will be machined on the back of the plate to prevent the wires from touching the turning wheel. the material that was chosen is HRS (hot rolled steel). Its a popular material, readily available, low cost, pretty solid, ...etc. Aluminium was ruled out because of the strong forces of the motor. The engineer has provided everything a machinist will need to make the plates : a detailed plan that includes tolerances, dimensions, instructions for the machinist, material to be used, different faces and angles of the design. IGS and STEP files : those are to be used to program the CNC machine. Lastly, the 3d file for future reference and modifiactions to the design if needed. Now, the next step if to have these things fabricated and thats it!!!! DONE!!! time to move on to the battery pack!!!!
check out the design plans :
p0_1 800 by 600.jpg (78.62 KiB) Viewed 931 times
p0 800 by 600.jpg (89.08 KiB) Viewed 931 times
original size plans:
(145.15 KiB) Downloaded 4 times
(166.18 KiB) Downloaded 4 times
details
fractal
Postby MattyCiii » Thu Mar 22, 2012 4:47 pm
Thanks for the props, Fractal. I'll be biting my nails for the next few weeks wondering what my "variant" of these dropouts will be like. It'll be oh so satisfying to mount that rear wheel and at least be able to pedal my A-Line around awaiting parts to go electric!
MattyCiii
Postby El_Steak » Fri Mar 23, 2012 9:53 am
Very impressive Fractal & all.
It's amazing all the stuff you get to learn when you get in this ebike hobby.
TidalForce S-750 frame
Rear 2807 in a 24" wheel fed by a Methods 100V 100A controller
LiPo config: 24s3p 15ah
All the details here: viewtopic.php?f=6&t=17166
El_Steak
Postby oatnet » Sat Mar 24, 2012 11:55 am
Wow! Impressive work from Team Frac! I look forward to seeing how they turn out! :mrgreen:
-JD
Image大鸡巴 Motors
oatnet
PreviousNext
Who is online
Users browsing this forum: Cowardlyduck, kentlim26 and 11 guests
