Wooden bicycles, lots of pics
Postby spinningmagnets » Mon Jun 01, 2009 9:46 pm
If you Google "wooden bicycle" or even "bamboo bicycle" (use "image search" also look at "fun bicycles" and "odd bicycles") there's plenty of crude whimsical examples...but I was pleasantly suprised and more impressed than I expected. A "trash day" MTB can provide head-tubes, BB's, drop-outs,...and a selection of bikes can even be bought for $20 at thrift stores.
If you can't afford a custom metal frame that accomodates a motor you want to use, or you wish you had an expensive recumbent...
Tino Sana
Old chinese carpenter, Peijia Wu (crank rods ! no chain)
High school shop project, Marco Facciola
Close-up, wooden freewheel
Waldmeister, German work of art
Tandem work of art, Jens Eichler (plywood laminated, then shaped)
unknown Wooden MTB
West-8
Last edited by spinningmagnets on Sat Apr 23, 2011 1:24 am, edited 4 times in total.
spinningmagnets
10 GW
10 GW
Re: Wooden bicycles, some pics
Postby mrgarci1 » Mon Jun 01, 2009 10:11 pm
Tino Sana
Holy crap that is a nice lookin bike. My jaw actually dropped when I saw it.
Phat Seabreeze beach cruiser, WE BL 36 running 36v20Ah Headway
mrgarci1
Postby spinningmagnets » Wed Jun 03, 2009 2:47 pm
Here's a Renovo (expensive!) hollow wood frames available in a variety of woods and bamboo (Hickory, Cherry, Ash, Maple, Bubinga, Jatoba, Padauk, Sapele, special requests...)
Frame is CNC machined, ~$2,000+, http://www.renovobikes.com/r2-road/
Last edited by spinningmagnets on Mon Oct 05, 2009 7:40 am, edited 2 times in total.
spinningmagnets
10 GW
10 GW
Postby mrgarci1 » Wed Jun 03, 2009 7:24 pm
can u post the image again? didn't work properly.
mrgarci1
Postby spinningmagnets » Wed Jun 03, 2009 7:42 pm
(edit: moved link to pic above)
Last edited by spinningmagnets on Mon Oct 05, 2009 7:42 am, edited 1 time in total.
spinningmagnets
10 GW
10 GW
Postby Zoot Katz » Thu Jun 04, 2009 12:24 am
I'm surprised we missed this one:
Wood Bikes You Can Make
http://woodenbikes.com/
I forget where I got this one
(20.94 KiB) Downloaded 6856 times
This bike was on the show circuit in 2006.
BC timber, BC bicycle company
(71.29 KiB) Downloaded 6843 times
Zoot Katz
Postby spinningmagnets » Fri Jun 05, 2009 1:25 pm
After a while searching, you begin seeing the same examples. I resisted posting more, but for those who have read so far, here's the best of the rest I found.
Reinhold Eichhorn
Peter Dahlberg
Gota
Magni Vinicio
Giuseppi Matera
The Amazing Wooden Bike Company
Two from Igor Ravbar (steam-bent strips glued together and cured while clamped in a form)
Alan McKay
Howard Hung
Bernd Vonau, SWB recumbent
Jan Gunneweg
1940 Italian Borsari (wartime metal in short supply)
Last edited by spinningmagnets on Fri Jun 05, 2009 7:52 pm, edited 1 time in total.
spinningmagnets
10 GW
10 GW
Postby Lock » Fri Jun 05, 2009 7:42 pm
OK, wood only as "accent"/detail but I thought the Mars pretty elegant:
(139.36 KiB) Downloaded 49 times
(ps...why does this show only as link and not online pic?)
If you like this message feel free to donate BeerCoins (BTC) to:
1LxAXWmbjY6SeMf8r9HHhSKt6pWyPvWg6L
Toronto Electric Riders Association:
http://www.ebikeriders.com/
Canada, eh?
Lock
10 GW
10 GW
Postby spinningmagnets » Fri Jun 05, 2009 7:56 pm
Marrs electric cruiser 2008 (thanks, Lock!)
spinningmagnets
10 GW
10 GW
Postby Lock » Fri Jun 05, 2009 8:40 pm
Yer welcome :)
I think of this one too as a "woodie"... not sure why:
Canada, eh?
Lock
10 GW
10 GW
Postby Lock » Tue Jun 09, 2009 3:15 am
(27.15 KiB) Downloaded 6563 times
Canada, eh?
Lock
10 GW
10 GW
Postby Lock » Tue Jun 09, 2009 3:17 am
For the yachties:
Canada, eh?
Lock
10 GW
10 GW
Postby Lock » Tue Jun 09, 2009 3:22 am
For the yachies again:
(30.36 KiB) Downloaded 6511 times
Canada, eh?
Lock
10 GW
10 GW
Postby mrgarci1 » Tue Jun 09, 2009 8:53 am
Can that autocanoe be pedaled directly into the water? It looks like there are "paddlewheel" wooden slats attached to the wheels.
mrgarci1
Postby Lock » Tue Jun 09, 2009 10:50 am
Apparently:
Jeremy spotted it and posted in the Electric Boat thread:
http://endless-sphere.com/forums/viewtopic.php?f=7&t=9806&start=30#p153676
Autocanoe here:
http://www.autocanoe.com/
tks
Lock
Canada, eh?
Lock
10 GW
10 GW
Postby spinningmagnets » Tue Jun 09, 2009 3:01 pm
The "TJ Flyer" (Truss Joint) 3/8" Baltic Birch plywood over Laminated Veneer Lumber (LVL)
spinningmagnets
10 GW
10 GW
Postby Zoot Katz » Wed Jun 10, 2009 12:14 am
I forgot this one Justin found on the prairies.
Richard Pitre's bike made of hockey sticks:
Zoot Katz
Postby spinningmagnets » Tue Jun 16, 2009 7:13 pm
I found the Igor Ravbar bikes fascinating, made of steam-bent strips. I recently stumbled across a story about furniture making where strip wood was bent by applying the side of the strip to a hot-pipe (heated by an electric element or a small propane torch).
The heat partially melts the connective lignin "glue" between the fibers, and if clamped in shape while cooling, the strip will retain its bent shape. Gluing several similarly bent strips together makes a laminate that is light and strong with a certain amount of springiness to it, much like a laminated archery bow.
this site is for making guitars, but it had the best pics for the hot-pipe wood-bending method.
http://gicl.cs.drexel.edu/people/sevy/luthierie/guitarmaking_guide/side_bending/side_bending.html
spinningmagnets
10 GW
10 GW
Postby Lock » Tue Jun 16, 2009 9:17 pm
Wood is a fantastic building material. It is only important that 1)you dry the moisture content down to about 10% in the finished structure and 2)that you absolutely seal the wood completely to keep any moisture out after that.
tks
LoCk
Canada, eh?
Lock
10 GW
10 GW
Postby spinningmagnets » Sun Oct 04, 2009 11:25 pm
This is "Le Zelo", a homebuilt wooden recumbent tadpole trike from Boris Beaulant.
http://www.borisbeaulant.com/
From Sakari Messuilla
spinningmagnets
10 GW
10 GW
Re: Wooden bicycles, lots of pics
Postby spinningmagnets » Sun Oct 04, 2009 11:46 pm
From the "Atomic Zombie" website, Jon in Maryland
spinningmagnets
10 GW
10 GW
Postby Lock » Mon Oct 05, 2009 7:05 am
Beautiful things! Saw this concept the other day, here:
http://www.sandwichbikes.com/
...but it pales in comparison (although intended as super-cheap/easy to build...)
tks
Loc
Canada, eh?
Lock
10 GW
10 GW
Wooden fenders?
Postby spinningmagnets » Mon Oct 05, 2009 7:53 am
Here's a great link about making your own fenders out of thin wood. It looks like a great winter project when you're stuck indoors. You can make them very simple and classic, or as complex as you want if you have an artistic streak.
Once the thin wood substrate is shaped, you can take a razor blade and cut veneers into patterns of stripes, diamonds, or any shape you want to make a attractive skin to add. Add a coat a clear sealer and you're set. Home-made guitar websites have some great info with lots of pics on making a skin of attractive wood designs.
http://www.momentumplanet.com/components/how-make-your-own-wooden-bike-fenders
http://www.woodysfenders.com/store/
spinningmagnets
10 GW
10 GW
Postby def215 » Thu Oct 08, 2009 12:51 am
thats just amazing. i wouldnt think that bike could be made out of wood but that proved me wrong. there are some pretty cool designs that they have. how about building your own http://www.instructables.com/id/How-to- ... o-Bicycle/
Project: E-BMX - Completed, debugging.
Konion Powered!
viewtopic.php?t=14550
Project Min-E Ped:
viewtopic.php?f=35&t=25636
def215
Postby spinningmagnets » Thu Oct 08, 2009 6:49 am
Good find, def215, I have seen pics of bamboo bikes on the web, but the instructable you found had great info on the process, so a home-builder could make one themselves. I originally started the wooden bikes thread because I was interested in collecting info and examples of methods for construction used in the past, and I knew wood could be very strong and reasonably light if engineered properly. This would allow me to make a custom frame just the way I want (and I have odd taste). Pic is from bamboo-bike link above (frame ended up being VERY strong)
spinningmagnets
10 GW
10 GW
Next
Return to General Discussion
Users browsing this forum: e-beach, Peter Sternersson and 6 guests
