HP ESP120 48V (51.4V) 57A 3KW Server Supply Thread
Re: HP ESP120 48V (51.4V) 57A 3KW Server Supply Thread
Postby ZOMGVTEK » Sun Nov 06, 2011 11:21 pm
I only used that connector on the ESP120, since I wasn't sure what I wanted to do with it. For the ESP135's I bent the pins together and soldered them. No need for a plug, why would I want to turn it off? I just plug it in when I want it on, an its on. To turn it off, you remove the power plug...
Here is what they look like...
I just bent the 3 pins together, lightly soldered them, and covered it in glue.
ZOMGVTEK
Postby Kin » Sat Aug 25, 2012 6:31 pm
It sounds very foolish, but I can't find a datasheet on this. So i'm not sure how to interpret the lights on the front.
When I short the three pins to activate "on" I get the green power light to be on, but I have a blinking yellow information triangle light. When I don't short them, I have a blinking green light.
In neither case do I get DC output.
Anyone know what's going on? This refers to the ESP120 (51.4v 57A), running off 208VAC (don't ask me, I don't understand how phase 1 is 110v and phase two is 112v and we get 208v when we combine them. But thats because I don't understand the basics of real-word electricals.)
Edit: I found the short datasheet again, http://www.rcgroups.com/forums/showthread.php?t=1625284, but didn't find useful information about the lights in it.
New to endless-sphere? Notice a lot of signatures recommending Ebike.ca? That's because it's the best place for a quality and manageable, (but still 'real'), first build. Justin is a solid supporter of electric bike development, and a good source of equipment.
My hat off a thousand times to the green people that effectively run this forum. The ES Mods are superb.
Kin
Postby hillzofvalp » Sat Aug 25, 2012 10:34 pm
I wish Luke would chime in on his efforts with this thing..
check out this guy:
http://www.ebay.com/itm/HP-74840-001-Po ... 320wt_1299
hillzofvalp
Postby Kin » Tue Aug 28, 2012 12:17 pm
That ebay one looks like just 6 of these in a case? I suppose that is itself kind of interesting.
I'm wondering if anyone has useful information about the yellow information triangle dot led on the front. I really wish I could understand why mine isn't putting out DC output. There's a marked high pitch change in the PS when I short the three pins, and the yellow triangle led starts blinking. So at some step things are being repressed, I just wonder which. Something is happening, though.
I might fiddle around a bit more. I'm not really getting anywhere though, my german isn't good enough to read the only source that seems to have deeply analyzed this PS (There's a google group from a german group that did a lot of work with this...even building a board that automatically shuts it off at a certain voltage [for charging RC batteries] and it adjusts the voltage. Several ES members were talking about doing that and if someone could just figure out what the german guys did, it might save a lot of work.)
Kin
Postby Kin » Tue Sep 04, 2012 1:02 pm
I'm not sure if I should be reposting what I posted to another thread, but this would be the more on-topic location to post it, although it was my secondary location I thought of.
Anyway, I thought I would post two links from the german guys who worked on the ESP120.
Essentially they made a holy grail system for the ESP120....28v-60v, 0-57A....That's pretty awesome, even if the accuracy is only rough.
http://translate.google.com/translate?h ... md%3Dimvns
http://www.lifepohandel.de/epages/63129 ... %20V2.2%22
Kin
Postby hillzofvalp » Tue Sep 04, 2012 6:26 pm
that is super interesting.. I want to put a pair of these on my motorcycle for 1/2 hour recharges. Let me know when you actually get two working in series! :)
hillzofvalp
Postby hillzofvalp » Tue Jun 04, 2013 7:15 pm
I just found a thread on lowering the voltage down to like 44V if needed. I think a digital pot, shutn and arduino would easily make this work well. Thinking about buying a couple since they are so cheap.
http://www.rcgroups.com/forums/showthread.php?t=1823759
hillzofvalp
Previous
Return to E-Vehicles General Discussion
Who is online
Users browsing this forum: No registered users and 3 guests
