The Mid Drive Hub Motor Media Group
Re: The Mid Drive Hub Motor Media Group
Postby bzhwindtalker » Fri Jun 22, 2012 12:47 pm
this one is pretty intense :
bzhwindtalker
Postby Lebowski » Fri Jun 22, 2012 1:16 pm
we need more video's like this to spread The Word and to show
e-bikes are not just for grannies
well done !
Lebowski
Postby aixelsyd » Sun Jun 24, 2012 2:14 pm
cool video, great editing!
aixelsyd
Postby spinningmagnets » Sun Jun 24, 2012 6:55 pm
From Warren, he uses the hub similar to the Hanebrink, halfway between the BB and rear-wheel, but with chains on both sides. A left-side cog on the 6-hole disc-brake flange is chained to the BB, and the right-side freewheel is chained to the rear wheel sprocket-set/derailleur. Pic is from an earlier chain configuration, but the hub has remained in the same location.
http://endless-sphere.com/forums/viewtopic.php?f=28&t=23259&start=135#p540457
spinningmagnets
Postby DiamondMobious » Wed Jun 27, 2012 10:58 pm
Miles wrote:http://www.endless-sphere.com/forums/viewtopic.php?p=290115#p290115
Anyone know the name of that clamp/bracket thingie holding the motor in place and where to get it please?
DiamondMobious
Postby Miles » Thu Jun 28, 2012 12:32 am
DiamondMobious wrote:Anyone know the name of that clamp/bracket thingie holding the motor in place and where to get it please?
You make it yourself....
Miles
Postby DiamondMobious » Fri Jun 29, 2012 3:03 am
Thanks for your response..
DiamondMobious
Postby briogio » Mon Jul 02, 2012 5:55 pm
spinningmagnets wrote:From Warren, he uses the hub similar to the Hanebrink, halfway between the BB and rear-wheel, but with chains on both sides. A left-side cog on the 6-hole disc-brake flange is chained to the BB, and the right-side freewheel is chained to the rear wheel sprocket-set/derailleur. Pic is from an earlier chain configuration, but the hub has remained in the same location.
Saturday was a good day!
I started my Project 2 Ebike, which will be a LWB recumbent, a la "Recycled Recumbents", and the coolest thing is it will be full-suspension, using parts from my first downhill bikes, (Trek 9000 and Pro-Forx LT's), you old school dudes might remember those 8).
Anyway I don't really understand the mondo gearing you can get on a recumbent and how you get your E-motor to use the bikes gearing?
Do you hook it up to the crank? or in between? What is the difference? do you get more gearing if you hook it up to the crank? I don't really get that bit.
Right now I'm planning on a Hubzilla as a mid-drive, 50 mph top speed and with enough batteries to commute just under 100 miles round trip (although I can charge it up at work, so I guess 50 miles range).
Very glad this group was started, I think mid-drives have more versatility, especially for range, than straight hubs (which was project 1)
briogio
Postby spinningmagnets » Thu Jul 19, 2012 4:32 pm
spinningmagnets
Postby briogio » Sun Aug 26, 2012 2:03 pm
2 newbie questions; 1, for full gearing advantage is it best to hook up the hub drive to the crank? 2, does the hub turn with it's drive sprocket?
Bonus question!; has anyone attempted a recumbent, or bike mid drive with a Cromotor? I'm thinking you'ld need to run heavier chain than 8 speed bicycle chain?
briogio
Postby spinningmagnets » Sun Aug 26, 2012 3:03 pm
"twingolo" from France...using a Bafang @ 36V
http://endless-sphere.com/forums/viewtopic.php?f=28&t=42116
spinningmagnets
Postby spinningmagnets » Mon Aug 27, 2012 4:57 pm
A Cyclone with upgraded DIY mounting bracket...
http://endless-sphere.com/forums/viewtopic.php?f=28&t=40895
spinningmagnets
Postby jateureka » Thu Sep 06, 2012 9:21 pm
The GNG midmount brushless drive http://www.endless-sphere.com/forums/viewtopic.php?f=28&t=42785
video on page 11
Bafang; Mac; Ezee; Easy2Ride; PowerPed; Nope; Condor; Aprilia; eLation V2; Razor
jateureka
Postby Whiplash » Sat Oct 13, 2012 10:21 pm
Here's a couple of vids to show what mine will do on about 1100 watts. After riding to this point and then climbing the hill the motor was maybe 10* above ambient or barely Luke warm almost not noticeable and so was the controller...
It will climb steeper than this but it gets very hard not to flip over, I was trying not to wheelie here but it still did a couple times...
https://www.youtube.com/watch?v=tzA-CTh ... ata_player
https://www.youtube.com/watch?v=bM63WOA ... ata_player
Power is a fascinating thing, the more you have, the more you want, but the real power is having the restraint not to use it all at once...............Um...Yeah..
The harder you work.....The luckier you get!!
"People who say it can't be done are often interrupted by those that have already figured out how to do it!"
Email me @ currentcycles@gmail.com
OR check out http://www.CurrentCycles.net
Whiplash
Postby crossbreak » Thu Oct 25, 2012 10:03 am
my tongxin middrive built in several built stages (earlier first):
http://endless-sphere.com/forums/viewtopic.php?f=3&t=34146
My first hub conversion middrive (decommissioned): http://endless-sphere.com/forums/viewtopic.php?f=3&t=34146#p495887
. . . Why not, make something that lasts?
crossbreak
Postby spinningmagnets » Thu Nov 08, 2012 9:58 pm
spinningmagnets
Postby sendler2112 » Tue Dec 25, 2012 1:59 pm
How is the chain and cassette life on these high powered mid drives?
sendler2112
Postby Whiplash » Thu Dec 27, 2012 9:38 am
Still on my first ones. Over 1000 miles easy plus tons of off road. The trick is to let off the power just a bit when you shift up, downshifting you can leave the power like when your climbing...
Whiplash
Postby courcheval » Thu Dec 27, 2012 10:14 pm
Conway e rider
Tench s prototype Number 2 : http://www.electricbike.com/specialized-super-charged/
Stealth Bomber Number 170
courcheval
1 W
1 W
Postby courcheval » Thu Dec 27, 2012 10:22 pm
courcheval
1 W
1 W
Postby sendler2112 » Fri Dec 28, 2012 6:08 am
Whiplash wrote:Still on my first ones. Over 1000 miles easy plus tons of off road. The trick is to let off the power just a bit when you shift up, downshifting you can leave the power like when your climbing...
Good to know. If a bicycle powertrain can hold up to operating mid drive for off road, it will easily take anything I would put through it on my commuter bike.
sendler2112
Postby bandaro » Sat Dec 29, 2012 5:55 am
So on a similar note, has anybody had any luck with >2kw and an internally geared hub? I'm thinking a 3-4 speed hub that covers the normal range would be awesome. A start gear, cruise/climb gear and a flying gear... thoughts?
bandaro
Postby spinningmagnets » Sat Dec 29, 2012 7:11 am
At >2kW, it would be wise to research the hub cooling threads. There is a long one for oil-cooling, and several discussing air-cooling. Since geared hubs have less copper mass and a smaller shell, they benefit the most from any cooling improvements, although direct-drive hubs clearly benefit also.
spinningmagnets
Postby bandaro » Sat Dec 29, 2012 9:28 pm
Oh sorry, I should have been more specific, I was meaning gears within the hub as an alternative for the cassette, not a geared hub such as a mac. There are a few big brand, expensive bikes (audi, blacktrail, m55, KTM etc) that claim 2kw and use a rohloff. I was wondering if anyone had any luck with an IGH that was a little cheaper that a $1500 rohloff. While 14 gears and a rohloff would be awesome, it is far beyond budgets for us, or at least me.
So any options out there?
bandaro
Postby amberwolf » Sun Dec 30, 2012 4:30 am
If you do something like Recumpence did with one of his drives to prevent shock loading, I expect the IGH could handle quite a bit, even for cheap old 3-speed hubs. But if you don't dampen the initial surge of power, and the gear lash allows them to smack into each other under high power, it could cause the teeth to rip out at the roots. See one of AussieJester's builds (either the trike or the first bike after that) for some description and pics and links about that problem using Sturmey Archer 3-speed IGHs. Might also be some from 1000w either in his own threads or in a separate one.
A slipper clutch or a "cush drive" like motorcycles often have (rubber damper blocks between the sprocket drive engage points on the wheel (IGH in this case) and the sprocket itself) would help dampen that initial shock. Power control/ramp-up like is avaialbe in the CA V3 would also help.
Doing something within the IGH to reduce gear lash would help, but might require remachining things for greater precision/meshing.
Pre-tensioning the chain or belt drive to the IGH so that anytime you aren't actually applying power to it it still pulls the chain or belt just enough to keep the sprocket pulling on the IGH so that it keeps the gears meshed fully would also help by preventing the gear lash from having the gap that allows the smashing-together of teeth.
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
PreviousNext
Who is online
Users browsing this forum: acn49 and 9 guests
