The one thing I must admit, I really like 40V lipo. Smooth power delivery and I use 15 amps at 25 mph as opposed to 38 amps at 40mph and 72 volts. So that's just about a 15mph speed difference with half the volts. That's my fun fact for the day:D
veloman wrote:
The last time I met a gasser, I really felt like I was sandbagging. I meet gas scooters (Honda Ruckus or similar) at lights at times, and usually it's pretty comparable, but hard to tell if they are WOT or what. If I go to 60v instead of 48v it would be a lot more interesting.
Glad you're enjoying your new ride. The black battery boxes look much better.
Trackman417 wrote:One quick question for people who are much more knowledgeable about circuits than I am....
I got a harness from icecube that series' my packs for discharging and then parallels them for charging. When I charge the battery's, I series the discharge leads and the balance leads.... This is where there is room for error. I have connected the series plug with the balance connectors two times too many. So my way to combat this problem is to add a small 4-5 amp fuse inline with each and everyone of the balance leads. The main belief behind this theory is the wires melt... Melting wires means more current than is good for the wires. So the fuse will break and instantly cut off the parallel connection between each individual cell. Other than a ton of soldering, are there any objections? More importantly Would this work??![]()
Tench wrote:There is a simple way to arrange your balance wires for series charging of a parralel setup, have a look at how i did it in this thread;
viewtopic.php?f=2&t=39489
This is the bike build thread which will enable you to understand the setup and therefore the explantion better;
viewtopic.php?f=6&t=37489
Simon.
Trackman417 wrote:Tench wrote:There is a simple way to arrange your balance wires for series charging of a parralel setup, have a look at how i did it in this thread;
Simon.
Alright Tench! Thanks for the links. I was looking at your build a month or two ago for inspiration. One question I have for you is where did you source the D-sub connectors. I was shown links of pictures of them however no links or stores to buy them.
Can you post on your page how you made the plastic connect blocks aswell? I am sure plenty of people (including me) would like a rather robust way to charge and discharge packs, with ease and simplicity. If you wanted to, I bet you could make some money making custom charge/ discharge blocks. I wouldn't mind being your first customer
sn0wchyld wrote:I recon tench has one of the best setups ive seen for switching reliably between series and parallel.
sn0wchyld wrote:depending on where you are, you can pick up the Dsub connectors from most electronics stores (like Jaycar), though ebay is the cheapest usually. that way you can still use the pcb traces as fuses, as its far less likely you'll have an accident.
sn0wchyld wrote:
sorry for jacking the thread a bit...
Trackman417 wrote:sn0wchyld wrote:I recon tench has one of the best setups ive seen for switching reliably between series and parallel.
Ohh yeah +1 on that. Easily the best charging/discharging setup out there. It is quite literally fool proof.sn0wchyld wrote:depending on where you are, you can pick up the Dsub connectors from most electronics stores (like Jaycar), though ebay is the cheapest usually. that way you can still use the pcb traces as fuses, as its far less likely you'll have an accident.
On my way to work I decided to stop by the local radio shack, and guess what they had! 25 pin D-Sub connectors! Looking at them thinking I have to solder each balance lead on there, looks like a pain in the neck!while I'm there I'm gonna need to pick up a small soldering iron as well. The iron I have has a tip the size of a big old construction pencil
Ehh. Don't worry about it. I was going to ask that question eventually anyway
sn0wchyld wrote:Trackman417 wrote:sn0wchyld wrote:I recon tench has one of the best setups ive seen for switching reliably between series and parallel.
if you really hate soldering, you can get db25's that connect to ribbon cables. you need a bench vice or something to do it well but it can make the job much easier. like these...
it does limit you to 28g wire (the thickness of ribbon cable) but lessens the workload allot. 28g should be ok for up to about 500ma, or 1a if its got lots of airflow over it. that's pretty conservative #'s too.
Really soldering them is pretty easy. get a iron with a small pencil like tip. first, go and fill all the little 'pins' on the back of the db25 connector with a bit of solder. just enough to fill the little hole + a bit more. then tin up the wires you're connecting. finally, heat up one of the pins to get the solder to melt, and jently push the wire into the hole. leave it there with the iron for a second or two, take the iron off and then your done! its pretty quick once you get the hang of it. just one big tip though: make sure you draw up which pin is going to which pack before you start, or else you might need those fuses sooner than you thought!
sn0wychyld wrote:Really soldering them is pretty easy. get a iron with a small pencil like tip.
sn0wchyld wrote:ha no probs mate. Just tryin' to give back some of the love ive gotten from es'ers over the past year or so. I look back at my first posts now, and its startling just how much ive learned. Hell, I didnt even know what 's' and 'p' on batteries meant then!
And while soldering + thicker wires is better for balancing, there's nothing wrong with using the ribbon type connectors. You just need to be aware of their limitations.
Trackman417 wrote:So I spent a good portion of yesterday wiring up a D-Sub connector. When I say it took me a good portion of the day, I mean 2-3 hours of soldering. I go new soldering station with a pencil tip just for the job. The one problem that I found was finding a way to parallel the leads through the other connector. So I got some copper cable from my previous bike unthreaded it, and soldered them into the connector. Sorry I don't have pics of that process but I do have pics of the end product.
After rewiring or making a new connector, does anyone find themselves connecting the new piece slowly or inspects it 1,000,000 times before zero hour? In hopes that if something does go wrong you will spot it and correct. I was doing just that! I connected the first JST-Xh connector, then I went for the other one, slowly. Then came the real test of paralleling them with the other connector. If anything happens it was going to be that one last connection.
Damn I do a good job, when I know what I am doing
YOu like what you see Sn0wychyld?
Tench wrote:I remember when the time came to plug my harness together for the first time, i checked the continuity and insulation of every connector and cable, balanced all the packs, double checked then tripple checked, then bit the bullet and plugged it in, right first time!![]()
My setup is working extremely well, every time i plug it onto the icharger all the 6p cells strings are at identical voltages, the most i have used of the 16ah is about 11ah so i am recharging when it is at about 3.8v, i charge right up to 4.2v.
Snowchyld, Initail rides showed up a little too much chain slap and i once had the chain skip when on the 11t top gear, i was bunny hopping a speed hump! i refered to Sheldon browns pages to find the correct way to determine chain length for a deraillier system and had to remove 6 links!! to do it his way, it is perfect now! The whole drive system is standing up well, i dont know yet at what mileage things will need to be replaced but i am confident that with care and good maintainence it is going to be dependable and reliable.
Sn0wychyld wrote:nah man, looks like crap...
just jokes mate. Great job! looks nice and tidy! and yea, I've built a few packs now and I'm still tripple checking everything, and connecting things as slowly as possible... half expecting there to be a flash and a puff of the magic smoke! sadly, for me, it has happend a couple of times.
Sn0wychyld wrote:Once I dead shorted a 10s's 4mm bullets. POW! then i was left, staring down at my stumps where before there'd been bullets... . second time I managed to f'up my circuit board connections, which meant connecting the top half of a 8s pack to the bottom half via its balance leads. fortunatly I'd built it to blow like a fuse if anything like that happened. No harm done to the packs or me in either case. There's allot to be said for not playing with batteries when you're tired eh?
hydro-one wrote:you guys havent heard of KFF???![]()
viewtopic.php?f=2&t=31627&hilit=184v only one example....i remember metalover had some nice metallica lookin black marks on his hand lol
hydro-one wrote:lol, youve got the best long term lipo chemistry experiment!! that stuff is actually magic smoke, the water has somehow condensed it into a solid state!! you may have solved a great riddle, how to contain the magic smoke, now see what u can do to collect it up and bottle it!!!! im in for a few bottles......![]()
hydro-one wrote:yes that was skin coming off the hand and it took around a week or two.im much carefuller now
Users browsing this forum: badhorsie, Bing [Bot], Google [Bot] and 5 guests
