Common high current connectors - and my opinion on them
A place to list links to retailers that sell EV related parts.
Re: Common high current connectors - and my opinion on them
Postby fechter » Tue Oct 28, 2008 3:15 pm
fechter
Postby Ypedal » Tue Oct 28, 2008 4:54 pm
In canada.. i get my andersons from this place:
http://www.rosspar.com/
ES site status page, for when "things" happen...
Always Staying Busy !!
http://www.ypedal.com/Projects.htm
Ypedal
Postby snowranger » Tue Oct 28, 2008 5:00 pm
What makes the mail order andersons expensive is the shipping. Here's a place that has good prices and low shipping. I just bought my last set from here.
http://www.alt-moto.com/
Electric: 400 watt BMC Hub Motor w/disc brake/Infineon 48V 30A controller/Dead 48V 20Ah Ping replaced with Headway 48V20ah
Bike : Generic mountain with xtracycle long tail
Accessories: homemade led lighting, 48V horn
Miles: 13,000 miles, 8,000 on the headway and counting.
http://www.ebikecommuter.com
snowranger
Postby sparky » Fri Nov 07, 2008 11:57 am
Thanks for the resources. Is there any trick in assembling the Andersons? I just got a baggie full of them from ebikes.ca with no instructions.
I'm thinking you just crimp/solder them then stick them in...the crimp tabs seem polarized (blade is cupped). Any trick to sticking them in right?
sparky
Postby Ypedal » Fri Nov 07, 2008 12:03 pm
with bigger gauge wire they just snap in.. but with thinner stuff you can use a small jewlers screwdriver or something similar to push the trip into the housings.. i made a picture thread of this a while ago... will try to dig it up
Ypedal
Postby Zoot Katz » Fri Nov 07, 2008 12:29 pm
Pictures and tips for assembling Anderson Powerpole connectors:
http://www.westmountainradio.com/supportrr.htm
Zoot Katz
Postby sparky » Fri Nov 07, 2008 1:40 pm
Zoot Katz wrote:Pictures and tips for assembling Anderson Powerpole connectors:
Thanks Ypedal and zootkatz!... link in particular is very helpful. Looks like it'll only "snap in" one way...this is good!
sparky
Postby LI-ghtcycle » Thu Oct 22, 2009 1:08 pm
****COUGH!!!!!!! COUGH!!!!!!!!!****
I know this is a dusty old thread, but I have a couple of Q's :)
First off, connectors:
One thing I didn't see addressed, is weather (particularly rain) resistance. I don't like to ride in the rain, but I live where rain is almost always a possibility, most any time of the year. I found some plugs at the local hardware store sold for use with power sprayers (pesticides) so I don't know what to call these or what they could be rated to handle (14G wire), but, the plugs that are 2 wire yet similar to the 4 wire trailer in that it is rubber, polarized, and I think, weather resistant.
Are any of the connectors listed on this post designed with weather (particularly water) resistance in mind?
Also, I am very curious about the parallel resister pre-charging circuit. Is this circuit still necessary with an adequate switch between the battery and the connector?
I understand that the switch takes the brunt in this situation, so maybe a relay is more practical?
I have only been using an Amped Bikes DD rear hub kit in it's nominal 36v power, and my next kit I plan to run 56v, so I am looking into what I will need to up-grade.
Another question (hope it's not too far OT hehe) is, if I up the voltage, yet stay low in AH's, will that be easier on the system? I'm sure a lot of these Q's can be answered with a better understanding of basic electrical theory, but I am afraid many of you have forgotten more than I have ever known, so until I am able to take some courses, I'm relying on your exceptional knowledge and patience. :idea: :wink:
Thank you Justin_Le for your selfless act of kindness! We all are in your debt.
My latest build: Vision R40 with Golden Motor "800W" Trike motor as mid-drive, NuVinci N171B rear wheel as transmission, 30 MPH on 12S (46V) 12 AH Turnigy Nanotech LiPo (25-50c) able to climb tall hills on a single Amp Hour! :grin:
http://www.endless-sphere.com/forums/viewtopic.php?f=3&t=29810&p=475990#p475990
LI-ghtcycle
1.21 GW
1.21 GW
Postby jateureka » Wed Apr 07, 2010 8:57 pm
I have seen Molex and bullet crimp connectors on a 36V 15A controller feeding a 250W motor that had melted and fused together.
This thread also shows the down side of using 'bullet' connectors, but I think they are actually banana connectors.(you need to scroll dwn the page a bit to see the photo)
viewtopic.php?f=6&t=15192&start=75
Re: Metallover's 9c Blackcomb Build
by Metallover » Sat Mar 27, 2010 12:30 pm
... I am about done with my Bullet Plugs. The last short I had to open up one of my zippies and re-solder one of the tabs. It was blown apart. This new short today is the one that sent me over the edge.
Bafang; Mac; Ezee; Easy2Ride; PowerPed; Nope; Condor; Aprilia; eLation V2; Razor
jateureka
Postby ZOMGVTEK » Thu Oct 07, 2010 9:49 am
I have a pair of Power Poles with a 1K resistor in line that I connect first, then a second pair that I connect a few seconds later...
It mostly eliminates the massive POP when I connect the battery, and keeps the contacts clean.
Im only using the standard little 45A? PP's, but they dont have a issue at all with 60A running through them. The wire is warmer than the contacts.
ZOMGVTEK
Postby Farfle » Sun Oct 10, 2010 1:30 pm
I have been using these bullets on all my connections both motor/controller and phase wires. They can take quite a bit of current, as 10 GA wire gets hotter than they do. And for the price you can have either 1 set of Andersons, or 10 pairs of these. plus they come with really good heat shrink :D
http://www.dealextreme.com/details.dx/sku.41134
The race bike:
24s5p 50c nano tech
Badass custom mofo outrunner 205x177mm 26kv
Peak power in : 318A at 91v
Peak power out: 24 Hp and 151ft/lb
Build to last...
"It will be assaulted by the elements, It will be ravaged by time and it will be destroyed by the user. BUT, if you Stick to the little rules: K.I.S.S., Overbuild everything, and test, review, revise, repeat. It will last"
Team Farfle blog!! http://www.farfleselectrics.blogspot.com
Farfle
Postby Kin » Tue Nov 15, 2011 8:07 pm
Any comments on the XT60 connectors? I got a bunch because it seemed like a good idea at the time.
New to endless-sphere? Notice a lot of signatures recommending Ebike.ca? That's because it's the best place for a quality and manageable, (but still 'real'), first build. Justin is a solid supporter of electric bike development, and a good source of equipment.
My hat off a thousand times to the green people that effectively run this forum. The ES Mods are superb.
Kin
Postby itchynackers » Tue Nov 15, 2011 9:04 pm
I love em. I haven't pushed the amperage limit on them, but they take many many connect/disconnect cycles and don't wear. They are very durable, and fairly easy to solder. In my opinion, they are leagues better than problem prone andersons.
9c 9x7f w/ 12awg phases
9c 8x8r w/ 10awg phases, temp sensor, vented
9c 6x10r w/ 10awg phases, temp sensor, liquid cooled, 3rd Place Pikes Peak 2012!
"Don't argue with the galactically stupid...they drag you down to their level and beat you with experience"
itchynackers
Postby nonlineartom » Tue Nov 29, 2011 8:03 am
What are people commonly using for X5 motors being pushed hard? My X5 is still running standard PP45's but I'm feeding it more than 45 amps, do you go to 6mm bullets?
Commuter bike: 10T MAC Schwinn Panther Beach Cruiser on 12S LiPo, super stealth hill eater
Forest trail eater: Crystalyte 5306 KMX Viper with 24" wheel. 100A controller 18S LiPo
Pocket rocket: 8T MAC e-BMX 18s LiPo. Missile for testing to destruction
Summer ride: 8T MAC Kona Joe MTB / chopper / beach cruiser hybrid bike. 24" wheels and a lot lot of style.
Respect and fear the ancient god LiPo and pray he is merciful.
nonlineartom
Postby Farfle » Mon Dec 05, 2011 12:34 pm
the HK 4mm bullets like these run great on a 130A 100v setup:
http://www.hobbyking.com/hobbyking/stor ... _set_.html
The race bike:
24s5p 50c nano tech
Build to last...
Farfle
Postby wojtek » Tue Dec 06, 2011 4:52 pm
I am now using XT150 all over :) they rule! and come with great housing - in different colours. Perfect for phase wires.
They can take a lot of amps, more than 4mm connectors by far.
WIRES AND CONNECTORS
viewtopic.php?f=31&t=30176
http://endless-sphere.com/forums/viewto ... 31&t=32244
http://endless-sphere.com/forums/viewto ... 31&t=32152
Go-One Evo tested with HS3540, now working on Cromotor
BATMOBILE - Astro 3220 / Nuvinci in progress
Velokraft e-VK3 / Max speed 90km/h downhill - EVKA [for sale]
Steintrike Mungo Sport HS3540-SOLD
Scorpion FS HS3540-SOLD
Kona Dawg BMC v2-SOLD
wojtek
Postby wojtek » Tue Dec 06, 2011 4:54 pm
Farfle wrote:I have been using these bullets on all my connections both motor/controller and phase wires. They can take quite a bit of current, as 10 GA wire gets hotter than they do. And for the price you can have either 1 set of Andersons, or 10 pairs of these. plus they come with really good heat shrink :D
I have them too. They are smaller than XT150. But it is good to get them with the plastic housing [available in red only] instead of heat shrinks...
If anyone needs 4mm / 5.5 / XT150 / 6mm - i have plenty of spares to get rid of.
wojtek
Postby moonshine » Mon Jun 11, 2012 5:25 pm
Awesome post. I guess i may have gone overboard with using 75a andersons on pretty much everything. phases...(motor/controller) and all on my battery packs. lipo pack(4mm bullets) to a parallel harness that has 75a andersons. I will say this....when you have 5 rows of 75a andersons...don't even THINK ABOUT SLIDING THEM TOGETHER. if you do, you're never gonna get them apart again. As in, the andersons have those slots for connecting to each other. even two rows of andersons (4x4 pattern) are borderline impossible to take apart. I have cut myself multiple times..Looking to change my setup now. maybe 6mm bullets? dunno..
03 Giant DH comp w/ 05 swingarm, cromotor in 26" large marge, Kelly KBL96251, 24s4p
Build Thread: viewtopic.php?f=6&t=40031
moonshine
Postby amberwolf » Tue Jun 12, 2012 1:37 am
Actually they can be easy to take apart. Set the row that slides back toward the wire face down on the edge of a table or something, with the row that slides forward away from the wire overhanging the edge. Press down on the back of that row with the edge of a hardcover book or block of wood or something similar that gives you a good handgrip to press against, then push down to slide them off.
You may have to use a second book or block against the opposing edge of the ones supported on the table, to hold them in place during the sliding of the others.
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Previous
Return to Resources & EV Related Parts
Users browsing this forum: No registered users and 0 guests
