System (U, Motor, Controller) Efficiency
Re: System (U, Motor, Controller) Efficiency
Postby efried » Sun Oct 26, 2008 8:42 am
Hello,
I have read about a Sanyo 2.4kg geared hub motor with regeneration!
do you have a reseller for that?
many thanks
E.fried
efried
Postby paultrafalgar » Sun Oct 26, 2008 9:20 am
You've probably seen this:
http://www.bikecircle.com/forums/tech-i ... ssion.html
it doesn't help in that it says there is no US supplier.
This also doesn't help with a supplier, but you might not have seen it:
http://techon.nikkeibp.co.jp/english/NE ... 07/154398/
Hope this isn't annoying! Lots of announcements are made by companies before anything is available. It's called vapourware!
If we knew what it was we were doing, it would not be called research, would it? Albert Einstein
A paranoid is someone who has SOME idea of what's going on. Allen Ginsberg(?)
If the greatest pleasure is giving, be selfish - give pleasure.
paultrafalgar
Postby Kurt » Sun Nov 02, 2008 5:59 am
I just wanted to backup Zoot Katz I think If he rides like he said he dose his number would be correct.I posted my numbers for both my dual motor and 5304 .I gave number range that represent how I normally ride the bike and the numbers are kinda average .
That said I have ridden the same bike and use much less power then I normally would I didn't take note of the wh/km but it was a regular ride that is 15km one way I use about 6ah from my pack each way when I ride normally.I once rode that same trip one way on just under 1ah and it isn't a flat ride there is a good mix of hills and flat sections. I put in a solid effort and just used the motor to take the edge off up the hills.
Hey if you don't use the throttle you don't use any power from your battery and if you have a good range of gears you will get there eventually on zero kw.
Kurt.
Kurt
Postby cycle9 » Wed Nov 19, 2008 11:34 am
1. Efficiency (Watts/mile): 14 to 18, depending on load
2. Speed (mph | kph): Typical average, 18 mph, city + highway riding, 17 miles round trip
3. Gradient (%): moderate hills, 3%, a few short 7-8% hills
4. Pedaling effort (none, light, heavy, extreme): heavy to start, light continuous
5. Bike Type (roadster, MTB, trike, others): Surly Big Dummy longtail
6. Motor Model: BMC V1 geared
7. Controller Model: Various, including BMC 25A, and Crystalyte analog 35A
8. Battery (Voltage/Capacity): Various. Typically LiFePo4 10Ah or 2x10Ah, 36V. Sometimes 48V, efficiency is similar.
http://www.cycle9.com
Intentionality fuels the master's journey. Every master is a master of vision.
- George Leonard, "Mastery"
cycle9
Postby Doctorbass » Sat Jan 03, 2009 5:36 pm
1 ) Efficiency - 10Wh/mile AT 22mph
2 ) Speed - 22 MPH cruising on long straights 47mph full speed
3 ) Gradient - Almost completely flat
4 ) Pedaling - never
5 ) Bike - Full suspension mountain bike
6 ) Motor - Xlyte 5305
7 ) Controller - Xlyte 7235 analog, modified with 4110
8 ) Battery - 24s18p Konion 3.7V/4.2V (88.8 volt nominal, 100.8V max 23.1A Ah)
9 ) Max range without pedal 210km finally measured
Doc
________________
-Fastest speed record from now: 113 km/h measured on GPS
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec X5 5303 on 24"
TORQUE SETUP:
-Team Konion Member
113kmh Giant___http://www.evalbum.com/3406
Mongoose____http://www.evalbum.com/1947
E-trike_______ http://www.evalbum.com/3776
I speak FRENCH and english
Doctorbass
Postby vkruger » Sun Jan 18, 2009 11:10 pm
1. Efficiency (Watts/mile): 10 to 12W/mi, depending on how many red lights
2. Speed (mph | kph): Typical average, 14-16 mph, city 23 mile daily commute round trip
3. Gradient (%): moderate hills, biggest 1 mile at 7-9% (have to brake at 45MPH going down)
4. Pedaling effort (none, light, heavy, extreme): medium (motor off above 18mph because of 20" hub wheel)
5. Bike Type recumbent Giro 20
7. Controller Model: Crystalyte analog 35A
8. Battery (Voltage/Capacity): 36V - Various LiFePo4 10Ah 20Ah duct tape, Konion 8Ah 12Ah
vkruger
100 µW
100 µW
Postby cerewa » Wed Mar 04, 2009 2:34 pm
This is for the commute I used to do. The motor's controller broke and I switched jobs, and these days I commute without a motor.
1. Efficiency (Watt-hours/mile): 6 - 7 watt hours per mile
2. Speed (mph | kph): 16mph (65 minutes each way, 17 miles each way)
3. Gradient (%): lots of hills, 10% of the distance on flat ground. lots of ~%5 grades, some climbs of ~150 vertical feet in a space of ~1500 horizontal feet (10%).
4. Pedaling effort (none, light, heavy, extreme): medium-heavy
5. Bike Type: mountain bike
6. Motor Model: Cyclone 500W
7. Controller Model: Cyclone 24V, built-in to motor housing (intended for 30A max, I believe)
8. Battery (Voltage/Capacity): YESA 240 watt hour (24V10Ah) LiFePO4. Enough capacity to go about 40 miles with this setup. 20A limit on BMS.
cerewa
Postby Toshi » Wed Mar 04, 2009 3:52 pm
i think this is an admirable effort. however, i don't think it can be used for straightforward comparisons between gear, as bike configuration (including handlebar/seat height! and tire choice), rider weight, terrain, number of stops/starts, presence of a headwind or tailwind, pace, and riding style/pedaling effort play a HUGE role. i could use 0 Wh/mile with my current setup and have used as much as 37 Wh/mile, after all.
that said, here are my data:
1. Efficiency. 25.89 Wh/mi lifetime average as of today. Scatter plot of energy use over time.
2. Speed. I cruise on the flat at 22-25 mph but my CA-reported average is almost always 15-17 mph due to hills as well as many stoplights and stop signs along my route.
3. Gradient (%). My normal route has 250 feet of vertical gain over 1.22 miles: an average grade of 3.88%. There's a short pitch in there that's probably a 5-6% grade.
4. Pedaling effort. Moderate. My bike is geared such that I can pedal along at a reasonable cadence whether going 5 mph or 30 mph.
5. Bike Type. Flat-bar hybrid with 26x1.75" semislick tires, with handlebars about level with the seat.
6. Motor Model. Crystalyte 407 in a 26" wheel.
7. Controller Model. Crystalyte 72V 20A pedal-first controller.
8. Battery. 48V 12Ah prismatic ebikes.ca LiFePO4.
Toshi
Postby bbushwacker » Mon Mar 09, 2009 3:34 am
1. Efficiency. 29.7 Wh/mile 18.5 Wh/km (average, going both directions)
2. Speed. max 34km/h
3. Gradient (%). pretty steep, estimated 100m elevation gain over 1km, rest flat
4. Pedaling effort. Minimal, only on hills, throughout acceleration and to pass others
5. Bike Type. Heavy full suspension downhill frame with knobby off-road tires
6. Motor Model. Ezee, rear with disc
7. Controller Model. Ezee, limited to max 17A min 39V to reduce the risk of frying more MOSFETs
8. Battery. 48V8Ah NiCd
bbushwacker
100 µW
100 µW
Postby floatbike » Mon Mar 23, 2009 1:02 pm
1. Efficiency : 14 WHr/Mi
2. Speed (mph | kph): 20mph max, 16mph cruise
3. Gradient (%): flat with a few steep hills
4. Pedaling effort (none, light, heavy, extreme): moderate pedaling all the time, heavy up hills
5. Bike Type (roadster, MTB, trike, others): 24lb aluminum folder
6. Motor Model: GoldenMotor Geared Mini Motor
7. Controller Model: GoldenMotor Cruise Controller with Regen
8. Battery (Voltage/Capacity): 38.4V 10AHr GoldenMotor LiFePO4
I used to race cross country MTB, now 15 years later I am slower with electric assist than I used to be unasisted!
floatbike
Postby icecube57 » Sun Apr 05, 2009 9:00 pm
1. Efficiency : 18-24wh per mile
2. Speed : 30mph on flats 36mph down hill
3. Gradient : 1-2% on the trail that I ride
4. Pedaling effort : Light Pedaling
5. Bike Type: Next Mountain Ridge MTB
6. Motor Model: Golden Motor 1000w
7. Controller Model: Golden Motor Stock 48v 30A
8. Battery (Voltage/Capacity) 48v 20AH Ebay Duck Tape (NON PING)
icecube57
1 GW
1 GW
Postby MartyK68 » Tue Apr 07, 2009 3:19 pm
It would've been nice to see everybody's weight...
MartyK68
Postby urace4me2 » Mon Apr 13, 2009 7:52 am
Just did a test yesterday:
1. Eff: 11.5 watt hour per mile 37.5 miles, 1:48, batteries never quit even though the last 3 miles or so I didn't pedal at all. so actual achieved efficiancy was higher and could have been much higher had I kept pedaling 'til batteries got below low volt controller threshold.
2. Spd: 24mph was the max speed I could feel the motor helping. Top speed by myself with motor turned off was 28 mph on the flats. After 30 miles I could still get 21 on the flat without pedaling.
3. Gradient: dead flat.
4. Pedal effort: Extreme. 90% of the ride was pedal unassisted for 10 to 60 seconds then use a electric burst to rest for 10-60 seconds. Probably less than 50% assisted time. Used pedals to get rolling but motor to help get from 4 mph to 20mph.
5. bike: Giant Sedona ATX (1994) clipless pedals to allow "full circle" pedaling. 1.7 inch wide almost slick road type tires pumped to 60 psi
6. motor: Amped bikes kit
7. controller: Amped bikes kit
8. battery: Jupiter battery 3 X 12 volt 12 ah AGM SLA
Thrilled with the range!
urace4me2
Postby Russell » Mon Apr 13, 2009 11:43 am
urace4me2 wrote:Just did a test yesterday:
Hello urace4me2,
What are you using to measure the energy consumed from the batteries or are you giving us your TOTAL power (you and batteries) from a PowerTap hub? I ask because when folks here talk about efficiency the Wh/mile numbers are JUST what the batteries provide and there's no way 3-12V/12Ah batteries can provide 431Wh (11.5 Wh/mi x 37.5 mi) of energy unless they are discharged completely at a 20 hour rate.
-R
Jeep Comanche 29er w/Bafang QSWXH, 41 lbs + 9 to 14 lb rear trunk bag w/tools+battery, 29 mph w/12S LiPo.
Mongoose Hatchet dual suspension w/Bafang BPM
Past Bikes: Raleigh 700C, Kona Smoke 2-9
Russell
Postby urace4me2 » Mon Apr 13, 2009 12:55 pm
I did math assuming 36v12ah capacity (432 watt hr) spread over 37.5 miles. It assumes the batteries were totally used up. Of course this is false but it errors on the side of indicating less efficiency than actually achieved. It is the battery power I used up during my 37.5 mile assisted ride (assuming they quit on me, but they didn't). I think what's so different is I was putting out some serious watts with my legs. It was more a test of how far those batteries could "help" me maintain a speed average of over 20, while saving me from having to put out an all out race level of effort. Total run time was 1:48 but throttle was off for probably 50% of the time. I milked those SLAs really slow.
urace4me2
Postby Russell » Mon Apr 13, 2009 2:25 pm
urace4me2 wrote:I did math assuming 36v12ah capacity (432 watt hr) spread over 37.5 miles. It assumes the batteries were totally used up. Of course this is false but it errors on the side of indicating less efficiency than actually achieved. It is the battery power I used up during my 37.5 mile assisted ride (assuming they quit on me, but they didn't). I think what's so different is I was putting out some serious watts with my legs. It was more a test of how far those batteries could "help" me maintain a speed average of over 20, while saving me from having to put out an all out race level of effort. Total run time was 1:48 but throttle was off for probably 50% of the time. I milked those SLAs really slow.
Urace4me2,
That's not a good assumption, but even if you did use them up (~10.5V/12V battery) SLA batteries are rated for a 20 hour discharge so if you discharge them quicker the capacity they deliver is significantly less. What I found was my SLA's delivered 60% of their rated capacity when discharged over a 1.5 hour ride, which is pretty standard. Temperature also affects how much capacity is available with 100% at 25C down to around 85% at 0C.
If you really want to measure how much energy you're using then you need either a Watts-Up meter or Cycle Analyst
http://www.rc-electronics-usa.com/ammeters/dc-amp-meter.html
http://www.ebikes.ca/drainbrain.shtml
-R
Russell
Postby urace4me2 » Tue Apr 14, 2009 5:51 am
I see. Thanks Russell. At least I know I can do the 38 mile each way commute on a charge now, if I pedal. If I plug in your 60% guideline, the efficiency goes to 6.91 Whr/mile. I know it's just an estimate.
urace4me2
Postby Borromeo » Tue Apr 14, 2009 8:33 am
The first long-distance test:
1 ) Efficiency - ? Wh/Mile (How I can calculate?) Autonomy - about 37 miles (60 kms)
2 ) Speed - 12.5 - 19 MPH (20-30 kph) cruiser, top speed 20 MPH (32-33 kph)
4 ) Pedaling - for starting only
5 ) Bike - mountain bike
6 ) Motor - "Red Flag" Chinese hub motor with Hall sensors
7 ) Controller - Chinese Unnamed
8 ) Battery - Gel Lead-acid 3 x 12V 12 AH
I was testing and changing the motor wiring and crossing the whole city, Buenos Aires
Borromeo
Postby ecat » Mon Apr 20, 2009 6:05 pm
Just got back from a typical ride and looked at the numbers, so here goes:
1. Efficiency (Watts/mile) 13.7 Wh/Km
2. Speed (mph | kph) Average speed 29.4 Km/h. Top speed 50 Km/h
3. Gradient (%) 70% flat 30% hills, none steep
4. Pedaling effort (none, light, heavy, extreme) medium, I was quite warm when finished
5. Bike Type (roadster, MTB, trike, others) Catrike Expedition tadpole recumbent trike
6. Motor Model Ecospeed mid drive
7. Controller Model BMC
8. Battery (Voltage/Capacity) Ping 36V 20 AH. Used 9.21 AH to go 24.3 KM
Ecat
2007 Catrike Expedition, Ecospeed mid drive, Ping 36V 20ah
ecat
Postby fifthmass » Tue Apr 21, 2009 9:02 pm
1. Efficiency : 12-20wh per mile
2. Speed : 23mph on flats 30mph down hill
3. Gradient : max 3-4% around Boston area
4. Pedaling effort : Light to moderate Pedaling 80% of time, 20% no pedal
5. Bike Type: crappy Walmart MTB
6. Motor Model: Clyte 408
7. Controller Model: Clyte 48v 40A
8. Battery (Voltage/Capacity) 48v 20AH Ping v1 LifePo4
Regards,
Bill
2010 Trek 820 hardtail with Surly rigid fork
Clyte 408 with Clyte 25A 48 volt controller
48v 20aH v1 Ping lifepo4 - 15,000 miles approx 1,000 cycles
fifthmass
Postby jag » Sun Apr 26, 2009 9:38 pm
18w/km = 28W/mile
40-50km/h
3. Gradient (%)
Some small hills up and down the river valley.
medium
Mtb with city slicks.
6. Motor Model
Nine Continent 2809
7. Controller Model
Crystallyte 30A pedal first
72V 8Ah NiCd
Martin
jag
Postby Reid Welch » Mon Apr 27, 2009 12:10 pm
1. efficiency: 19 to 20 Wh/mile
2. speed: 20mph
3. gradient: flat
4. pedaling: none
5. bike: steel chinese cruiser 52T front, 16T rear
6. motor: 26" eZee, Bontrager Big Hanks slicks front and rear, 10PSI and 20 PSI, respectively.
7. controller: standard supplied eZee 20A.
8. Battery: 36V/20Ah Ping
9. Cycle Analyst presently set for 13A max to save start-up current. Cruises at about 9A @20mph,
riding style: full upright, leaning backwards, pulling against the long (reversed stem) handlebars.
10. Riding style: wasteful, WOT from starts.
11. Suspicion that planetary geared motors are a bit lossier at cruising speeds than direct drive,
and less lossy at start ups and when lugged.
12. Freewheels great. I will pedal more as I get my bicycle legs again.
13. Fixed gearing about ideal for pedal assisting up to about 23mph.
14. C.A. could be set for 20mph max (or whatever), at which point there is no electric consumption (no aid from motor).
15. Unloaded speed of the eZee with this pack is about 28mph; so I have that option of e-assist up to that speed if I spin like mad. So I have it set for "30mph", to always have some help from the eZee if I happen to feel like spinning pedals.
16. Bike has only 110 miles on it at present and the motor is partially oil filled with ATF.
I hope for =a bit= greater motor efficiency with break-in, with possibly less oil in the fill; less oil churning at the ring gear,
and, of course, reduced power consumption when I add pedal assist.
17. At present am having most fun just going pure electric, but that will change and Wh/mile will decrease in proportion as I grow less lazy-legged.
Reid Welch
Postby fabiograssi » Mon Jul 20, 2009 8:50 am
Sorry about the noob question, but I saw in this topic some setups we have 72v controllers with 48 or 36 volts battery packs. Is that possible? The controller don't cut off the power because of the low voltage? Need some mod? Or the users that mentioned 72v controllers are, in fact, the 36~72 volts controllers (the ones that accept more than one fixed voltage input)???
fabiograssi
Postby aaronski » Sat Jul 25, 2009 3:17 pm
On Road:
1. efficiency: 15 wh/mi
2. speed: 16mph average
3. gradient: 5% up down constant
4. pedaling: medium
Off Road
1. efficiency: 35 wh/mi
2. speed: 7mph average
3. gradient: 10% up down constant
4. pedaling: light
5. LOTS of starts and stops due to riding with DOG. no coasting downhill either, can't go over 7 mph at all.(her top speed)
General:
5. bike: 22#alu full suspension mtb
6. motor: 26" BMC, Specialized Armadillo, 60 PSI
7. controller: standard supplied BMC 30 A
8. Battery: 48v 10ah from Cycle9.com
Broken bike and electric bits everywhere. Some times it's a bike and I ride it.
Have:bmc 9c, bafang, lifepo4,lipo, konions, infineon ctrlrs
Smoked:bmc,9c,bafang, lifepo4,lipo, infineons
Konions appear to be bulletproof...
aaronski
Postby alan » Mon Sep 07, 2009 7:22 pm
22 mile round trip commute 4-5 days/week
1. Efficiency: ~14 WH/mile (battery always strong at end, but assume 7/8ths used per display showing 1 of 8 battery bars).
2. Speed: 18-22 mph (I maintain speed the whole way).
3. Gradient: mostly flat, except for half dozen over/under passes
4. Pedaling effort: full power starts and climbs, regen decelerates, medium pedaling mostly
5. Bike Type: Univega Alpena chrome-molly front suspension/hardtail MTB with Michelin City 1.75"x26" tires/fenders
6. Motor Model: Bionx 350 PL
7. Controller Model: Bionx 350 PL
8. Battery 36V, 9.8AH
9. Bike+rider weight: ~225 lb
alan
PreviousNext
Users browsing this forum: Osric, rborger73 and 22 guests
