Power calculator
A place to list links to retailers that sell EV related parts.
Power calculator
Postby Miles » Sat Mar 17, 2007 10:17 am
This spreadsheet calculator was posted on the Power Assist list sometime ago. Credit for the program to Dave Everett. I've corrected one of the slope conversion formulas, that's all.
Ebike powercalc rev.1.zip
(5.96 KiB) Downloaded 703 times
Miles
Postby Miles » Thu Jun 07, 2007 3:44 pm
Just tidied this up a bit.
Ebike powercalc rev.2.zip
(5.91 KiB) Downloaded 440 times
Miles
Postby Miles » Sat Jun 30, 2007 5:03 am
Version 3 attached.
The expressions used for the formula in cell G7 were revised to enable the spreadsheet to function correctly on Google Spreadsheets.
You can now use this calculator without the need for Microsoft Excel.
Create an account with Google and upload the file to http://docs.google.com/
Please post any bugs/suggestions here.
Miles
P.S. I'm intending to append a table of "typical values" to the spreadsheet, so that people will be able to enter the value that most closely corresponds to their specific case.
Ebike powercalc rev. 3.zip
(6.02 KiB) Downloaded 638 times
Miles
Postby Miles » Wed Sep 05, 2007 9:49 am
If you don't have spreadsheet software, you can also upload this program to: http://www.editgrid.com/site and use it online. Editgrid seems to be better than Google Docs.
Miles
Postby PJD » Thu Nov 01, 2007 10:07 pm
As far as power calculations for climbing various grades, a while back I set up a spreadsheet so I could use the various slope hills in my area, along with a drag force calculation as a sort of poor-boy dynamometer test.
The spreadsheet is attached. It provided actual motor performance graphs for a hub-motored bike, or it could be modified easily for a chain or reduction gear.
It gives the calculation results and both metric and US units, but the raw data has to be in US units, sorry.
The numbers entered on it representing the actual performance on my e-max.
PJD
Postby fechter » Fri Nov 02, 2007 9:02 am
Whoa.. almost 5kw. That's a pretty spunky scooter.
fechter
Postby deardancer3 » Sun Dec 09, 2007 11:57 am
I like this power calculator; thought I would share.
(It lets you easily swap out different bike frames with default setting)
http://www.kreuzotter.de/english/espeed.htm
Dick in colorado
deardancer3
Re:
Postby paultrafalgar » Wed Jun 11, 2008 6:40 am
PJD wrote:As far as power calculations for climbing various grades, a while back I set up a spreadsheet so I could use the various slope hills in my area, along with a drag force calculation as a sort of poor-boy dynamometer test.
That's a fascinating spreadsheet, PJD. What I find interesting is comparing Row 12 with Row 16.
You have halved (approx) the speed and EVEN though it's doubled the slope, you use 60% of the power!!!
SLOWING DOWN ON THE CLIMB is the way to go.
If we knew what it was we were doing, it would not be called research, would it? Albert Einstein
A paranoid is someone who has SOME idea of what's going on. Allen Ginsberg(?)
If the greatest pleasure is giving, be selfish - give pleasure.
paultrafalgar
Re: Re:
Postby Miles » Wed Jun 11, 2008 6:52 am
paultrafalgar wrote:SLOWING DOWN ON THE CLIMB is the way to go.
Slowing down makes very little difference to the total energy consumed to climb hills.....
Miles
Re: Power calculator
Postby paultrafalgar » Wed Jun 11, 2008 7:05 am
Not according to PJD's spreadsheet.
paultrafalgar
Re:
Postby paultrafalgar » Wed Jun 11, 2008 7:09 am
Miles wrote:If you don't have spreadsheet software, you can also upload this program to: http://www.editgrid.com/site and use it online. Editgrid seems to be better than Google Docs.
Just a little plug for OpenOffice. You don't need to be without a spreadsheet! OpenOffice is FREE for both Windows and Linux (probably Mac as well, I don't know).
IMHO better than Microsoft Excel by far.
:D
paultrafalgar
Postby Miles » Wed Jun 11, 2008 7:14 am
If you halve your speed you take twice as long to climb the hill.....
Sure, we know the power required to overcome air resistance goes up with the cube of the speed but if the power required to climb goes up linearly then slowing down on hills will have less effect on the total energy consumed than it would on the flat.
Miles
Re: Re:
Postby Miles » Wed Jun 11, 2008 7:16 am
:D
I certainly wouldn't disagree with this :D
I moved from Excel '98 to Open Office Calc after trying Microsofts' latest.......
Miles
Postby Miles » Wed May 13, 2009 12:31 pm
Latest version, in ODS format:
Ebike powercalc Rev. 4.ods
(25.32 KiB) Downloaded 356 times
Miles
Postby Eric » Thu May 21, 2009 8:27 pm
Am I the only one who cannot open this due to its password protection? It probably works fine in other spreadsheets, but Xcel is having issues.
Eric
Eric
Postby paultrafalgar » Fri May 22, 2009 3:15 am
Eric wrote:Am I the only one who cannot open this due to its password protection? It probably works fine in other spreadsheets, but Xcel is having issues.
Eric
It's an open-source format that OpenOffice uses, I'm not sure if Microsoft recognises/tolerates importation of .ods, but if you ask Miles nicely, he will convert it using Openoffice to Microsoft .xls format! BTW IMHO Openoffice calc is vastly superior to Excel and it's a free download, so why not get a copy that runs on Winders (if you must use a c**p operating system. :D )
paultrafalgar
Postby Miles » Fri May 22, 2009 4:26 am
Hi Eric,
Here's an older version in Excel format and a conversion of the latest from .ods to .xls:
Ebike powercalc Development Excel.xls
(83 KiB) Downloaded 161 times
Ebike powercalc Development1 Excel.xls
(24.5 KiB) Downloaded 429 times
Miles
Postby Miles » Tue Sep 14, 2010 1:37 am
Revision 5.
- Added breakdown of torque at the wheel.
- Altered background colours of cells.
Ebike powercalc rev.5.ods
(25.53 KiB) Downloaded 123 times
Miles
Postby Miles » Tue Sep 14, 2010 8:27 am
Revision 6. Simplified version.
- Removed battery characteristics; motor efficiency and torque inputs.
- Removed distance and amps outputs
- Added motor torque output.
OpenOffice format (for Excel format see 2 posts down).
Ebike Powercalc Rev. 6.ods
(21.5 KiB) Downloaded 251 times
Miles
Postby Miles » Tue Sep 21, 2010 7:53 am
Miles
Postby Miles » Tue Sep 21, 2010 7:57 am
Revision 6 as an Excel file:
Ebike Powercalc Rev. 6 (Excel).xls
(24.5 KiB) Downloaded 257 times
Miles
Postby Miles » Sun Jul 17, 2011 5:16 pm
Miles
Return to Resources & EV Related Parts
Users browsing this forum: No registered users and 0 guests
