Voicecoil's red, fully rigid commuter
Re: Voicecoil's red, fully rigid commuter
Postby voicecoils » Tue Oct 28, 2008 5:28 pm
another day another test
Last set of fresh nylon gears!!! 36v only for now. Packed with moly grease (3%) we'll see how they go...
I managed to mount my CETMA rack on the read bike without any fork modifications. I just used two U-bolt w/ plates and screws. Then put the rack strut on and screws a nylock nut on top. I'll see how it holds up to vibrations and loads. If it slips down I'll look to a better solution.
I temporary mounted the 36-72v 35A Crystalyte controller (in non-slip rubbery stuff) to the vertical part of the rack, and the cycle analyst too.
I had a run last night with 36v10a headway pack in a bag occy strapped down on the rack. The bike handled fine with the weight, just a bit heavy on the steering. But standing still it really does want to fall over (thanks to the fork angle) and it is a MEGA pain to carry up or down stairs. (queue Mark_A_W saying: "I told you so") :wink:
More on the actual test run in the next post...
voicecoils
Postby voicecoils » Tue Oct 28, 2008 5:39 pm
I hooked the analogue Crystalyte 36-72v 35a controller up to the bafang and tried to follow Nogwin's wiring:
http://www.endless-sphere.com/forums/vi ... ing#p93646
Nogwin wrote:My sample of a BAFANG motor (from knuckles) to a Crystalyte analog controller 36-72v 35A looked like this:
Motor Controller
reverse jumper open
My motor wiring combo
Motor Phase -- Controller
B B
G Y
Y G
Hall
Motor Controller
pos pos
neg neg
B B
G Y
Y G
Other combos I tried did not get the motor moving (except one where it went backwards).
The combo I settled on worked but did seem a bit noisy and had high vibrations. I took it out on the street and as soon as I hit the throttle I was thinking "what the heck!". The whole bike was buzzing like crazy. The first thing I found was a loose water bottle cage bolt. A lot quieter after that. BUT still noisy. I proceeded to electrical tape down everything I could think of that might be making noise, brake lines etc... Controller and CA seemed very firmly mounted.
Today I'm going to go through the wiring combos again, and might take the rack back off and see if it is just transmitting vibrations through to the frame and causing all the noise. If so I'll try to isolate it with some bits of old bicycle tubes.
I only used 0.8Ah before I stopped riding. Too worried about the nylon gears and controller mis-wiring. It was loud enough that I didn't want to hit the throttle when passing people for fear of scaring them :shock: :lol:
It's raining today so a good chance to check my 36 wiring combos! But...I'm wondering if the crystaylte controller is just not the best match for the bafang. It does work, but could it be causing the bafang to operate with high vibrations?
voicecoils
Postby voicecoils » Tue Oct 28, 2008 6:37 pm
just checked wiring.
Nogwin's wiring runs my motor smoothly, but backwards!
Will try Docnjoj's wiring now:
Halls are the same but he ran the phases:
Motor -- Controller
B Y
G G
Y B
EDIT: DOC's work! but it is loud. I'm going to try to sort out where the noise is coming from. Sounds like a power drill drilling screws into 2x4s. I'm thinking it must have been Doc's wiring that I ran with last night...
voicecoils
Postby johnrobholmes » Tue Oct 28, 2008 6:41 pm
Could just be a loud ass controller. Is it harmonic frequencies or popping frequencies?
_______________________
Volt up, gear down!
http://www.HolmesBikes.com -- Custom 15 -12ga spokes
http://www.VoltRiders.com -- Custom wheels, ebikes, and Mopeds
johnrobholmes
Postby voicecoils » Tue Oct 28, 2008 6:50 pm
with doc's wiring I cranked the throttle no load...
and blew a 10A fuse :!:
Before I had 10A max current set on the CA, this time I took it off. Seems like I'm having the same problem doc had. Dammit.
I'd like to know how nogwin has his set up. maybe I can get him to double check his wiring.
voicecoils
Postby voicecoils » Tue Oct 28, 2008 8:04 pm
Ok, I've found the superior combo. (at least I think so! :oops: )
Nogwin's wiring with the 36-72v 35a crystalyte analogue controller jumpered to reverse (my key switch is broken).
Runs smoooooth at under 1A no load. DAMN the rain!
voicecoils
Postby voicecoils » Tue Oct 28, 2008 8:09 pm
johnrobholmes wrote:Could just be a loud ass controller. Is it harmonic frequencies or popping frequencies?
I would have described it as harmonic (noise from the motor). However I don't know what a popping frequency might sound like.
10A+ no load is just wack.
I think the combo I described in the above post is the answer. Road testing will tell for sure. I suspect nogwin has his switch turned to reverse or jumper jumpered, but we're running the same controller motor, and wiring now. mine is working with the controller in "reverse"
Motor sounds much smoother. Before it was sending vibrations through the whole frame.
voicecoils
Postby Freddyflatfoot » Tue Oct 28, 2008 8:56 pm
VC,
I would be interested to hear how you like the Bafang at 36v.
I am more than happy to run mine at 36v, but then mine is a 24v model overvolted to 36v!
Cruise speeds above 30 kph are fine for me for my commute, and by keeping the speed down a bit, I also keep a tighter reign on my whr usage.
Rob
Current setup, 250 watt/24 volt chain drive setup on Jamis MTB, 24 volt, 10 AHr Yesa LiFePO4 pack. 15A controller. (increased to 20A, currently dismantled) (motor sold)
Home built recumbent trike, 350 watt, brushless, geared, hub motor, 36v/10AHr 'Duct Tape' LiFePo4
Freddyflatfoot
Postby johnrobholmes » Tue Oct 28, 2008 9:14 pm
You should be able to swap two phase wires, and two sensor wires to achieve proper rotation and synch without the reverse on the controller. If you got it to work, no matter though!
A popping frequency is just that- a popping sound. When a controller is firing the motor wrong it can occasionally let out a POP when the phases un-sync and re-sync because of load changes.
Volt up, gear down!
johnrobholmes
Postby Nogwin » Tue Oct 28, 2008 10:03 pm
I just checked the controller and the key switch is at the horizontal position pointing to red mark.
When I was getting the phase wiring figured out several months ago, the combo I posted was the only one to work smooth. Others made a crazy noise and amp load was 10+A at a few mph. So the wiring I have and the key switch in that position works well. There's absolutely nothing but smooth motor accel all the way to wide open throttle. No unusual vibrations or anything like that.
I hope this helps
btw - I should mention the 66v is really good for commuting and I get good acceleration thru 30mph. At 48v I was just at 20-21mph, and needed more for safer travels. I really hope your gears survive. Also plan to pull the motor apart and photograph my gears after 2000 miles which should be in a few weeks. (I ride about 50miles round trip 5 days per week)
Nog
Nogwin
Postby voicecoils » Tue Oct 28, 2008 11:32 pm
Nogwin wrote:I just checked the controller and the key switch is at the horizontal position pointing to red mark.
I hope this helps
Nog
Sweet, yes it helps. My switch was broken when I bought it. I think "open" is forward, "connected" is reverse. Inside the controller is a little 2 pin plug that connects to the key. So in one position the key closes the connection (reverse) and the other position is open (forward). I don't know which is which regarding red/green.
It would be useful to know if others want to replicate the setup, however I'm fairly convinced now that we are running the exact same wiring. I had to use a hard drive jumper connector to jump my controller. I think docnjoj's wiring was not correct, and it matches your description and my own experience.
If the rain stops I will go try out the bike again :) If it doesn't, I might head out anyways!
66v does sound sweet. My current batteries can't do that (36v or 72v) and I do need to get some use from them before I invest in more. Your commute sounds full on. I'm very interested to see photos of your bike and the gears. If they've survived I will be quite amazed. The gap between 66v and ~80v is decent though, perhaps it made all the difference.
How do you tackle hills? Wide open throttle & peddling like mad?
voicecoils
Postby docnjoj » Wed Oct 29, 2008 6:26 am
Interesting about the jumper in the Crystalyte 20 A 36-72 volt with problems. I will take mine apart today and give a looksee! If it works, it would be great to have a real backup controller! My controller box has no switches or other proturberances of any kind, just wires coming out! Kool, voicecoils!
otherDoc
E-bike stable at our house
My wife and I ride the trikes
docnjoj
Postby voicecoils » Wed Oct 29, 2008 7:57 am
docnjoj wrote:Interesting about the jumper in the Crystalyte 20 A 36-72 volt with problems. I will take mine apart today and give a looksee! If it works, it would be great to have a real backup controller! My controller box has no switches or other proturberances of any kind, just wires coming out! Kool, voicecoils!
otherDoc
Hi Docnjoj, I don't know if yours will be the same on the inside but here's mine:
You can see the empty 2 pin socket next to the 5 wire socket and a little chip. It's called "S2" on mine. I just popped a jumper in it. Worked a charm with Nogwin's wiring. I think you'll be impressed :)
voicecoils
Postby voicecoils » Wed Oct 29, 2008 8:20 am
Ok, finally got a decent ride in, at 36v nominal. Not sure how many km I traveled total but I closely estimate ~20km. I consumed 138.7Wh according to my CA or 3.7Ah. Pack started at around 42v and resting voltage 5min after I finished my ride was 39.4v My charger took around just under an hour before going into the float/balance stage. My kill-a-watt says it drew 140Wh from the wall. I know my charger and battery are not 98.5% efficient so either the CA or kill-a-watt is slightly off.
I checked the gears afterwards, the look minty fresh and slimed up nicely with the Moly grease. Hope they stay that way!
I had a 30A fuse in line which I did not blow. The cycle analyst reported Amax = 69.3A which I do not think is correct. I did not witness higher then 22A on the CA, though I was not looking at it the whole time obviously.
At 36V I only seem to get up to around 25kph. Not very fast, though I can pedal it up a bit beyond. Once it hits max speed the current draw really drops, down to just a few amps. I can see the appeal of upping voltages now, otherwise you do hit a wall with the speed. My max speed was ~42 kph but that was going downhill. I peddled from starts and kept the amps under 10A most of the time.
The internal gear hub is great. I can be grinding out the top gear and when I come up to a stoplight I just brake, stop. Then shift down to an appropriate gear and it's ready to go on the green light. It's a great partner to the hubmotor.
I'm liking the front rack and the controller mounting. It's very convenient.
With the battery pack in a backpack (sitting on the rack when riding) I can leave the bike locked up outside. It doesn't draw much attention at all. I've got lots of wiring I haven't cut yet, so it's just coiled in the little bag on the rack. Works fine for now.
Changed from the ubolts to these rubber mounted P-clamps. They work MUCH better. I went about 15km on the u-bolts and they slid down a bit. If they had slid down more it would have wedged between the fork and the hub. That would have been a disaster.
voicecoils
Postby voicecoils » Wed Oct 29, 2008 8:28 am
The last 5 km I had my GPS with me. Here's the output of speed & elevation graphed vs distance:
I felt like I was going faster, but oh well. 36v does have limitations. I'd much prefer to be able to stay in the 30-40kph zone more of the time. I should do the trip in reverse and see how it compares.
Overall I'm quite happy. Frame feels great at speed, even fully rigid. Even with the battery weight over the front wheel. Getting the batteries in the frame will be a big step forward. 36v is fine for now. I eagerly await metal gears. I'd like torque arms, a front disc mount (and disc holes drilled in the hub) and a way to read speed with the plug in CA. Anyone know how to wire in a magnet & sensor speed pickup to the plug in CA?
voicecoils
Postby Mathurin » Wed Oct 29, 2008 3:05 pm
Damn dawg, that ride looks fat with the CETMA! Ridin' on yo new pimp throne, haterz gonna be jealous how yo bitchez riding in style.
red_rack-xlyte biatch.jpg (43.08 KiB) Viewed 1562 times
You have to know, not fear, that someday you are going to die. Until you know that and embrace that, you are useless. - Tyler Durden, Fight club. Ditch the fake identity you've created for yourself, walk your own way in a society of mindless drones to become real, you are not your social status.
Mathurin
Postby voicecoils » Wed Oct 29, 2008 4:28 pm
Mathurin wrote:Damn dawg, that ride looks fat with the CETMA! Ridin' on yo new pimp throne, haterz gonna be jealous how yo bitchez riding in style.
Hmm there are a lot of small dogs carried around in designer bags in my neck of the woods, but I don't know that I want to get down with the trend.
Maybe I need a hub motor with chrome spinners? :lol:
The CETMA rack is sweet but in hindsite I think the price is rather expensive, even as a handmade item.
voicecoils
Postby voicecoils » Fri Oct 31, 2008 3:55 am
Latest iteration:
Additions: rear rack and larger chainring (from 32t to 46t). Not pictured is my 1.7kg Kryptonite New Yorker 3000, but you can see the mount for it on the rear triangle near the seat.
Using 1/2" track chain and 1/2" track 16t freewheel + non-ramped/pinned DH chainring.
With my tire size, crank length and gearing with the Alfine hub, at a cadence of 80 rpm I have a speed range (pedal only) of 15kph to 46kph according to the Sheldon Brown Internal Gear Calculator. It's pretty much perfect if the 30km ride I did today is any indication.
Soon to try 72v again, but will limit current to 10A with the cycle analyst and a fuse. Can't afford to keep buying new gears!
See here for performance calcs: http://endless-sphere.com/forums/viewtopic.php?f=3&t=7232
Battery feels fine on the rear rack strapped down in the bag. ~5kg with the bag, fuse and wiring. I'll put the second battery on the front. Plan is to free up both racks by getting batteries into the main triangle as soon as I can. Bike is a porky ~22kg without batteries or lock, and a pain to lug up the stairs.
Easy emergency disconnect on the top tube, just yank the powerpoles :D
ignore the garbage and messy kitchen. I'm in love with velcro straps.
(167.39 KiB) Downloaded 4179 times
voicecoils
Postby pwbset » Fri Oct 31, 2008 11:15 am
voicecoils wrote:Soon to try 72v again, but will limit current to 10A with the cycle analyst and a fuse.
Probably already know this, but remember that the CA will pulse way above and below before finally settling on 10a. If you ask Justin he might be able to get you faster response adjustment settings. It's the same with the CA speed control. Still wouldn't floor it if you want to keep that last set of gears non-peanut buttery. :wink: That's a sweet looking ride. Good luck.
pwbset
Postby voicecoils » Fri Oct 31, 2008 4:46 pm
pwbset wrote:Probably already know this, but remember that the CA will pulse way above and below before finally settling on 10a. If you ask Justin he might be able to get you faster response adjustment settings. It's the same with the CA speed control. Still wouldn't floor it if you want to keep that last set of gears non-peanut buttery. :wink: That's a sweet looking ride. Good luck.
So far I've seen the current limit stay within +-0.50A, which seems like pretty reasonable control to me. If I blow the 10A fuse, I'll know it can stay above 10A for too long. But, who knows even 15A might be OK if the bike is ridden carefully or if the crystalyte controller has a smoother throttle then the 72v28A old ecrazyman controller.
Cheers for the bike complement :D
voicecoils
Postby voicecoils » Mon Nov 03, 2008 7:18 am
I've done 60-70km total now. Just checked my hubmotor again and the gears are looking alright. They've slung much of the moly grease off the teeth but haven't shredded yet.
I road ~5km today at 80V with the current limited to 10A. This lead me to realise that the CA's max speed setting of 99kph was causing the controller to cut power to the motor at around 23kph actual speed. I think the same thing was happening when I was operating at ~40v. It explains why I was getting nice assistance up hills and off the line but a piss weak top speed. I've started a thread about that here: http://endless-sphere.com/forums/viewtopic.php?f=3&t=7271
Now I'm curious to find out what my real top speed is at 40v and 80v respectively on level ground. Hopefully I can find this out tomorrow. :D
voicecoils
Postby voicecoils » Fri Nov 07, 2008 6:25 am
checked the gears again, they're fine and still greased up well.
One thing I've noticed with 3 gear assembly is that it is not fixed in position with relation to the ring gear. In other words, it can wobble around and therefore no longer mesh with the ring gear on the same parallel plane. If that makes sense. One would hope, that when the motor is bolted together that everything is held in place nice and straight and tight, but there may be wiggle room to go out of alignment, who knows...
I've made three youtube videos. The first shows the motor only (no gears or freewheel mechanism) in my dropouts. Hubmotor case/wheel and gears can be seen in the background. First I throttle up the motor at ~40v, this consumes 24W and registers as 33.3 kph on the cycle analyst. Using the 1666mm wheel diameter trick programed into the CA (which outputs speed in kph as 10s of RPMs) that gives an 1100-1110 RPM wide open throttle (WOT). Then in the same clip, I add a second pack in parallel for ~80W. It shows 75W power, 65.7kph, and 2210-2220 RPM. In both cases the motor sounds quite nice and smooth to me. With no mechanical reduction this is the best (quietest) the bafang will sound like:
High Quality here: http://www.youtube.com/watch?v=6fdxLmGQGEU&fmt=18
Ok, next up 40v in the wheel. First I throttle up and then down very slowly and smoothly. Then I go straight to WOT and dump it back to zero. Listen to the mechanical sounding clunking. I suggest you stop the video at 1:55. My girlfriend suggests it's blindingly boring to watch :wink: you may agree:
High Quality here: http://www.youtube.com/watch?v=V3yQi2DxZq0&fmt=18
Lastly, 80v in the wheel. Same tests as above.
High Quality here: http://www.youtube.com/watch?v=mwTkL1QPM9I&fmt=18
Although the wheel wobbles a bit in the video, it's extremely close to dead true. I had a bike shop true it on their truing stand and with the bike upside down in the and looking at the rim passing through the brakes side to side and up-down movement is very very small.
I'm curious about the mechanical clunking. Gears, freewheel? I'd like the motor as quiet as possible. I'm tempted to pack it with more grease but I don't want too much slinging into the motor windings.
voicecoils
Postby shinyballs » Sat Nov 08, 2008 1:08 am
Cooool video! especially at 80v... Your center frame triangle is begging for batteries.
shinyballs
Postby voicecoils » Sat Nov 08, 2008 1:33 am
shinyballs wrote:Cooool video! especially at 80v... Your center frame triangle is begging for batteries.
Cheers. I agree completely about the main triangle. At the start of december I'll have more free time and will be attacking both bikes full bore. Can't wait!
I've noticed the motor/gears really only sounds happy when they're going full bore WOT and not being stressed. So at ~40V this happens between 20-25 kph on gentle hills, 24-27kph on the flats, and 25-30kph on gentle down hills (all with light peddling). I have to moderate my peddling to keep the motor in the "sweet spot" while WOT. It starts whining below which is not stealthy and sounds crap IMO and if I peddle past the "sweet spot" then power levels drop under 100W and the motor can't spin fast enough to do useful work.
voicecoils
Postby rguy56 » Sat Nov 08, 2008 2:06 am
Your wheel can be perfectly true, but bike tires are rarely, if ever, perfect. Honestly, I think that's the reason for the oscillation.
I'm a fanatic for a true wheel, and I see that same effect. Some tires are "truly awful". Yuk-yuk.
Bob
rguy56
PreviousNext
Who is online
Users browsing this forum: AussieJester, boo, DanGT86, Sunnyboy and 7 guests
