Next, scratch that. THIS years bike
Re: Next years bike
Postby Jason27 » Tue Jan 03, 2012 4:22 pm
Thats a sweet bike your building. I wish I had the $$ to build something like that. Best of luck to you.
My ebike:
Diamondback with 800 watt hub motor with AllCell 48V 12AH Lithium Manganese battery pack.
36v hobby king lipo as backup.
"Conquering the hills of SF"
Jason27
Re: Next years bike
Postby Farfle » Tue Jan 03, 2012 10:30 pm
Getting more done, been working on the next batch of Genesis swing arms , so not a whole lot of progress, here's some more pictures.
The race bike:
24s5p 50c nano tech
Badass custom mofo outrunner 205x177mm 26kv
Peak power in : 318A at 91v
Peak power out: 24 Hp and 151ft/lb
Build to last...
"It will be assaulted by the elements, It will be ravaged by time and it will be destroyed by the user. BUT, if you Stick to the little rules: K.I.S.S., Overbuild everything, and test, review, revise, repeat. It will last"
Team Farfle blog!! http://www.farfleselectrics.blogspot.com
Farfle
Re: Next years bike
Postby etard » Wed Jan 04, 2012 11:17 am
Lookin good man! Am I seeing that right? The swingarm
rotates around the Bottom Bracket? If so, I like this idea, my Cove G-spot had this design and clamped onto bearings around the bottom bracket.
etard
Re: Next years bike
Postby gwhy! » Wed Jan 04, 2012 11:53 am
Farfle wrote:Getting more done, been working on the next batch of Genesis swing arms , so not a whole lot of progress, here's some more pictures.
Hi Farfle,
Its coming together well. Can I ask a quick question, how did you bend the rectangle steel for your swingarm :?: It looks a lot better than what I did for mine.
gwhy!
Re: Next years bike
Postby Alan B » Wed Jan 04, 2012 11:55 am
It appears the swingarm pivot is a couple inches behind the bottom bracket. I wonder if the connection there is stable enough against torsional moments.
The Greyborg frame has coaxial bearings for the swingarm.
Alan B
1.21 GW
1.21 GW
Re: Next years bike
Postby kfong » Wed Jan 04, 2012 12:22 pm
A frame that flexes at high speeds around corners would be a concern. Single pivot designs seem to have those issues.
kfong
Re: Next years bike
Postby johnrobholmes » Wed Jan 04, 2012 12:34 pm
Multi link suspension can be just as flexy, if not moreso from the additional slop of multiple pivots. It is more important to design the pivot and swingarm correctly than to worry about the type of linkage.
_______________________
Volt up, gear down!
http://www.HolmesBikes.com -- Custom 15 -12ga spokes
http://www.VoltRiders.com -- Custom wheels, ebikes, and Mopeds
johnrobholmes
Re: Next years bike
Postby Farfle » Wed Jan 04, 2012 5:08 pm
Battery pack is assembled! 24s 3p of 5 ah nanotechs, entering the 1kw/hr club in style :mrgreen: 8)
The race bike:
24s5p 50c nano tech
Build to last...
Farfle
Re: Next years bike
Postby Andje » Wed Jan 04, 2012 5:45 pm
24s3p? why not just go for it with 36s2p? :P
Norco 125 Dirt Jumper
100v 15ah Lipo Backpack
lyens 18 fet, 100v 100 amps, R12 Regen
x5304- 95km/h
http://endless-sphere.com/forums/viewtopic.php?f=3&t=24594
Norco A-Line Park 2009
144v Kelly 300amp
5403/ future HS60
http://endless-sphere.com/forums/viewtopic.php?f=6&t=35652
Andje
Re: Next years bike
Postby gensem » Wed Jan 04, 2012 9:58 pm
Andje wrote:24s3p? why not just go for it with 36s2p? :P
Farfle is going to wind his motor, and im gessing its going to be a fast wind. Like 15kv, so he can use 4110 mosfets that handle more current. :)
A decent 25mph bike will cost around $1000.
A decent 35mph bike will cost around $2000.
A $1000 35mph bike will get you killed.
Justin we really appreciate what you did!
gensem
Re: Next years bike
Postby nicobie » Thu Jan 05, 2012 2:50 pm
I did battery work ONCE on a steel bench. :oops:
May your tote always stay tight and your edge eversharp :wink:
my eTownie build thread: viewtopic.php?f=6&t=23701
nicobie
Re: Next years bike
Postby neptronix » Thu Jan 05, 2012 3:07 pm
nicobie wrote:I did battery work ONCE on a steel bench. :oops:
I already know how this ends.. and my condolences :shock:
Is that how you got your avatar pic? :mrgreen:
ES facebook group: http://facebook.com/#!/home.php?sk=group_125035107565566&ap=1
The all-arounder: 8T MAC motor on a Trek 4500.
The girlfriend bike: 350W front MAC on a 700c Trek.
The Bus: ??? on a 'da bomb' cargo bike frame
Pro-tips for noobs: Avoid BMS Battery like the plague | Charge RC Lipos to 4.15v, stop discharging at 3.5-3.6v | Use torque plates/arms! | Rear mounted hubs are always best
neptronix
Re: Next years bike
Postby Andje » Thu Jan 05, 2012 3:07 pm
hhaaha its SO true; i hadn't noticed. Trusting your $$$ to those chinese brand red plastic connectors lol. That would make one hell of an interesting vid; i can see the youtube caption now: "...skip to 1:43 to see one pack weld itself to the table... skip to 10:54 for the fireball...".
x5304- 95km/h
144v Kelly 300amp
5403/ future HS60
Andje
Re: Next years bike
Postby SamTexas » Thu Jan 05, 2012 3:47 pm
Very good observation! I guess it takes one to know one!
SamTexas
Re: Next years bike
Postby Microbatman » Thu Jan 05, 2012 10:09 pm
The stock/factory connectors look like they provide some protection. But never hurts to be too safe.
Best quote I heard about wiring lipos
"Like working with a hand gernade with the pin pulled out"
Yep take off the wedding ring. Or electical tape it if it does not come off.
When possible try to use plastic knife rather than metal knife for cutting.
Move all metal tools off the bench. Only work with 1 exposed wire at a time.
Do you plan on sticking with the stock connectors or install new/different ones?
Lipo language translated for those in need.
24s3p explained
24s is 4bricks. Each brick has six individual cells. So 24s is 4X6
3p is 3sets of the 4bricks
Anyways looking good. Cant wait to see the final product.
MotorCrystalyte X5304 20 Inch Rear Wheel DISC Brake Controller Crystalyte 48A72V4110MOSFETS
Batteries A123 24s2p
Charger Mastech 5020
Frame Azonic Steelhead
Grateful/fortunate/blessed to have the resources and family support to enjoy my ebike hobby
Microbatman
Re: Next years bike
Postby Farfle » Fri Jan 06, 2012 3:45 am
I would never work with batteries, especially those batteries on any steel table except that one, it doesn't conduct at all, cause it's been lacquered so many times. but anywho, I got the BMS set up today, but it's not working, all the cells are perfectly balanced, but the end of charge light doesn't turn green, so the meanwells just sit there floating at 100.8v. And why is it the more awesome a battery is, the more it looks like a bomb :shock:
The race bike:
24s5p 50c nano tech
Build to last...
Farfle
Re: Next years bike
Postby kfong » Fri Jan 06, 2012 5:37 pm
Ha ha, it that thing ever goes off. It will be a bomb :mrgreen:
kfong
Re: Next years bike
Postby cohberg » Sat Jan 07, 2012 9:21 pm
Farfle wrote:I got the BMS set up today
can you talk a bit about the bms you have on there?
Build 5.0 - Commuter (Active) | 18xIRFB4115@50A | 30S2P 10Ah | GM Rear Hub | V2100 | CST-Cyclops | XC 28
Build 5.1 - Chain Virgin (Halted) | HPM5000B | 11.4:1 reduction ( 12:32 - 9:38) | HPC300 72V300A | 20S5P 25Ah
cohberg
Re: Next years bike
Postby Farfle » Sat Jan 07, 2012 10:04 pm
The bms is the ggoodrum/fechter zephyr lite, google it and you will find the sphere thread on it. And speaking of the bms, I got it working, right upuntil I plugged the meanwells into an improperly wired outlet that cooked 3/4 of them :shock: :cry:
The race bike:
24s5p 50c nano tech
Build to last...
Farfle
Re: Next years bike
Postby Farfle » Tue Jan 10, 2012 7:17 pm
Suspension is coming together :D. heres some more pics, she's almost a roller! :D :mrgreen: :D :mrgreen: :D :mrgreen: :D
The race bike:
24s5p 50c nano tech
Build to last...
Farfle
Re: Next years bike
Postby Microbatman » Tue Jan 10, 2012 9:44 pm
Looking Great!!!
Love the adjustablity of the rear shock mount.
More tuning choices.
Back to the Bottom Bracket that you posted about on page 1 with a nice picture.
You mentioned you lengethed it 1 inch.
Did you have to modify the cartridge/internals that connect the pedals?
I found a 100mm wide bottom bracket from here.
http://www.paragonmachineworks.com/cgi- ... key=BB2010
How wide (left to right) is the modified bottom bracket you made?
Anyway my new favorite tread. Keep up great work.
Microbatman
Re: Next years bike
Postby Farfle » Sun Jan 15, 2012 10:34 pm
Front brake, 210x2.5mm thick rotor :D
The race bike:
24s5p 50c nano tech
Build to last...
Farfle
Re: Next years bike
Postby etard » Tue Jan 17, 2012 6:52 pm
Looks great Farfle, I'll have to get a rearview mirror so I can see that thing in action. :lol: Take those shrouds off the forks and let that thing breath. How have you healed up from your accident? Gatorbrakes huh? I got those mounted on the front too, I'm wondering how they do, I expect a full review. :wink:
etard
Re: Next years bike
Postby Farfle » Tue Jan 17, 2012 7:29 pm
You better have a rear view mirror, want you to see me lapping ya :twisted: . Pretty much all healed, rotator cuff takes forever to heal tho, And I have no idea how the brakes will work, will find out when I get out rolling
The race bike:
24s5p 50c nano tech
Build to last...
Farfle
Re: Next years bike
Postby Lenk42602 » Tue Jan 17, 2012 9:39 pm
those gator brakes stop very well, just take a bit to seat the pads. No problem locking up the front with a 203mm or the 11.75" rear rotor I have on my 5303.
better stopping power than any other bicycle brakes I have ever used....
Lenk42602
PreviousNext
Who is online
Users browsing this forum: AussieJester, GCinDC, Harold in CR and 7 guests
