Some advices to STORE YOUR BATTERY for the winter period
Doctorbass
Quebec, Canada East
For some of us, the winter season is at our doors and some of us will store theor ebike for few months,
I though that it could be good for you to know some great advices about this and you lithium ion battery.
That mostly concern peoples that store their bike for couples of months for that cold season.
I'm sure that many of us already heard that keeping a battery fully charged will help to keep it's long life and prevent loosing capacity and other dammages. This is particularrly thru with SLA and most of the NiCad battery.
But!.. for the lithium this is something different!!
Lithium cells will not lose the same amount of charge like sla and nicad do.
Here is what is HIGHLY remommanded:
0-Avoid to keep them at 4.20V or 3.7V(LiFePO4) for a long period and in a warm or hot environment!!
1-Store your battery to around 40-50%state of charge (generally it's equivalent to 3.7-3.8V per cells for the normal 4.2V 100%soc lithium for the A123 / LiFePO4 is different and it's 3.05-3.10V
2- Store them in a cold area. Usually around 15 degreeC is perfect but below 25 degreeC and above freezing point.
3-If stored for more than one years.. (it's a rare situation for us i guess...) One a year, fully charge them to 4.2V or 3.7V(for LiFePO4) and then discharge them to their storage voltage mintionned above.
4- Ensure that they will never go below 2.5V during this period.
Here is some references about that: http://www.batteryuniversity.com/parttwo-34.htm
Doc
nice aid!
crap.. this means i have to burn sum ah in my house to bring the voltages down lol .. or bring the bike for a nice run. :D
-steveo
What happens when the Li cells are stored fully charged?
Their life will be shortened.
Hmmmmm... I wonder by what percentage for both cycle life and calendar life. I imagine that storing it fully charged may reduce its calendar life by 20-50%, but if it's used 200 cycles a year and it would have had a 1000 cycle life otherwise but instead now has a 900 cycle life, then that's only a 10% reduction in the cycle life. Surely there's some mathematical relationship between cycle life and calendar life degradation.
If you CAREFULLY read the link to the battery university that i posted on top, you will find this:
Figure 1: Permanent capacity loss of lithium-ion as a function of temperature and charge level.
High charge levels and elevated temperatures hasten permanent capacity loss. Improvements in chemistry have increased the storage performance of lithium-ion batteries
and another important thing to remember about laptop!!:
The worst condition is keeping a fully charged battery at elevated temperatures, which is the case with running laptop batteries. If used on main power, the battery inside a laptop will only last for 12-18 months.
Doc
I saw the relationship for calendar life but not for cycle life, and a battery's "cycle life" and "calendar life" is not a 1-to-1 correspondence. Since I have a feeling many of the ping users are going to deplete their battery capacity by cycle use rather than desuetude, this is kind of an important thing to know.
Good info, Doc!
These numbers are for Lithium cobalt cells, right? LiFePO4 will have less loss of capacity (in percentage)than LiCo, but the 100% charged vs 40% charged capacity loss ratio should still be similar, right? What this also means is that avoiding charging your batt to 100% will extend it's life, as long as balancing is done once in a while.
Oh boy... one more potentialy very interesting long-term test to be added to the "cell testing wishlist"! :shock:
is this apply to lifepo4 too?
ZapPat said:
Good info, Doc!
The principle is the same for the liFePO4 but the effect is less important on them. I have no numbers to give and they are difficult to find between these two kind lithium cells.
The principle always concern the INTERNAL heat of the cell AND the chemical reaction coming from the high voltage state for long period storage.
These are the main cause of stress that lithium cells have.
Most of people think it's high current is the cause... but this is secondary effect only.. cause high current will create HEAT if the cell have high internal resistance. and high resistance occur also when cells havelost capacity over calandar life.. andalso when approaching low or high voltage cutoff..
Doc
Excellent advice. Another thing to keep in mind is that any attached device - such as a charger or DC converter may have a slight amp draw. Over time it can be enough to ruin a battery. If in doubt it's best to disconnect them entirely!
z.
If LiIon batteries deteriorate more slowly when half charged, then wouldn't it be better to delay charging until the battery is needed, even if only overnight? And wouldn't a slower charge be better, since the battery would spend more time at less than full? A slow charge would mean a lower temperature and be easier on the BMS too. How about a smart controller that lets you set when you need the battery next, and it figures out the best parameters for battery life, and delivers a fully charged battery just in time?
dak664 said:
If LiIon batteries deteriorate more slowly when half charged, then wouldn't it be better to delay charging until the battery is needed, even if only overnight? . How about a smart controller that lets you set when you need the battery next, and it figures out the best parameters for battery life, and delivers a fully charged battery just in time?
That's an excellent question!
Yes, that is the better way. But you will need to plan when you will need your battery and sometimes it's too much work for doing simple quick ride... the capacity lost over the time would represent like 5-10% over the total life.. so it depend how you want to profit of your ebike..
Planning every use of it and charging it overnight just before the use and having a gain of 5-10% more life of your batery... well.. it depend how you pecieve that...
Some people will want to have their bike ready for every ride.. some not..
Certainly, a slower charge is always better cause the current that travel the cell is lower and will generate less heat inside it and will let the BMS to do a better work!.. and then.. encourage a very long battery life.
That's a great idea.. i think i've heard of some EV home charger working like that... but again like i said a great and accurate planning of the future use of your ev will be a must!
Doc
I have a simple answer for the daily rider looking for just in time chargin.
I bought a wall timer that you can program to turn on as needed.
My battery fully charges in 3 to 4 hours tops. I leave my place at 8 in the morning. So, the night before, I plug my bike in and the timer doesn't turn on until 4am, then charges up the bike, which is then ready to go by 8am.
I posted a video to show you what I mean here: http://www.youtube.com/watch?v=RJAezKY9m6g
Rory
