Hello,
i am going to do a fullsuspension Frame which can fit 48 pcs 38120 Cells, 5000w hub motor and enough place for all possible controllers.
material: AlMgSi0,5 150x18x2mm profile
this is the first layout of the frame
this is the frame on the down position of the suspension
front suspension 200mm
rear suspension 200mm with 190x50mm damper
Frame will be welded, 2 sideplates with screws so you can get inside to every part.
this is my first frame so please if you have any hints or known problems i will have tell me before
BR Michael
BR Michael
