zukster wrote:No one is getting back to me from above.
Does anyone have any suggestion on alternative products with the same properties or close.
Maybe something a little more common and available around town?
While far thicker in viscosity than water displacement sprays, it lends itself better to corrosion prevention than lubrication, so isn't really a chain lube. But I have every confidence that, reapplied twice yearly, it should minimise chances of internal corrosion in frames, trailers and racks, and eliminate the need to drill out corroded SPD shoe fittings - even on bikes living in coastal regions.
Affliction wrote:What good is acf-50 if it can't lubricate?
Affliction wrote:It is superior anti-corrosion compound.
It kills corrosion in progress
It prevents new corrosion cells from forming for 12-18 months
It is an excellent penetrant.
It is an excellent light lubricant.
This is good shit!![]()
If you can get this stuff then it has the same properties of Wurth Film.
All I see while searching this is websites in the UK.
I'd definately use it if it was availabe in Canukistan
Lube, corrosion, and penetrating.... all properties you want to protect your hub motor from the elements..
This is probably the same stuff rebranded! The wurth film has actually stopped all rust on my unpainted kickstand mount!
The mount has direct spray from the rear tire and none of the protection has washed off.
Maybe research a bit before posting...
Affliction wrote:Turns rust black? Sounds familiar.....
What kind of hub motor do you have Affliction? The Bafang looks mostly Aluminum inside. That might
explain the lack of rust. There was a bit of white Aluminum Oxide corrosion on the screw on cap, but that
was it. I made no attempt to plug the hole where the wires exit the motor through the axle on this hub.
On the other
hand, if water did not get in where the wires come out, I doubt it will get in the little hole (like you
said Affliction). Still I'll probably tap the hole an put in a bolt. ADD sucks eh?
Affliction wrote:What is black and blue and doesn't like sex? A: zuckster in my basement![]()
grindz145 wrote:A grease fitting would be sweet too, just pump it up with some new stuff once and a while and clean up the overflow...
johnrobholmes wrote:How about Corrosion X? It is a great product for motors.
Use CorrosionX to eliminate corrosion and protect all metal surfaces of your boat, trailer and dockside equipment. Especially recommended for brightwork (keeps stainless from pimpling), hatches, powerheads, antenna bases, hinges and latches.
CorrosionX is also the best lubricant you can use for maritime applications. It does not attract dust, outperforms lubricants fortified with Teflon* (PTFE), and due to it's unique polar bonding technology, CorrosionX repels water, and doesn't dissipate quickly or wash off in harsh saltwater environments. Use CorrosionX on throttle cables, steering mechanisms, seat swivels, locks, travelers, winches, pulleys, furling systems, tracks and on any other gear that would benefit from lubrication.
Due to its extraordinary dielectric properties, CorrosionX should be applied to all battery terminals, terminal strips, ignition switches, electrical connectors, circuit breakers, fuse holders, light switches, light sockets, electrical plugs, blower motors and fans to protect them from corrosion, extend their life and keep them working reliably. Although CorrosionX is inherently nonflammable, the environmentally-friendly propellant used in our aerosol cans is flammable. Please use caution when applying to electrical equipment. Before applying, make sure there is no current running though the system and that electrical motors are disconnected before applying.
.... This is the same crap as ACF50!It does not attract dust
Users browsing this forum: Moya and 10 guests
