-- Edit: i've requested this post be moved to USED section. my bad... --
$75 + shipping.
- old style 9x7 9c
- vented rounded side covers, one side damaged but operational, rim brake compatible (or request unvented side covers)
- upgraded w/ 12g phase wires, silicon wire, 4mm male bullet connectors
- upgraded w/ lm35 hobby king temp sensor, jbwelded to stator, but will need connector, and wire extension if you run to handlebars.
history: it was brand new and laced in motorcycle wheel when i got it. but then i braked too hard in dirt and snapped the threaded disc mount off.
so you can either run it as is with vented side covers after you lace it into a wheel with rim brakes, or i can put two unvented side covers on from the other 9x7 9C i'm about to sell and use another threaded disc. i can sell a disc mount for $10 extra.
