....So I went oldskool with a pen, paper and a cardboard box![]()
"old school" CAD ....Cardboard Aided Design. !
heathyoung wrote:Looking at the topology they are buck - so non-isolated, and input voltage must be higher than output voltage.
Server supplies aren't usually current limited like you would hope, they are usually hiccup unfortunatly.
Hyena wrote:LOL, I used the latest cardboard vers....
Bulk BULK charging will be done with 2 server power supplies, put in series to charge 6S parallel groups at 50 amps. ooft![]()
That'll charge my 18S2P (10ah) packs at nearly 2C and the 18ah pack in my stealth fighter at 1C. Noice.
icecube57 wrote: It seems like the dc to dc does the current limiting 60v 5A and you can dial in the current limit so its only draw what it needs and it shouldnt overload a server psu 60vx5A plust overhead isnt alot of watts..
heathyoung wrote: I have a box full of server power supplies (about 14KW worthincluding those HP supplies.
Easiest way is to make up a current mode buck converter - with a whopping great inductor and a bank of mosfets - As long as your supplies are the right input voltage to charge your cells
heathyoung wrote:I'll swap you a working server PSU if you would like for the dead 400W charger, it will be interesting to do a reverse engineer of these. What model was it?
I'll give the constant current circuit some more thought - the P channel FET is useful in this configuration as it will just pass when your input voltage = output voltage.
heathyoung wrote:Well, that's not too bad then, an LM317 and some pass transistors could do it - I had a pair of coherent Argon-Ion laser supplies that ran some show lasers that used a linear reg (!!) - Boy did that get hot (never mind the tube - the water-cooled ones ran so much quieter)
Users browsing this forum: 317537, acorless, andreym, Bing [Bot], bowlofsalad, mark5, mushymelon, Observator, snellemin, Whiplash and 17 guests
