Molicel IMR-26700A/AB
Got something to sell? Have extra parts that need a good home? Have something that others would need to complete their kits? Post it up here and see if anyone else is searching for what you are selling. Guest may post replies to topics already here. All topics here will expire after 90 days of inactivity.
Re: Molicel IMR-26700A/AB
Postby methods » Fri Sep 23, 2011 12:33 pm
That is pretty standard.... The Hobby City Lipo is good for about 250 cycles IIRC. What is important is how they rate the life. Could be the point where it only has 90% capacity, or 70%... It is not like they work 300 times and then just die :-)
Ignorance is pretty much bliss and I think you will find that most people have no idea how many cycles their cells are rated at.
Cycles are also misleading... a cycle is a hard swing from HVC to LVC to HVC. That will cause much more wear and tear than a reasonable ride from 4.0V to 3.3V to 4.0V. Only a tard cycles their cells down to LVC. By short cycling your cells last forever - I am still running the original white-shrink hobby city cells I bought for my first electric scooter years ago.
-methods
Jozzer wrote:Your already the guy to go to for the guys that other guys go to..
I sell stuff.... like little morsels of my integrity @ http://www.MethodsTechnology.com
methods
Postby SlyCayer » Sun Sep 25, 2011 10:12 pm
Tests...
As of now, it's not looking too good...
I just did a test on 2 cells separately 4 times:
Cell 1 at 1C: 1.05Ah, 1.06Ah, 1.15Ah and 1.01Ah.
Cell 2 at 1C: 1.69Ah, 1.65Ah, 1.65Ah and 1.65Ah.
At least I can say they are constant with the Ah... These cells we're from one battery so please let me open more and test the cells out of other batteries.
I will also change my testing method. I am currently using a "high resistance" way of testing them with long small wires between the tester and the cells...
I will shorten the wires to bare minimum and see if it makes a difference.
http://www.JCCayer.com Where you can find tools and Dewalt(A123) batteries.
SlyCayer
Postby liveforphysics » Sun Sep 25, 2011 10:32 pm
SlyCayer wrote:Tests...
Definately need to 4 wire it. Or use as short and fat of wires as you can.
For ebike parts, don't be a douche, buy from http://www.ebikes.ca or http://www.MethTek.com
Justin saved the forum at great personal expense! The man is a legend and a hero!
liveforphysics
Postby SamTexas » Mon Sep 26, 2011 7:25 am
SlyCayer wrote:Cell 1 at 1C: 1.05Ah, 1.06Ah, 1.15Ah and 1.01Ah.
1) At what voltage did you terminate the test? What was the cells' voltage after 5 mins rest? For laptop LiCo cells, I terminate the test at 2.50V. After 5 mins rest, the cells' voltage recovered to about 3.50V.
2) What were the cells' voltage at the beginning of the test? I charge the laptop LiCo cells to 4.20V before testing.
SlyCayer wrote:I will also change my testing method. I am currently using a "high resistance" way of testing them with long small wires between the tester and the cells...
It will make a difference, but not a big one for sure. You were testing only one cell at the time. At 1C, the current is only 1.0A and 1.7A respectively, so the wires' size and length matter only a little.
But these are high discharge cells, so I think most people are interested in 4C and up discharge tests. For 1C, people would be much better off with laptop LiCo cells which have much higher energy density.
SamTexas
Postby SlyCayer » Tue Sep 27, 2011 4:45 pm
SamTexas wrote:1) At what voltage did you terminate the test?
2.8V
SamTexas wrote:What was the cells' voltage after 5 mins rest?
back to 3.7V
SamTexas wrote:2) What were the cells' voltage at the beginning of the test? I charge the laptop LiCo cells to 4.20V before testing.
4.2V-4.3V
SamTexas wrote:It will make a difference, but not a big one for sure. You were testing only one cell at the time. At 1C, the current is only 1.0A and 1.7A respectively, so the wires' size and length matter only a little.
You are 100% right it didn't change anything, reran a test with Cell number 2 and got 1.71Ah which is still FAR from 2.9Ah.
I will be running further tests on multiple cells from multiple packs and let you guys know.
I do all of this for the fun of testing and find out more interesting stuff...
I will be testing Milwaukee's M18 cells(Red-Lithium) which are supposedly a lot better.
SlyCayer
Postby cassschr1 » Tue Sep 27, 2011 5:02 pm
Red lithium ,hum, do you mean 18650 cells or 26700, 18650 red is probably sanyo and the only 26700 I've seen are a brown or white cardboard. Hope your testing gets better capacity than the three hundred I tested
cassschr1
Postby gblast123 » Tue Sep 27, 2011 7:39 pm
I believe that they are the 18650 W2 cells from Sanyo. They have something like a 5c or 10c discharge rate and are 1.5Ah.
Pretty hardy cells.. they are being used in the Ridgid tool line.
gblast123
Postby liveforphysics » Tue Sep 27, 2011 7:45 pm
Whoa! Hopefully you just happened to have picked some duds from the bunch when you tested? Or did you test a bunch and got dud results?
Methods and I both have over 1,000 of these moli-cel 26700 LiMn cells in new condition that do test over 2.5Ah. I personally don't sell things like that, only give it away to folks who do things that impress me.
Methods sells his I believe though.
liveforphysics
Postby nebriancent » Tue Sep 27, 2011 8:05 pm
you think i could impress you by taking my bike into a large steel cable deck mount on a car bridge at over 60k and only damaging my ca and front rim(besides my pride and body) :P j/k
so how many cycles do you think we would get at a much more conservative charge and discharge on the cells??
if at first you don't succeed...dont force it just grab a bigger hammer
back to my gm 901 for now 26"
modified infineon ebikes.ca 40-100a 36-72v controller w/ cruise http://endless-sphere.com/forums/viewtopic.php?f=2&t=37068
4s 14p liMn (doc makita pack) and headway 2p 10s in serries
cycle anylist 2.3
top end on flat is about 48kmh hot off the charge
range >40km
best distance in a single charge about 75km
xvision front light. led marker light rear w/ limiting resistor for tail/stop operation
nebriancent
Postby liveforphysics » Tue Sep 27, 2011 8:45 pm
nebriancent wrote:you think i could impress you by taking my bike into a large steel cable deck mount on a car bridge at over 60k and only damaging my ca and front rim(besides my pride and body) :P j/k
If you get it on video so I can enjoy it, I would totally dish out cells for that. :-) Watching ebike parts explode into plasma, watching batteries burn on bikes in public, watching human bodies thrown from ebikes cartwheel and flip and slide and tumble, etc. Those are all the things on here I like to see. :-)
I mailed off a premium 1.3kw-hr ebike battery this week all ready for free to a very deserving awesome person on this forum. :-)
liveforphysics
Postby nebriancent » Wed Sep 28, 2011 12:04 pm
no video plasma or fire just a lot of bent and broken parts in the front end
**edit the thing that realy impressed me was the bike still turned on, spun up, lights all still work, and after folding the front rim in half i didnt get a flat or kill my shocks:)
already fixed - front rim, CA, front brakes, wiring to CA,
had to make a hole new bottom end for my CA
i used some extra plate at work last night and made a mounting point out of a few nuts and a couple of bolts
but... now im geting a dead line thru the ca i meen it all works just one line in the display dosnt function
eg
xxxxxxxxxxxxxxxxxxxxxxxxxxx
any ideas on what it could be...
mabee just a bad connection to the lcd board in one part or somthing???
cycle anylist 2.3
range >40km
nebriancent
Postby beast775 » Wed Sep 28, 2011 12:05 pm
damn it! i just had my front fender brace lock up my front wheel,i need a vid cam.thats awesome to hear LFP :) .
new build started.
I spent all my money on bicycles women and beer the rest i just wasted.
ebikes.ca
beast775
Postby heathyoung » Wed Sep 28, 2011 6:34 pm
A dead line on the LCD is caused by the rubber strip between the LCD glass and the circuit board underneath it. These are crimped at the rear (the metal 'tangs' onto the PCB) - sometimes moving these fixes the issue, otherwise the LCD is a standard 16X2 unit.
New evil decided - GNG offroad build on Craftworks DHR with 12S4P lipo. Aim - Light, balanced, powerful, able to climb a tree.
Project Vectrix restarted. Status - BMS + Charge control redesign (read faffing with batteries again)
heathyoung
Postby cassschr1 » Wed Sep 28, 2011 9:20 pm
Luke, in testing those cells about the highest was 2050 ma with most at 1300 to 1700, and a whole lot of just dead ones. At one point I had taken apart 40 milwaukee V28 packs and every f.....g cell was bad. Ridgid 24v were better. Both have the same BMS manufacturer. I built four packs of moli 12s4p with every cell tested by itself , 192 cells . This is all on one TF on the top tube. I wish my cells delivered 2.5 ah
cassschr1
Postby SlyCayer » Wed Sep 28, 2011 9:22 pm
P.S: Milwaukee M18 Red-Lithiums are not Sanyo, they are Samsung INR18650-15M
I will be performing tests on these to see the max discharge current.
SlyCayer
Postby nebriancent » Thu Sep 29, 2011 11:53 am
heathyoung wrote:A dead line on the LCD is caused by the rubber strip between the LCD glass and the circuit board underneath it. These are crimped at the rear (the metal 'tangs' onto the PCB) - sometimes moving these fixes the issue, otherwise the LCD is a standard 16X2 unit.
thanks i was thinking that the rubber sh%# might be the problem
ill have to give that a try on the weekend as i have sealed my unit of w/ silicon and don't feel like going through the bother till then
cycle anylist 2.3
range >40km
nebriancent
Postby methods » Thu Sep 29, 2011 5:41 pm
liveforphysics wrote:....
That is because I am a money grubbing energy whore. :wink:
-methods
methods
Postby SlyCayer » Thu Sep 29, 2011 6:03 pm
methods wrote:That is because I am a money grubbing energy whore. :wink:
LoL
SlyCayer
Postby SlyCayer » Thu Sep 29, 2011 8:04 pm
Took about half of the cells out of packs...
SlyCayer
Postby Kin » Thu Sep 29, 2011 8:47 pm
Woah, four screen work station?
New to endless-sphere? Notice a lot of signatures recommending Ebike.ca? That's because it's the best place for a quality and manageable, (but still 'real'), first build. Justin is a solid supporter of electric bike development, and a good source of equipment.
My hat off a thousand times to the green people that effectively run this forum. The ES Mods are superb.
Kin
Postby SlyCayer » Fri Sep 30, 2011 5:51 pm
Kin wrote:Woah, four screen work station?
Yeh, I might have 4 more coming that will be 2 high by 4 wide.
SlyCayer
Postby SlyCayer » Sat Oct 01, 2011 10:54 pm
Alright,
Test Cell 3 and 4 choosen very randomly scored a high 2.09 and 2.15Ah at 1C.
Is it possible that at like 7C the battery can't just take it?
The test went on for only like 2 seconds??
SlyCayer
Postby SamTexas » Sun Oct 02, 2011 12:17 am
7C is 20.3A per cell, right?
That's only half of the maximum 40A claimed rate. Disappointing for sure but not totally surprising considering the common practice of over advertising. So do you plan to continue testing at lower rate? 5C, 4C...
I wonder if people who bought HK super duper high discharge RC Lipo batteries (50-100C) have ever actually done any testing at all.
Edit: I just went back to look at the discharge graph in the data sheet you provided:
They did have discharge data at 20A (red) and 30A (black), and the capacity is only about 15% less than 3A discharge. So it looks like you have problem with the test equipment.
SamTexas
Postby methods » Sun Oct 02, 2011 1:02 am
Emoli cells are good to about 3C in the real world. If you want high discharge then buy Lipo.
-methods
methods
Postby liveforphysics » Sun Oct 02, 2011 1:23 am
methods wrote:Emoli cells are good to about 3C in the real world. If you want high discharge then buy Lipo.
-methods
+1
The datasheets on these cells were written by a dreamer.
liveforphysics
Next
Return to Items for Sale - Used
Who is online
Users browsing this forum: No registered users and 3 guests
