Voicecoil's red, fully rigid commuter
Re: Voicecoil's red, fully rigid commuter
Postby docnjoj » Sun Mar 22, 2009 10:00 am
That is in agreement with the observed 20 mph of my extra wide rear Bafang on 48 V nominal in a 20x2" rear wheel! Thanks Mark and Voicecoils!
otherDoc
E-bike stable at our house
Bike-e electric front brushed C/L
Steintrike Mad Max full suspension trike rear 9C
Sun USX delta trike 9C front wheel sort of front suspension
Frame of homebuilt trike in shed with Bafang still on it
New Agniusm/A123 on the Steini and old 10ah Ping paralleled with 12 ah Fatpacks on USX
My wife and I ride the trikes
docnjoj
10 GW
10 GW
Postby Mark_A_W » Mon Mar 23, 2009 8:12 pm
32kmh...at 48v.
That's just not fast enough. It'll need 72v to cruise at 45kmh....
Under construction: Giant DH Team, MAC Shanghai, Infineon 18 FET controller, 64v Headway battery. LINK!!
Retired: Kona Dawg Dually + Bomber Triple Clamp forks with Nine Continents front hub motor, 48v 10Ah Headway LiFePO4 Pack + 12v 10Ah Headway LiFePO4 booster pack (nominal 64v).
Powered by the sun :)
Dead: Jamis Dakar frame, Mongoose Pro Downhill frame, cooked Lipo booster pack....and various other bits and pieces...
Mark_A_W
Postby voicecoils » Tue Jun 09, 2009 8:04 am
New photos, the bike is running well. I've been running at various current limits with electrical power at 300-1200W. The battery box houses the controller, fusing and wiring. It's attached at the water bottle bosses and located by ally channel along the top. It's extremely solid, stainless steel with aluminium side panels. Great fabrication work from the Engine Whisperer :mrgreen:
(156.42 KiB) Downloaded 57 times
(171.89 KiB) Downloaded 967 times
(192.2 KiB) Downloaded 913 times
(121.53 KiB) Downloaded 50 times
voicecoils
Postby Toshi » Tue Jun 16, 2009 2:13 pm
that battery box is looking good! secure mounting is quite the issue for homebrew e-bikes...
Toshi
Postby voicecoils » Thu Jun 18, 2009 4:48 am
Toshi wrote:that battery box is looking good! secure mounting is quite the issue for homebrew e-bikes...
Thanks Toshi, With the water bottle mounts and a bit of bracing against the top tube, a solid mount is quite straight forward for a tough steel frame like mine.
The battery box with is surprisingly not an issue at all for pedaling and I've yet to knock my legs against it even though I do plenty of pedaling.
I'll get some close up photos of a few little details like how I turn the controller on and off externally, and how the side panel slides off soon.
I don't think the Bafang will stand the test of time so I'm already thinking of my future options. So far I haven't been able to bring myself to bolt that big 9continents motor to the front, the bike is already a handful to carry up quite a few steps in and out of my apartment. I carry it partially by the box and it hasn't bent or shifted out of alignment at all. If it did, I'd know because the crank clearance is so close!
voicecoils
Postby patrickza » Fri Jun 19, 2009 2:11 am
Good looking battery box! How wide is it, and does it feel the same pedaling or do you have to compensate?
Greyb.org, Cromotor, Headway 83.2v 20AH, Lyen 18 fet: viewtopic.php?f=3&t=45514
Kona Kahuna, x5305, Headway 76.8v 10AH, Crystalyte 72v48A: viewtopic.php?f=3&t=10256
Bladez Scoot, 450W motor putting out 3kW, Headway 38.4v 10AH, Lyen special controller: viewtopic.php?f=35&t=25872
patrickza
Postby voicecoils » Fri Jun 19, 2009 5:06 am
patrickza wrote:Good looking battery box! How wide is it, and does it feel the same pedaling or do you have to compensate?
Hey Patrick,
The box is just a touch over 130mm wide. The Headway cells are 120mm wide without tabs and heatshrink so it's a snug fit!
Pedaling is not affected at all, I haven't spaced out the crank arms or anything either. I does feel odd if I put both feet on the ground. That's when the width of the pack is noticed but it rarely happens. When riding or stopped with one foot on the ground it's no problem.
voicecoils
Postby johnrobholmes » Fri Jun 19, 2009 7:55 am
What kind of temps are you getting on your motor now?
_______________________
Volt up, gear down!
http://www.HolmesBikes.com -- Custom 15 -12ga spokes
http://www.VoltRiders.com -- Custom wheels, ebikes, and Mopeds
johnrobholmes
10 GW
10 GW
Postby voicecoils » Fri Sep 25, 2009 7:14 am
johnrobholmes wrote:What kind of temps are you getting on your motor now?
I'm flirting with the devil and riding with 16-18A limited now (@72v lifepo4). Motor gets warm but not hand burning. I expect winding temps to be very high though.
Have not quantified it with a temp meter...yet, sorry.
voicecoils
Postby voicecoils » Fri Sep 25, 2009 7:17 am
after searching for ages, I finally have a grommet that fits perfectly around the wires that come in and out of the box. Trottle, Cycle Analyst, phase wires, hall sensors, and a positive DC pigtail from my battery pack (the 'key' of the system) all come out of that hole. Now they're sitting on rubber and water will have a hard time finding it's way in. The box has: one screw to pull the side cover off, one charge port on the right side, and the grommet'd hole for the wires. That's it, nice and neat.
voicecoils
Previous
Users browsing this forum: adam333 and 5 guests
