fabieville
- Joined
- Jul 15, 2012
- Messages
- 114
What method(s) should be implement to keep your single speed freewheel in perfect working condition?
I realize that sometimes the "dog" in mines sometimes slip and I have to flush out the freewheel with Double D40 to get it working again.
I normally use the Double D40 to flush it out and then I lubricate it with Tri-Flow Superior Lubricant P.T.F.E oil as I saw on the net that someone suggested.
I do a daily commute on my ebike of approx. 40 miles each day. Can you tell me how often I should flush out the freewheel and lubricate it with oil to ensure proper working conditions at all times?
Would once per 2 weeks ok or what do you suggest?
Also would proper maintenance of the freewheel prevent it from never have to change? Reason why I ask is because mines is a mid drive e-bike so therefore all I do is change the chainrings sprockets that are connected to the freewheel whenever they are rub down too much.
