Instant Start 18 fet Infineon Boards are here...
Re: Instant Start 18 fet Infineon Boards are here...
Postby methods » Wed May 27, 2009 11:33 am
Doctorbass wrote:Here is what solution i found :
eh eh... Not so fast Doc
You forgot a few things.... Like the 3 giant phase wires :mrgreen:
Also you will find that the bottom right of the board has heavy congestion due to all the control wires being grouped right there.
Also the VCC comes from up on the left corner.
I am not saying that it can not be done... I bet I could put 6 AWG wires in there and 600V caps.
Doing it once is one thing.
Building 30 of them is another.
Convincing a fabrication shop to take the job..... That is yet another.
Usually i think like you Doc.
On this project I am being forced to think about compromise, ease of build, repeatability, etc.
I have built many high consequence systems at work and I have learned that tight cable routing leads to great frustration and problems.
But I dont want to argue... If the build works out good then please share with me the part numbers and I will try them out.
-methods
larger 160V caps layout.JPG (75.73 KiB) Viewed 1298 times
Jozzer wrote:Your already the guy to go to for the guys that other guys go to..
I sell stuff.... like little morsels of my integrity @ http://www.MethodsTechnology.com
methods
10 GW
10 GW
Postby dnmun » Wed May 27, 2009 1:38 pm
i used the 100V1000uF caps on my 72V conversion of the 9 FET infineon: viewtopic.php?f=2&t=10222
the caps are 18mmx40mm long so i had to move the power resistors to the underside so the two on the input would have space inside the case.
i am selling the caps i got on ebay for 30 cents apiece plus postage. i need to put up a sign in the for sale section yet. i also have 5 of the 100V2200uF caps i might part with, but you have to have a need since i am gonna use them on the S/D busses when i do the next upgrades to 72V.
nichicons.
dnmun
Postby Doctorbass » Wed May 27, 2009 4:51 pm
Oh... :mrgreen:
digikey is SO FAAAAAAST !!!
I received them at the diner !!! less than 20hours after my order!!!!
12 brand new 160V 1000uF caps...
Methods I agree with you that building 30 controlelrs with biggers caps is not as simple as it appear to be !!!
but you know me.. for building one or two.. i'll find the place!!! :twisted:
I will need to use a precharge resistor otherwise i will blow the switch after 10 or 15 power ON action!!! :mrgreen:
The 18 mosfet Crystalyte is on the way too.. i will have both and will compare them after i'll upgrade them. :twisted: :twisted:
ok.. now i quit.. i must go to assemble the aluminum case of my mini A123 killacycle pack !!!.. it will be very similar to 1/10 scale of it :mrgreen:
Doc
________________
-Fastest speed record from now: 113 km/h measured on GPS
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec X5 5303 on 24"
TORQUE SETUP:
-Team Konion Member
113kmh Giant___http://www.evalbum.com/3406
Mongoose____http://www.evalbum.com/1947
E-trike_______ http://www.evalbum.com/3776
I speak FRENCH and english
Doctorbass
Postby liveforphysics » Thu May 28, 2009 10:21 pm
I just had a realization about this cap stuff.
We seem to be going about it the wrong way. We aren't concerned at all with storing energy in these caps, that's why we have batteries. We have the caps to resist the change in voltage each time a FET bank switches on or off. The peak capacitance we need to be store to do this is under 50uF (from my crude estimation).
All the effects our performance is the final ESR of the system of caps we use. In other words, any cap solution that provides a lower combined ESR, regardless of the capacity values is going to result in higher performance.
This reminds me of my car audio days, when I was able to keep my amp voltage more stable with a single 1/2F cap than with the 16F cap bank that I had bought thinking it would be an upgrade. It used those carbon supercaps inside, which have crap Ri, and it didn't help keep voltage stable any better than adding an additional little wimpy 12v SLA battery would have done.
liveforphysics
Postby Doctorbass » Fri May 29, 2009 12:58 pm
ok guys.. let's show some real data :twisted:
This afternoon i've tested the capacitors ESR and capacity using a high quality laboratory grade HP LCR tester ( 15000$)
here is the data.. ( i thing you might consider replacing those stock caps) :wink:
Infineon 1000uF 100V Rubycon: cap: 998uF ESR: 110mohms
Crystalyte 1000uF 100V DTDZ : cap: 1063uF ESR: 260mohms :?
Panasonic 1000uF 160V Panasonic:cap: 740uF ESR: 73mohms :mrgreen:
It seems that buying these 4.50$ caps is the best thing to do for high power/voltage controller! :twisted:
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby swbluto » Fri May 29, 2009 1:17 pm
liveforphysics wrote:I just had a realization about this cap stuff.
Which is why replacing more capacitors in parallel should only help, as more effective series resistors in parallel means a less total effective resistance. However, lower ESR caps should help more if you're only changing out caps.
By the way, I didn't know ESR was such a big deal for caps. What kind of failures do high ESR lead to? Higher probability of cap failure due to over-heating? A slowing down in "capacitor response" time due to the higher RC time constant which leads to...? Any others?
swbluto
10 GW
10 GW
Postby fechter » Fri May 29, 2009 2:14 pm
What frequency were you doing the ESR test at?
I would suggest testing at 10-15khz and also at 1khz. 15khz will be near the PWM switching frequency and 1K will be closer to the commutation frequency.
You may be surprised with the results of of lower capacitance samples too. Try a 470uf or even a 220uf and see how it compares :wink:
fechter
Postby Doctorbass » Fri May 29, 2009 8:35 pm
i've used 10kHz.
yes that could be interesting to test lower value!
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby liveforphysics » Fri May 29, 2009 9:48 pm
It's great to know that a single one of those panasonic caps would help more than 4x the crystalite caps! That's quite a suprize, because generally ESR increases directly with voltage rating for capacitors of the same technology (electrolytic in this case).
I know there are 12v rated caps used for computer MoBo's that are 2mOhm ESR. It would be fantastic to find an ultra low ESR cap for voltage ratings closer to what we are working with.
liveforphysics
Postby CamLight » Fri May 29, 2009 10:11 pm
swbluto wrote:By the way, I didn't know ESR was such a big deal for caps. What kind of failures do high ESR lead to? Higher probability of cap failure due to over-heating? A slowing down in "capacitor response" time due to the higher RC time constant which leads to...? Any others?
Those are the big ones.
High temperature is death for caps. All that charging/discharging through that equivalent resistance creates a LOT of heat. Lower ESR means both faster response (if needed) and cooler running caps. Electrolytics have a short enough life span already without heat making it worse. :)
However, there are some voltage regulators that require a minimum ESR to remain stable for certain voltage/current operating ranges.
John M.
Owner
CamLight Systems
CamLight
Postby liveforphysics » Fri May 29, 2009 11:50 pm
I found this site, it's kinda neat.
http://www.low-esr.com/
Too bad I didn't find anything too fantastic for our E-bike applications. If you were running a 24v system, going for the 35v hybrid caps would be great, they are extremely small so you could package one on the board locally for each FET.
But, nobody runs 24v that is interested in power, and grouping them in series would end up with a lot of hassle for a minimal performance gain.
liveforphysics
Postby liveforphysics » Sat May 30, 2009 12:19 am
Rubycon makes some caps that look pretty good, but you would need 3 in series... which would be lame to setup.
35v 470uF 0.014Ohms ESR 10mm x 20mm
So, it would be 42mOhms for a 105v cap with 156uF, and it would fit in a very small space. I think using a group (3s8p) of these caps you could get a board down to maybe 5mOhms.
Running 4x of Docbass's panasonic caps would get you to 18mOhms, and it would be a lot easier to solder up :)
I'm going to keep hunting for the ideal cap. I found ultra low ESR caps in voltages up to 200v, but they maxed at 1uF. Really impressive specs though! I just need to find a larger size of cap using the same polymer technology rather than the regular cheapy liquid electrolyte style.
liveforphysics
Postby methods » Sat May 30, 2009 1:52 am
Keywin forgot to populate D32. This is the diode that links the -EBS (ebrake) pad trio. It is suggested that you use a 1N4007 or an M7.
Doc & Gary -> you are on your own :mrgreen:
I know it is rocket science but I think you two can manage :roll:
-methods
methods
10 GW
10 GW
Postby boostjuice » Sat May 30, 2009 2:05 am
Are these physically too large to fit inside the infineon casing?
1200uF, 100v, 62mohms, 1.375" in Diameter x 3.125" in Length, $16.74
http://www.mouser.com/Search/ProductDetail.aspx?qs=sGAEpiMZZMsCnlYck6hSqO6KPCXhPvFm4H11sKdCUik%3d
720 uF, 150v, 63 mOhms, 1.375" in Diameter x 3.125" in Length , $17.16
http://www.mouser.com/Search/ProductDetail.aspx?qs=sGAEpiMZZMsCnlYck6hSqO6KPCXhPvFmXU7gjc7nu2c%3d
boostjuice
Postby methods » Sat May 30, 2009 2:22 am
The 18 fet Crystalyte boards are IDENTICAL to these boards.
They are buying from the same manufacture and just populating with slightly different parts.
http://endless-sphere.com/forums/viewtopic.php?f=2&t=10627&p=163176#p163176
Lol... Poor old Doc is going to have 2 of a kind. :cry:
-methods
methods
10 GW
10 GW
Postby Doctorbass » Sat May 30, 2009 1:37 pm
I found something interesting on the XIECHANG website!! some new indo availlable about the 18 fets controller!! and the uC they use ( crystalyte and Infoineon!!)
here is the 18 fet Infineon page: http://www.xie-chang.cn/cn/product_read_kzq.asp?id=117
you can translate using Babelfish..
This is great to have update on their page about the 18 fets controlelr and the new Uc pdf!
Doc
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby wanders » Sat May 30, 2009 4:04 pm
Doctorbass wrote:I found something interesting on the XIECHANG website!!
Yep, all of Keywin's controllers (whether with an Infineon microcontroller or not) come from Xie-Chang (see my post on page 2 of this thread). Their website has a lot of dowloadable documentation, all of which is copy-paste protected (to prevent automated translation among other things, I guess). I have fixed this for all their docs, and another ES member (biketrials) has said that he would help translate. The automatic translators (e.g. Google) don't do a very good job on this stuff. Hope to have some results soon.
On a slightly different tack, methods, are you programming these things using the USB cable? The software is available on the Xie-Chang site (I can point you to it) but it is probably all in Chinese. My controller is still XC846 (Infineon) based, unlike the 18-FET version. I need some pointers on how to use the direct USB cable which came with my Xie-Chang controller (a 12-FET 72V/45A version). For example, do you program with the power on, or does all the programming power come from the USB cable?
wanders
Postby methods » Sun May 31, 2009 6:29 pm
DUDE - DOC - you are a genius!
I think that is the new software that I have been waiting for keywin to Translate!!!
I can get the translated tomorrow and we will have the software running!
I secured a translator at Stanford University. He is perfectly fluent in both Mandarin and English.
Awesome!
I am going to have to send you a free gift if this is the software that I think it is.
-methods
methods
10 GW
10 GW
Postby Doctorbass » Sun May 31, 2009 6:42 pm
methods wrote:DUDE - DOC - you are a genius!
Awesome!
-methods
:mrgreen:
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby Doctorbass » Sun May 31, 2009 7:19 pm
Something INTERESTING FOR YOU GUYS !!
Here is the complete folder of the XIE CHANG web page concerning controller!!
I translated the folder but not the file content.. ( few hours are needed for that!)
I ziped it for you!!
Alot of great INFO about infineon.. and i guess crystalyte controlelr desing!! and their Uc !!... and some .exe!!
I let you discover how to use these files!
My part of job is done for that.. I must return to my drag bike fabrication!
Doc
WUXI XIECHANG.zip
(5.84 MiB) Downloaded 301 times
________________
TORQUE SETUP:
-Team Konion Member
Doctorbass
Postby methods » Sun May 31, 2009 10:05 pm
Good job Doc!
Please, lets use this thread to investigate this further.
Anything that anyone can add or help with is welcome!
I have been trying to translate the instructions for the software but the damn PDF is locked which prevents copy paste.
There are multiple ways to get the data...
This is exciting. I hope this really is the new software. Tonight I am going to try to translate all the words on the software GUI.
This will tell us what we can control this time.
-methods
methods
10 GW
10 GW
Postby liveforphysics » Sun May 31, 2009 10:50 pm
use "foxit" .pdf reader, and use the plug-in for disableing all write protection stuff. It's all opensource and free.
You can also use google chrome to view them, and download the 3rd party plug-in that removes all protection stuff from documents, and you can copy and paste freely.
or, if it's some propriatary crazy file format that those don't work with, just your print screen button, past the screen image into some program with optical text recognition, and go from there.
If you can see the data, it only carries the illusion of protection.
-Luke
liveforphysics
Postby methods » Sun May 31, 2009 10:54 pm
Ok, I sent the software off to 2 different translators.
One is a friend of mine and the other is a paid professional translator.
For starters I sent a screen shot and the instruction manual.
I dug through the software folder and found the upload files!
Unfortunately they only have examples for 6, 9, 12 fet but I bet there will still be a setting for 18 fet.
Good news > ?? There are way more settings!
NEW SOFTWARE CHOICES
3:EB212
70
28.0
41.5
1.0
60
1:Ñ­»·ÃŠ½ÃˆÃ½Ã‹Ã™¶Ãˆ
100
80
60
1.0
6.0
1:ֻÓл¬ÃÃÃÃ”ʾ£¨¼Ã™µÃ„£©
1:¹²Ã’õ
0:ÆÕͨ
40
60
1:¸ÃŸµÃ§Ã†½
0:ÎÞ
0:¼Ã™µÃ„
0:Ѳº½Ã–¸Ãо
2:¼Ã¦ÃˆÃ
OLD SOFTWARE CHOICES
1:EB806
70
7
32.5
1
50
0:Switch Mode
100
100
100
1
15
1:Only fake Indicate
1:Comm GND
2
35
SWEET!!!
I will have a translated screenshot up ASAP.
-methods
methods
10 GW
10 GW
Postby liveforphysics » Sun May 31, 2009 11:35 pm
Printscreen button Methy! Lets see this stufff!
liveforphysics
Postby methods » Mon Jun 01, 2009 3:50 pm
wanders wrote:
Doctorbass wrote:On a slightly different tack, methods, are you programming these things using the USB cable? The software is available on the Xie-Chang site (I can point you to it) but it is probably all in Chinese. My controller is still XC846 (Infineon) based, unlike the 18-FET version. I need some pointers on how to use the direct USB cable which came with my Xie-Chang controller (a 12-FET 72V/45A version). For example, do you program with the power on, or does all the programming power come from the USB cable?
There is a lot of talk on this subject. Start in the infineon threads and technical section.
Basically you load up the file settings, make your changes, press go, and touch the programmer to the programming slot.
Alternator you can leave it connected and power cycle the controller.
Lots of ways to get it done.
Where did the ZIP file go that doc posted with the software ?!?
Did a mod pull it and why?
-methods
methods
10 GW
10 GW
PreviousNext
Return to E-Bike Technical
Users browsing this forum: Harold in CR, Lory, Moya and 10 guests
