Jozzer wrote:Your already the guy to go to for the guys that other guys go to..
SpeedEBikes wrote:The iChargers aren't just power supplies.
mwkeefer wrote:
.... - on better supplies the likes which Methods uses - probably no pop fuse, no blown fet, resettable breaker? LOL...
mwkeefer wrote:Methods... what resistor do you use to short your cells out for balancing (kidding but I've thought of a simple 4v dissipator, single cell to draw down the higher cellls in a manual process durring charge until the slower cells catch up).
-Mike
methods wrote:That helmet saved my ass![]()
-methods
-methods
mwkeefer wrote:The IC chip (8 pin smt) is actually a TTL->USB level adapter used to interface to the MCU of your charger.
rscamp wrote:methods wrote:That helmet saved my ass![]()
-methods
Hmmm. Are you sure you put it on correctly?
methods wrote:Pffffft.....![]()
If you cant fix that you are weak-sauce.
I - personally - would spend the 36 hours it would take to repair/rebuild/reverse engineer all that.![]()
150 / 36 = $4.16 / hour for your efforts!
-methods
hurricaniac wrote:Does anyone see any red flags in using the following cheap bulk charger setup for a 12s3p Lipo 15ah (Using six Turnigy 6s1P 5000mah 20C packs)?
- 48V 20A server power supply with 20' of 17ga lamp cord to limit current
- CellLog8s to trigger a HVC device ("Improved simple auto disconnector for battery charging/testing" -- a DIY circuit in RC Groups: http://www.rcgroups.com/forums/showthread.php?t=1131817)
Thanks for any fire alarms you can pull in advance,
Bruce
(My wife made me write this after seeing lipo fires on youtube)
drewjet wrote:So I ordered myself 6 of the 6s 5000 MAH 20C Turnigy's. Got them in less than a week, WOW! Shipping at $69 kinda hurt, but even so, still a great price. Of the 2 I have charged so far, they are showing an Internal resistance of 1.3 to 1.6
Now the bad news.
1 Came with a slight puff on an end cell, and one came with a cell at 1.0 volts.
What should I do? Charge and see what happens? Send em back?
Suzuki SP200, Mars Brushless, 300 Amp Kelly Controller,(18S12P) http://www.evalbum.com/1511
Users browsing this forum: gknowes, melodious, mrzed and 8 guests
