low budget pocket rocket
Re: low budget pocket rocket
Postby Philistine » Fri Mar 16, 2012 6:54 pm
If you don't have the proper ebike freewheel removal tool (with the larger opening), you can just get a standard bike shop removal tool, and use a dremel with a carbide bit to widen the opening, that is what I did, took 5 minutes to do.
Philistine
Postby veloman » Tue Mar 20, 2012 12:20 pm
I got a kick out of these videos. I think I did something similar before.
Yup, time to flip the wheel around... and go back to original wiring.
Mush! Mush you electrons! Push harder!
Main ride: Old School Specialized Stumpjumper FSR, Clyte HT3540, 63v lifepo4, 12fet Infineon set to 26amps. And a bunch of others... viewtopic.php?f=6&t=34236&p=497325#p497325.
veloman
Postby nonlineartom » Tue Mar 20, 2012 4:13 pm
Done, getting a big of rub on the frame, need to put a washer in there to stop it grinding, but I can only stretch the dropouts using a scissor jack, removing the jack makes it return to it's original width (aluminium) and I don't want to over stretch and break the frame. I can't seem to widen the frame enough to fit it in with the washer and get the wheel in at the same time.
On the upside it looks absolutely bad ass.
Commuter bike: 10T MAC Schwinn Panther Beach Cruiser on 12S LiPo, super stealth hill eater
Forest trail eater: Crystalyte 5306 KMX Viper with 24" wheel. 100A controller 18S LiPo
Pocket rocket: 8T MAC e-BMX 18s LiPo. Missile for testing to destruction
Summer ride: 8T MAC Kona Joe MTB / chopper / beach cruiser hybrid bike. 24" wheels and a lot lot of style.
Respect and fear the ancient god LiPo and pray he is merciful.
nonlineartom
Postby knoxie » Fri Mar 23, 2012 5:48 pm
You will need a torque arm if that frame is ally, trust me :P My BMX still works 6 years now since I did this video, it was breaking spanners and shredding metal, if you dont it will snap your drops if they are ally, the one way bearings can go but they can be replaced but yes and ahem you had this the wrong way around :twisted: but yes fit torque arms, you can see what it does on my video, crikey this is an old one!!
[googlevid]1721490376015071704[/googlevid]
Electric KMX 72V Lipo, USPD drive unit. BMX 72V, Puma BMC,
Raleigh 26 inch MTB Puma 50V Turnigy 25C Lipo 10AH, Trek MTB, X5 48V NIMH. Electric BMX
http://tinyurl.com/4vrmc8 http://tinyurl.com/3umm4n
knoxie
Postby nonlineartom » Sat Mar 24, 2012 10:50 am
Yeah they are ally dropouts, really quite thick beefy bits of metal though (side loading axle) and a very tight fit but I'll fit a Lyen universal torque arm for now and then mig weld one of Docs torque arms in the future, I've already had the freewheel go in my 10T mac motor on my commuter.
All I'm missing now is a 14mm axle nut and I'll give it a test, should probably fit some functioning brakes too. What did you do for battery on yours?
nonlineartom
Postby nonlineartom » Sun Mar 25, 2012 3:16 pm
This thing is terrifying. Noisy as well, sounds like a formula one car in a box. Goes like a rocket. Taped everything up for a test ride today and it launches better than my X5 motor.
Next up I will put this motor on the trike and test it at 4kw. Has anyone ever drilled ventilation holes in a mac motor? or is that just stupid
photo 2.JPG (185.58 KiB) Viewed 964 times
nonlineartom
Postby nonlineartom » Sun Mar 25, 2012 3:30 pm
note the complete lack of brakes at the end resulting in the good ole foot brake method. I need to make this thing a lot more refined before actually riding it properly.
nonlineartom
Postby nonlineartom » Sun Mar 25, 2012 5:14 pm
Mike has found a name for this machine. Its now called:
I.N.N.U....
I need new underpants
nonlineartom
Who is online
Users browsing this forum: cruzxia, pendragon8000 and 5 guests
