The Electric Boat Thread
Boats, Jet Skis, Kayaks etc., including hovercrafts
Re: The Electric Boat Thread
Postby Zoot Katz » Fri May 22, 2009 1:57 am
I sure liked the slipper design.
How large a rudder would need to be attached to a canoe?
Seems simpler than steering the prop shaft and no penalty if it only has to be as deep as the skeg or maybe kick up for beaching.
Zoot Katz
Postby dontsendbubbamail » Fri May 22, 2009 1:17 pm
I have been running a 17 lb trolling motor on an 18 foot canoe. Anything extra in the water in addition to the motor causes extra drag. It may be debatable as to how much drag. If there is any wind, it can push the canoe around and make staying on course or turning very hard to impossible unless I put a paddle into the water and use it as a dagger board. A small keel down the length of the boat would be a solution if you don't care about quick turns. I plan to make a bracket to hold the paddle so that I can take it out when not needed.
My vote would be for a removal dagger board and no rudder.
Bubba
dontsendbubbamail
Postby Jeremy Harris » Sat May 23, 2009 10:12 am
Zoot, I like the slipper design too, but it's a bit harder to make than a canoe, I think, plus would need a trailer. I'm using the canoe as a starting point, to see how well the motor etc works. If it's a success, then I think I may go for something a big bigger, like the slipper launch, with a fully solar power system. I doubt I'll be able to do more than augment the battery power with solar cells on the canoe, without having ungainly solar panels stuck everywhere. I should be able to mount enough cells on the canoe to get maybe 20 watts of boost though, which will make a significant difference to range, plus allow for solar charging whenever the canoe is sitting idle.
Bubba, Thanks for the tip about the directional stability. I think I'll add a small keel down the length of the canoe, both to fix this and act as a bit of hull protection. I'll carry a paddle as well, so I can use that for any really sharp turns, although I hope that just turning the motor will be enough most of the time.
Jeremy
Please ask questions on the forum, rather than by PM, as it helps others and you'll get a better range of answers.
Jeremy Harris
10 GW
10 GW
Postby dontsendbubbamail » Sat May 23, 2009 6:10 pm
You may want to consider some kind of remote steering. With my 18 foot canoe, if I sit at the back and tried to steer, the front would stick up in the air and act as a big weather vain. I solved this problem by making a transom that allowed me to put the motor directly behind the canoe. The head of the trolling motor was removed and the wires extended so that I could sit in the middle of the canoe to control the speed. A board was mounted in the place of the head and two ropes tied to the ends so that I could steer from the middle of the canoe.
A flat stern canoe would be my first choice even if it is not as efficient as a double end canoe. A well behind the rear seat is my second choice. My third would a transom like I have.
It is really cool as to how close you can get up to wild life with this setup. I have been cruising up a river and come within 25 feet of a heard of deer drinking from the river and not spooked them.
Bubba
dontsendbubbamail
Postby John in CR » Sat May 23, 2009 7:53 pm
Jeremy,
One thing to keep in mind with steerable thrust is that you want to build a stable canoe, since the thrust when turning will also try to make it flip. Of course batteries in the bottom will help counter that effect, but be careful with that high output RC motor.
John
John in CR
Postby vax » Sat May 30, 2009 7:16 am
I'm designing 5m electric/wind hybrid catamaran boat for some time now. This involves laser cutting plywood sections (0.5m distance) and filling the gaps with foam. Further I plan sanding it to right shape and finishing with epoxy resin.
Next step is taking negative mould.
It's modelled in SolidWorks, so I can easily transform it into laser cut files (*.dxf).
Motors will be dual 600W geared, from Chinese scooter. Direct shaft drive.
Otherwise I think it will have conventional sails (I happen to have them already), and perhaps ability to recharge batteries from props spinning when it's on sail power.
Or, maybe using wind turbine instead of sails?
Laser welding
vax
Postby paultrafalgar » Thu Jun 04, 2009 5:06 am
Sorry, nothing electric here, but I thought you might like to see:
http://www.hydroptere.com/~hydropte/_en ... 624#centre
If we knew what it was we were doing, it would not be called research, would it? Albert Einstein
A paranoid is someone who has SOME idea of what's going on. Allen Ginsberg(?)
If the greatest pleasure is giving, be selfish - give pleasure.
paultrafalgar
Postby John in CR » Thu Jun 04, 2009 11:05 pm
Vax,
It looks like you've got a lot of efficiency robbing surface area in those keels. I'd suggest taking a look at Bernd Kohler's anti vortex panels, which replace keels using a very small wetted surface area and use 0 additional draft for the basic hull shape in total contrast to traditional keels. see http://www.ikarus342000.com/Looseends.htm .
John
John in CR
Postby Jeremy Harris » Fri Jun 05, 2009 1:57 am
Like the hull shape, Vax, but I'm with John on the wetted area from the keels causing a load of added resistance. I've been reading up on this stuff over the past few weeks, mainly the work done by some of the good human powered boat people. They get a bit fanatical about reducing wetted area, as their "motor" power is very limited.
There's some good software about that allows pretty accurate modelling of performance. I'm still trying to get to grips with the rather awkward interface, but Michlet does seem highly regarded. Modelling your hulls in it, with and without the keels, would show what the effect was.
I'm just about done with my hull design, it's not dissimilar to your cat hull in some ways, a sort of cross between a canoe and a skiff, made from tortured ply. I'm currently building what I hope will be the last model, an eight scale version in 1/32" ply, to make sure the panel shapes I have are properly developed. Putting pseudo 3D bends into plywood can produce some really nice looking hull shapes I've found, plus it's a pretty easy building technique.
Jeremy
Jeremy Harris
10 GW
10 GW
Postby Lock » Sat Jun 13, 2009 4:29 pm
Rick just posted another youtube vid. From the post:
"This is a long slender pedal boat with an electric drive. The motor is a Turnigy SK 600W permanant magnet synchronous motor with 3-phase supply from a two small 12V batteries. The boat topped out at 10kph (5.4kts) while drawing 200W from the battery."
If you like this message feel free to donate BeerCoins (BTC) to:
1LxAXWmbjY6SeMf8r9HHhSKt6pWyPvWg6L
Toronto Electric Riders Association:
http://www.ebikeriders.com/
Canada, eh?
Lock
10 GW
10 GW
Postby John in CR » Sat Jun 13, 2009 5:53 pm
Lock,
Thanks for sharing but I'm sure Jeremy as well as myself want to build electric boats that are useful. Make the hull in the clip longer and it's likely to go faster on the same 200W. I'm looking at building a 1000-1500lb cat that can handle another 1000-1500lb of passengers, and is sturdy enough to be comfortable 30-40miles out in the ocean, and will achieve 6-7 knots (the high end of trolling speeds for sailfish, marlin, tuna, and mahi, which a prevalent here "in season") using only 1200-1500W.
John
John in CR
Postby BMI » Sat Jun 13, 2009 11:11 pm
Hi to all you guys who are interested in large electric boats.
I thought I would post some info on an e-boat project here in case anyone is interested.
I am in the middle of a project where we are converting a 50 foot racing catamaran to all electric drive. This will be the most technologically advanced electric boat in the world when it is finished due to the advanced battery diagnostics and monitoring capabilities. It will be powered by three 5kW Power Pod retractable electric motors. We are just waiting for the motors to arrive from the US any day now. The 48V 240Ah battery bank is already at the boat yard waiting to be installed.
The boats' batteries will be recharged by solar panels, back-up diesel generator and re-generation (when the boat is under sail power in strong winds).
The boat has been entirely stripped out now in preparation for fitting of batteries, motors and all associated electrics.
As you can see from the below photos of the boat in its current state the boat looks pretty bare.
I will be happy to provide updates as to progress if there is interest here. There will be a full featured article appearing on this electric boat in at least two major boating/alternative energy magazines which will show to those involved in the boating industries what is currently achievable with regard to electric boat technology.
BMI
Postby Lock » Sun Jun 14, 2009 11:25 am
John in CR wrote:Lock,
Hi John. Understand!
From the original post:
Jeremy Harris wrote:The canoe I'm planning to build is the Selway Fisher Raven on this site: http://www.selway-fisher.com/Opcan16.htm. It's a ply, stitch-and-glue, open canoe. It seems to need around 40 watts or so to travel at 3.5 to 4 kts. It's maximum hull speed is about 5 kts, but it would need around 200 watts to reach it. My plan is to build a cruising boat that I can use to travel inland waterways and lakes at normal paddling speed, hopefully with some solar cells to augment range and allow charging when not moving.
The finished canoe should look like a scaled-down version of a typical Victorian electric river canoe like this one:
John
Understand. My interest in eboats is mostly about 40-passenger water taxis:
http://groups.yahoo.com/group/QCYCTender/
Here is a thread you might get a kick out of:
http://www.boatdesign.net/forums/hybrid/solomon-technologies-electric-wheel-electric-motor-propulsion-systems-676.html
...I got my first electric scooter "by accident" as a way to educate myself a bit about batteries and controllers and charges and electric traction generally. Had no idea what I was getting into (meaning not so much the tech but the politics.)
tks
lOCck
Canada, eh?
Lock
10 GW
10 GW
Postby John in CR » Sun Jun 14, 2009 5:07 pm
BMI wrote:Hi to all you guys who are interested in large electric boats.
BMI, yes definitely keep us posted on progress. Out of curiosity, did you slip a digit on the battery capacity, because that's only 11kwh of capacity, or 45 minutes of runtime with the three 5kw motors at rated capacity? For the 10m cat for which I'll soon kick off construction, my back of the napkin capacity plan is 15kwh. That is without any solar panels in the budget. What is the maximum output expected from your PV panels under optimum sun?
John
John in CR
Postby Lock » Sun Jun 14, 2009 7:02 pm
Beauty boat BMI! Who was her designer please (Shuttleworth?) Will you still be racing her? I understand the daggerboards as max. efficiency for racers, but if I were cruising her I would move to centerboards... (old Tornado sailor here)
tks
Lock
Canada, eh?
Lock
10 GW
10 GW
Postby BMI » Sun Jun 14, 2009 9:36 pm
John
Only the two outboard motors will be used for normal cruising. The central motor is designed as a manoevring motor so will not be used for most of the time. We expect to get a good hour of motor run time from two motors at leisurely cruising speeds.
We haven't worked out how many solar panels we can fit yet but I will let you know when we get to the stage of deciding.
BMI
Postby BMI » Sun Jun 14, 2009 9:48 pm
Lock wrote:Beauty boat BMI! Who was her designer please (Shuttleworth?) Will you still be racing her? I understand the daggerboards as max. efficiency for racers, but if I were cruising her I would move to centerboards... (old Tornado sailor here)
tks
Lock
I am not sure who the boat was designed by originally but will chase up the details for you and will let you know. I am only the battery supplier and electrical engineer on the project. I am designing the electrical systems for the boat for the electric conversion (both power and data). As far as the original boat design goes I will ask the boat's owner next time I speak with him.
Yes, she will still be racing. This is why we are waiting eagerly for the motors to arrive. The plan is to mount them on some kind of hinged panel so they can be lifted completely out of the water by a hoist/pulley system so as to not cause any drag while the boat is racing.
BMI
Postby John in CR » Mon Jun 15, 2009 10:18 am
tks
Lock
Lock,
Before installing any daggers or keels, look into Anti Vortex panels first. Less surface area so less drag, require no more draft than the hull itself, more effective because they reduce the water vortices that create drag and wake. Look at Bernd Kohler's work he has generously shared in the links on the right half of the page at http://www.ikarus342000.com/Looseends.htm
BMI,
Since it's a refit not a build, I assume that for the PV panels you aren't going with the ones that can be built right into the deck and walked upon. That's the route I'd love to go, if it wasn't so darn expensive. ie a craft covered almost entirely in PV above the waterline would be great. Add in about 1000lbs of lithium batteries, reefable wingsails for more efficient sailing with improved maneuverability (including reverse under sail), plus a nice size wind turbine for battery charging without sun or the need to be under way, and then you've got a near ideal boat.
I assume you plan to use BMI lithium cells. What is special about the BMS mentioned in your first post?
John
John in CR
Postby BMI » Tue Jun 16, 2009 6:06 am
tks
Lock
Lock,
BMI,
John
The type or number of solar panels which will be used hasn't been decided as yet.
There is a ferry here in Sydney Harbour which is absolutely covered in solar panels. It is called the "SolarSailor" and you can see it on the manufacturers website here- http://www.solarsailor.com/
When you see the boat close up it sure stands out from all the other boats with all the solar panels which cover her.
Yes, our boat will be powered by BMI batteries. Originally the boat was going to be fitted with more than half a ton of Trojan lead acid batteries. Then the owner of the boat looked into the capability of the BMI packs and decided on them instead. The total battery weight of BMI packs comes in a little under 200kg so is less than half the weight of the original Trojan battery bank for the same effective battery capacity.
The BMI batteries don't have a BMS but a VMS instead. There is a basic explaination of the VMS here-
http://lithbattoz.com.au/index.php?page ... iagnostics
The VMS allows for a laptop computer to be plugged in to a dedicated battery diagnostics panel mounted socket fitted in the boats instrument panel. The internal voltages of every cell in each of the battery packs can be displayed on the PC and errors for over charge, over discharge and over temperature are logged as is the total number of full accumulated battery cycles. The batteries have the ability of performing an automatic self check up to twice a day. If any cell in any battery is found to be out of specification or requires attention in some other way an SMS text message can be sent to the boat's owner or an email sent alerting him/her of the need to check the battery in question. Therefore the owner of the boat could be on the other side of the world many miles away from the boat and will know at all times of the condition of all the batteries in his/her boat.
BMI
Postby Lock » Tue Jun 16, 2009 8:22 am
Gawd I love that Solar Sailor. Hadn't checked their site for a long while now. Nice to see developments and growth (apparently) in the offing for them. Didn't see any pics of the "real" Solar Sailor at first, just computer renderings of future stuff, so my fav Solar Sailor pic:
John, tks for the link to Kohler's Anti Vortex work. Very interesting and will read later. Love the idea of built in swim platforms (smile)
...and I still say BMI's project is a Shuttleworth :)
Lock
Canada, eh?
Lock
10 GW
10 GW
Postby BMI » Tue Jun 16, 2009 8:40 am
Lock wrote:Gawd I love that Solar Sailor. Hadn't checked their site for a long while now. Nice to see developments and growth (apparently) in the offing for them. Didn't see any pics of the "real" Solar Sailor at first, just computer renderings of future stuff, so my fav Solar Sailor pic:
Lock
Wow...what a great pic and such a familiar sight to me as it heads out from Circular Quay and a bit past the Opera House.
I will have to take a pic personally and post it for you when I see the boat on my next trip in to the city.
BMI
Postby Lock » Tue Jun 16, 2009 1:26 pm
John in CR wrote:I'm looking at building a 1000-1500lb cat ....another 1000-1500lb of passengers ...sturdy enough ...comfortable 30-40miles out in the ocean, and will achieve 6-7 knots ...using only 1200-1500W.John
...been thinking about this. I know you mentioned wing sail (was sorry Walker was never able to make a go of his)... but 2HP approx for the electrics seems a little optimistic. Just thinking of tidal races and ocean currents where ya need a few knots across the bottom just to keep up with the water headed in the opposite direction! Especially in light airs. Or if you want to tow somebuddy or something... fight a fish? Hopefully your topsides will be super smooth too ta keep down the windage... Dick Newicks boats always had very "slippery" topsides:
http://www.jumpcut.com/view/?id=570EB9864F4711DB9FA92EF149F8C96D
BMI's "Room With A View" also looks pretty slippery...
tks
loK
Canada, eh?
Lock
10 GW
10 GW
Postby John in CR » Tue Jun 16, 2009 5:03 pm
tks
loK
Lock,
I want to take a shot at a charter fishing boat based mostly on a sailcat form, but primarily electric powered, in an effort to virtually eliminate fuel costs, which typically run $500-$1000/day here. I'm thinking $20-$50/day to fuel the generators for the higher power runs out and back, but run on batteries while trolling, which is at 5-7knots of water speed. I got the 1500W for 7 knots from the boat designer, but plan for some extra length as a hedge. It's that trolling at low speed for 6-8hrs on batteries that we want to be highly efficient. It's open ocean and I don't think direction matters, so with a biplane rig of small wingsails as assist, wind should only help our cause.
In addition to minimal fuel costs, boat motion will be far less than a monohull, and the lack of vibration and noise of a big diesel, will make for a far more pleasant outing for the passengers. Hell, this boat won't even have the sail flapping and rigging noise of a regular sailboat.
Regarding sailwings, there a plenty of functional ones, and they practically own the wind powered craft records on both land and water. Also, I'm look to size them for assist, not primary power, so that's last on the list and I'd probably just go with a pair of large surfsail rigs for the wind assist, and work on my ideas for soft wingsails after the concept is proven.
I'm confident that I can build a lightweight seaworthy boat. I'm no marine engineer, so I'm going on faith regarding the power requirements, but it doesn't take much to go relatively slow (well below hull speed with these aspect ratios) if you aren't dragging the big wake of a typical boat at 6kts, and under wind power these hulls have proven to do over 20 knots.
My main concerns are more about the concept working for deep sea sportsfishing. eg Does the noise and big wake pulled by a traditional rig attract the fish, but I think my last captain's beliefs were just old wives tales. If sound is an attractant, we can just drop a transducer underwater, and to me the wake only obscures the baits in tow. The patio sized deck will a tremendous advantage, but the devil will be in the details (setting up so the mate can easily get down to the water to haul in a 500lb tuna or marlin, etc.). One thing is for sure, it will be hugely different from current charter fishing, and I can't think of anything much more fun to test, so we'll see. Worst case, it doesn't work, and with small changes I convert it and sell it as a sailboat with a hybrid electric/diesel drive.
John
John in CR
Postby Lock » Sun Jun 21, 2009 2:45 am
BMI wrote:The boats' batteries will be recharged by solar panels, back-up diesel generator and re-generation (when the boat is under sail power in strong winds).
...or perhaps moored in a river or ocean current or tidal flows... Nice exerpt here from a vid about midaeval Paris with boats moored in the Seine river using water wheels turned by the current to mill grain(starting at 2:55):
tks
lok
Canada, eh?
Lock
10 GW
10 GW
Postby Lock » Fri Jan 08, 2010 4:52 pm
*Bump*
Nice site here (in German... ya can use Google Translate for English if ya like) showing more work with kort nozzels on a small eboat:
http://www.sinusleistungssteller.de/Brummer.html
...which leads to:
http://www.e-jet.org/
Their largest design (they are not in production yet):
E-JET-170L-8000:
Input voltage 24 to 48V
Input power up to 8KW
Thrust / bollard pull up 120kgf
Diameter 230mm
Rotor diameter 170mm
Length 170mm
9kg - Weight 9kg
Wundervoll!
tks
Lock
Canada, eh?
Lock
10 GW
10 GW
PreviousNext
Return to Electric Watercraft
Users browsing this forum: No registered users and 0 guests
