Shenzhen (ecrazyman) Controller Information
Archive of useful information. This is not a discussion area.
Re: Shenzhen (ecrazyman) Controller Information
Postby solarbbq2003 » Wed Sep 24, 2008 7:41 am
quick look at some literature shows increasing the caps value lowers the freq output of the resonator, so changing resonator/crystal without changing caps will probably give higher frequency, also might explain the high pitched noise of some controllers, seems resonators are piezoelectric ( convert vibrational energy into electrical), so the things are vibrating at very high frequencies ( sorry guys I thought was interesting stuff, all new to me). Also seems going over 30mhz some other issues come up with resonate frequencies.
solarbbq2003
Postby fechter » Wed Sep 24, 2008 8:11 am
solarbbq2003 wrote:just going back to changing crystals/resonators ( I think was earlier in this thread), have noticed there are 2 pin and 3 pin resonators used ( ceramic type ), 3 pin have built in caps set up the oscillations, 2 pin type need caps in circuit with the resonator to set up the oscillations. Just wondering if any one playing with these knows if different picofarad value caps go with different frequency resonators, if there seems to be a problem with going to higher freq say 40mhz i'm wondering if the associated cap values might be an issue in getting the correct oscillations ( or maybe some chips just wont accept the higher frequencies)
According to the datasheets, those capacitors are very small, like 10pF. I tried it with and without them and it did not seem to make much of a difference. I could imagine under some conditons, the capacitors will help get the oscillation going. When I tried 40mhz, it just wouldn't oscillate. For higher frequencies, it may be necessary to use an external oscillator instead of just a crystal.
fechter
Postby Knuckles » Sun Sep 28, 2008 7:35 am
I am running the original ecrazyman controller (not the Infineon) with a 32 mhz crystal and it works fine.
(See pic here ... viewtopic.php?f=2&t=6300&p94776#p94776)
I built this "MEGA over clocked" mod before the Infineon was available.
Kind of pointless now but I was curious about how it would hold up (32/20 = 160% of rated 20 mhz MCU ... 60% overclock).
So far running like a champ on a DD hub motor. Will easily run the Bafang motor at 72V. And the PUMA at 48V (maybe).
With the Infineon available it is all pointless but still cool to know for folks with the old controller.
The old controller works great on DD motors. Same performance as the Infineon on DD motors.
-K
Now this is not the end.
It is not even the beginning of the end.
But it is, perhaps, the end of the beginning.
Knuckles
Postby solarbbq2003 » Thu Oct 02, 2008 4:58 am
good news 32Mhz resonators are high enough for "normal" use on controllers with 16-20Mhz resonators, I'll try a few different controllers as time permits, main use I see is in sensorless controllers, which seem to use external resonators ( well lots of controllers really)
solarbbq2003
Postby oddjones » Fri Oct 03, 2008 5:44 am
Knuckles wrote:That is a Bafang Motor? Direct from from Bafang? Dom ... How the heck did you manage that?
I asked them very nicely :mrgreen: :mrgreen:
Home of the "bad wiring combo torture test" -- I test components until they break
oddjones
Postby jorge75 » Mon Nov 17, 2008 4:46 am
Hello I am new to this forum, I followed this thread with great expectations, particularly as I play a bit with pics (microcohip) myself and own an ICD2. It appears now that the new controllers sold by ecrazyman are all infineon, not pics.
has anyone already bought and opened the beast, are they hackable (cutout voltage) and how; :shock: is it possible to buy a pic based version elsewhere?
I own a goldenmotor 36V 500W with a regen controller :o
jorge75
Postby jorge75 » Mon Nov 17, 2008 7:35 am
:o I have seen now that there is a thread on infineon controller; it shows at least the low voltage cut modification, many other things are apparently to come including the most important: CA taps point (but given the speedometer connection provided the rest may be easy to guess)
Two other things seems important to me: first a connection for a pot to limit intensity and increase autonomy;second wether the controller response to the pas sensor which ecrazyman gives with the controller, is jerky or smmooth :?:
jorge75
Postby Knuckles » Mon Nov 17, 2008 11:00 pm
I have detailed information on the Infineon ...
They are for sale here ... viewtopic.php?f=9&t=8428
A technical post is here ... viewtopic.php?f=16&t=7361
Details of the CA wiring and calibration are provided here ... viewtopic.php?f=16&t=7361&p=110932#p110932
Knuckles
Postby John in CR » Tue Nov 18, 2008 12:21 am
Knuckles,
You electronics guys just love to confuse me. Is the open controller what the raw controller looks like, or are those wires you point to the CA connector's wires? If that's the raw controller then all but the Isense and analogue ground can be tied into from outside of the controller. Is this correct? If that's an open controller with the CA already wired in, then I'm really confused as the yellow and green CA connector wires change color at some point.
Sorry to be a pain, but I have an Infineon that I'd like to tie one of my CA's into.
John
John in CR
Re: Voltage Regulator section
Postby Nicoist » Wed Nov 26, 2008 2:29 pm
fechter wrote:The voltage regulator section is an interesting cascaded LM78xx linear regulator design.
They seem to run quite hot, and I would be inclined to put some heat sinks on the regulators.
Here's the basic layout:
The 5v processor control power starts to crap out at around 40v input in the stock configuration.
By jumpering R1, you can go down to around 30v (50v max).
By jumpering both R1 and R2, you can go down to 15v (35v max).
Here's the location of R1 and R2:
Hi!
Can someone body explain this a little to me?
When I hit the throttle, the motor doesn't react up to a certain point, where the motor starts pretty fast. This means going at low speed is impossible. It's like a minimum speed for the controller. Is that what is meant here?
"30V (50V max)" does this mean I can then go slower, but high speed will be less than before, too? Like limited to max 50V?
(I wouldn't want to limit my top speed)
Thanks for any help
Nicolai
Nicoist
Postby fechter » Wed Nov 26, 2008 7:48 pm
Nicoist wrote:
Hi!
Thanks for any help
Nicolai
It sounds like a throttle problem. If you have a voltmeter and put the wheel off the ground, you could measure the voltage between battery negative and the throttle signal wire coming from the throttle. It should range from around 1.4v at no throttle to around 4v at full throttle and vary smoothly in between. If the throttle response is correct but the motor still won't run at the low end then there may be a problem with the controller.
Not sure about your voltage question, but top speed is a function of voltage. More volts goes faster. Lowering the voltage will reduce the top speed.
fechter
Postby Knuckles » Thu Nov 27, 2008 6:33 am
You need to be using a "hall effect" throttle and not a "5k" throttle.
Check your throttle.
Knuckles
Postby Nicoist » Fri Nov 28, 2008 6:33 pm
yes you're right, i installed my backup throttle and now it starts spinning right from the start with low speed. seems like i had a defect one...
Nicoist
Postby Joehannes » Sat Feb 07, 2009 5:06 am
Hello
I am a member of nearly the same Forum in Germany.
My english is not very well. But i hope somebody can tell us about the controller from crazyman.
We need him for a e-scooter from China, named TD690Z , Voltage 72V , enigine 1500W.
The original controller is a now named and we do not found an other in germany. :cry:
The original is on fire. :evil: :evil: :evil:
So we found the controller from keywin in ebay. Now the controller is on air to germany.
The pictures we found in this board are from 2006. May be now better pictures from a
better controller in 2009? Only inside.
Have somebody a e-scooter TD690Z
The germany forum is not allowed for pictures. i will look again here.
I hope so
Joehannes
Joehannes
Postby philf » Sat Feb 07, 2009 9:30 am
Hallo, Joehannes!
Willkommen!
The controller in this thread has been replaced with the (much nicer) one discussed in this thread: http://www.endless-sphere.com/forums/viewtopic.php?f=2&t=5713
It's based on an Infineon MCU (German!), and is what you should be receiving from e-crazyman...
Cheers!
philf
Postby Joehannes » Sat Feb 07, 2009 11:21 am
Hallo philf,
wir danken Dir für die rasche Antwort und werden still eine Maß ( 1Liter Bier ) für Dich auf dem Oktoberfest ( München ) mittrinken. :D
Thank you, and we will wait for the controller from crazyman and repair TD690Z
MFG
Joehannes
Joehannes
Postby Roy Von Rogers » Mon Feb 16, 2009 10:42 pm
Mmmmm..kann ich da auch kommen...lol
Roy
Roy Von Rogers
Postby diver » Mon Feb 23, 2009 11:06 am
question on the controller, I had the seller change the voltage to 60 volts, . I can not get anything out to the motor. the voltage at throttle is 5. I pulled out the board to check the led status and it blinks 4 times. at 48 volts 4 times at 60 4 times at 72 4 times. Can someone please tell me what i am missing. i followed the wiring diagram for the hall and phase wires. The one led next to the fets stays solid and theother one blinks 4 times... thanks
diver
Postby Mike1 » Mon Feb 23, 2009 2:16 pm
What type of throttle is it?
My controller will give 5V out without the throttle plugged in but that drops to about 4.2 volts when the throttle is connected. Have you checked the throttle resistance across the +5 and 0 wires?
Also I don't think you should be trying to run this at 48V without changing the regulator resistors.
Mike1
Postby diver » Mon Feb 23, 2009 2:31 pm
Hi, it is the throttle that came with it. It will run the motor using the xlite controller but not crazy mans controller. Yes the voltage and resistance is fine at throttle. Im at a loss..lol thanks
diver
Postby Mike1 » Mon Feb 23, 2009 2:44 pm
If the throttle signal wire is giving the correct voltage (mine goes from 1v to about 3.8V) then I would guess that the phase wires are in the wrong order.
Here's the permutations I use.
Hall
Sensor
Wires
BGY BYG
Motor Wires
BGY BYG GYB GBY YBG YGB
Theoretically there are 36 permutations but the 12 above cover them all. All the others are just rotations of these.
I was lucky with mine, the colours matched what was already on the bike.
Mike1
Postby diver » Mon Feb 23, 2009 3:42 pm
I think its just dead, lol. I think i will just buy another one from knuckles. Ive played with all possible combinations, tried a different throttle. We bought two at the time and the other one is over at my buddies house as we have not tried that one yet. I think i will see if i can get that one and wire it up . Hopefully it is alright
thanks
diver
Postby Mike1 » Mon Feb 23, 2009 3:50 pm
I hope mine lasts a little longer than that :)
Waiting for more batteries to arrive so I can re-program the LVC and go to 72V. :D
Mike1
Previous
Return to Technical Reference Area
Users browsing this forum: No registered users and 0 guests
