callagga wrote:Hi Russell,
So is this correct to say (plus some questions)
* All throttles work on the concept of providing a variable voltages back to the controller, therefore all one needs to do is mimic this behaviour when working out resister values?
* I have a Crystalyte throttle for an eZee kit (http://ebikes.ca/store/store_ezee.php) so irrespective of how the current throttle works your approach should be ok for the eZee kit?
* If you put no resistors in at all and the voltage sent back is say 0V - Supply Voltage, could this damage the controller do you think? In other words how sensitive do you think controllers would be to getting things wrong here (e.g. resister values)? (I would get there shouldn't be an issue)
* You don't talk about current (A) in your thread - are there any current limits that a controller would be sensitive to? Like you could get the same voltages buy buying a potentiometer & resisters that were 1/10 of the value, or 10x the values no? You would still get the same ratios however the currently flowing would change. Did you measure the current flow on your original bike, or just assume that if scooter throttles come in this 3.3kOhm range this is normal and work from here?
thanks again
bikeelectric wrote:I am considering trying this lever type - I am starting to think the raw spot on my thumb is from my thumb throttle !
I found the same thing for less than half the price here
Note : I was going to order from here but didn't see a https secure link for credit card info so I am holding off on it.
http://ebladez.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=70171&Category_Code=EPXTRStreetIICompIIRP
callagga wrote:Russell - BTW does the 3 pin connector at the end fit out-of-the-box the ebike controllers? i.e. are they all standard? In other words would I have to order a connector separately?
BTW - One place that does ship to my location is http://www.partsforscooters.com/111-46. These guys should be as good as any no?
Tks
Russell wrote:the TRIGGER throttle.
To me a full twist throttle is at home on a motorcycle where the rider is stationary and usually in an upright or even laid back position but they don't seem to be the best solution on an ebike which someone is actually pedaling and may even be getting out of the saddle from time to time. The full twist throttle that came with my kit is hard plastic and I know it would be a real pain holding it in position for any length of time. I ordered a left hand thumb throttle but then I noticed many active vehicles where the rider may be getting jostled such as ATV's and jet skis often have trigger throttles. Of course those are cable actuated but I did find a trigger throttle used on an electric scooter to try.
-R
sprocket wrote:
Russell,
Do you think one could modify that throttle to fit 15/16" diameter bars rather than 7/8"? One nice thing I see is that the throttle mechanism is separated from the mounting hardware (unlike thumb or twist, where it actually surrounds the mounting hardware. As you pointed out, curved handlebars are rare, and one problem we have is an incompatible diameter for standard throttles.
-S
Russell wrote:
I take back what I said a few posts ago, I ordered my latest throttle from here a couple days ago;
http://www.scootercatalog.com/bladez-throttle.html
instead of here;
http://www.extremescooters.biz/throttleleverbladezpart70171.aspx
-R
Joepostal wrote:The plastic bits on this throttle are huge, the mounting could potentially be cut in half to 15mm, 7 on each side and it still would work fine. The resistance is high and the full sweep causes it to have to be mounted right next to the grip.
i.e. You can't mount it on the other side of a brake lever since it would hit the mount for the brake and you would not hit full throttle. ...
... ver use it.
callagga wrote:bought one to try out
Having some fun at the moment through trying to fit (a) handbrake, (b) gear lever & (c) throttle in a manner in which each is close enough...seems a little bit of a challenge.
callagga wrote:Hey Russell - do you think the throttle will be OK in the rain if you caught?
grwsaltspring wrote:Very interesting thread. Can anyone tell me how long the wire is from the trigger to the plug.
I'm in the process of converting my e-bike to an e-trailer and I need about 6 ft from trigger to the controller mounted on the trailer at the moment.
Cheers Greg
Russell wrote:UPDATE May 5, 2009:.... To do this I changed the 100 ohm resistor to 220 ohm and the 470 ohm to 1K-ohm.
Users browsing this forum: Bing [Bot] and 5 guests
