voicecoils wrote: at 48v for example I would arrive at work half as exhausted as I would otherwise arrive with a pedal-only bicycle.
recumbent wrote:
I don't get it, perhaps you have very steep hills? I can ride my 48 volt bike for two hours and don't get tired at all, and i'm outa shape.
recumbent wrote:You've been working on this bike for half a year and still haven't mounted your batteries yet.
Took me only one afternoon to complete my bike conversion from bare bike to roadworthy Ebike. This includes complete dependability for 5,000 km's.
It seems to me (and many others i'm sure) that building the bike is more important than anything.
Russell wrote:... The point being you determine how much effort you put into the activity so even if you have a big honkin' motor on your bike you can still choose to input a power level which would put you at your red zone...or barely raise your pulse.
voicecoils wrote:My plug in CA has died. Backlight comes on with battery power but either the screen stays blank or gives me garbage.
pwbset wrote:Oh man, that looks familiar. I would get that garbled crap all the time and then a complete fade away. What voltage are you running again??
My symtpoms:
viewtopic.php?f=2&t=5959
What fixed it for me:
viewtopic.php?f=2&t=6823
Been fine since... good luck.
HAL9000v2.0 wrote:"Up here" you can find standard key in any bearing shop for a few cents. Don't know how is down there...
TPA wrote:Does Keywin have a website?
Mark_A_W wrote:No, a bearing shop, not an engineering shop.
Try CBC bearings, ask for keystock - best is to just show up and see what they got.
How on earth did the key fall out? It would be pressed in....
very good idea. I'll give that a shot if I run out of ready made options.Drunkskunk wrote:Drill bits are hardened steel, and cheap. easy enough to grind one down to the shape you need. An afternoon with a few beers an an angle grinder should have you a new shaft Key. Worked for lawn mower I repaired for a friend once.
yeah, that's the way it usually goesI bet you'll step on the original key the moment you finish making the new key, too!![]()
I wouldn't sweat not being finished. You started Months after me, and I'm still not done with my latest build. I'm in no hurry either.
voicecoils wrote:Thanks. I think your experience is similar to mine, hopefully the solution will be too. After more testing, my CA will struggle to life at 36v (fading in and out), barely start up at 48v, and wont do it at all at 72v. I made 3 respective youtube videos. direct plug in CA on top, stand alone CA on the bottom. I'll be contacting Justin when it's Monday in Vancouver. I'm sure a solution can be found or sorted out.
I love the CA, make no mistake!!!
Users browsing this forum: Google [Bot] and 8 guests
