snowranger
Here are some pics of my latest ride. As my kids are getting bigger, I was finding it difficult to make that final hill to school. With BBS02 and the Nuvinci Developer kit, all I need to do is pedal and brake. I can go as slow as I want up a hill, yet it is also scary how fast this thing can go.
I am using a 20t sprocket and have set the Nuvinci cadence to 80 RPM. The Nuvinci controller and 48-12volt dc-dc converter are hidden under the top deck.
For the battery case, I used a super heavy duty electrical enclosure box ground down to shape. A 14s 20 ah Li pack fits perfectly in the space between the chain and pedals.
After a little over 2200 miles, the the Nuvinci 171 has been retired. The hub still worked but sounded like it had gravel in it. Also, spare parts for the obsolete developer's kit were hard to come by.
Over the past couple weeks, I converted the drive train to an 8-speed derailleur system. On the front is a 37 or 38 t chainring mounted to the 104 bcd adapter.
Since this is a Yuba Mundo, the rear dropouts are 14mm and horizontal. As a result, motor chain power pulls the right side of the wheel forward. Even using aggressive washers did not help at all. Finally, I pinned the axle into the dropout using a metal plate and 2 bolts.
The bike definitely performs better than before in terms of acceleration and top speed. I am using throttle control but not PAS in order to decrease dead time between gear changes. The brake cutout button is too slow, and the throttle control circuit (ala Kepler) does not seem to work on my setup.
Overall, the bike is much lighter now and more responsive. I like it.
