crusoe wrote:Hey adam, just re-read your thread again. After having finally finished my bike days ago, I too am noticing black residue all over my rear disk (none on front). Maybe time for a new set of pads?
crusoe wrote:Looks great! Can you post the URL to your photos? They tend to get cut off if you use [img] code
shorza wrote:My rear wheel seems to 'bounce' around some corners and i fear it's because of the amount of weight on the front. Are you getting anything like that?
oatnet wrote:What does your 3d scanner look like, is it a home-brew David-laserscanner? Are you using makerbot, or milling these parts?
adam333 wrote:shorza wrote:My rear wheel seems to 'bounce' around some corners and i fear it's because of the amount of weight on the front. Are you getting anything like that?
No bouncing at all, I adjusted the rebound as describe in the manual owner and even with the extra 55 pounds, it is prety stable.
When I lift the bike with one hand, the center of mass is around the yellow arrow, what about yours?
adam333 wrote:Thanks for the good words guys.
4800 km done so far on this bike this summer and I never had any serious issues.
I didnt work much on the bike lately, but my crusade against mud is still ongoing...
I scanned the front fork on the 3 D scanner as well as the "THE mudguard" I bought from Ebay.
I then modelised a strong ABS adaptor plate to secure the fender in place.
With this methode, the fit between pieces is perfect and there is no movement at all.
My next chalenge is to increase the length of the rear fender
cwah wrote:
So niiiiice!!
I want a 3D scanner too. Where can I get one at a good price?
I'm planning to get a CNC router in order to get my own parts:
http://www.ebay.co.uk/itm/PRO-CNC-3040Z ... 956wt_1021
If I also have a 3D scanner I will try to copy you
cwah wrote:I'm planning to do bike part on it such as battery case, clamp, holders, trailer part...
But I'll mill aluminium only as still would put the machine on its knee.
Here's a video of the tool machining aluminium:
So it can still do (soft) metal such as aluminium.
And torque arm can even be made of aluminium so it seems to be a good tool!
