Mag Max: compact 2-stage drive /w mag clutch brake regen
Assembling the Mag Max
Postby j3tch1u » Mon Jan 11, 2010 12:13 pm
Output shaft Matex part #U75-907.
j3tch1u
Postby j3tch1u » Mon Jan 11, 2010 12:17 pm
Bearing block using double stacked NSK-6301 37mm OD radial bearings. Gearhead assembly bolted together with 8 stainless steel M4 hex cap screws.
j3tch1u
Re: Mag Max: compact 2-stage drive /w mag clutch brake regen
Postby j3tch1u » Mon Jan 11, 2010 12:24 pm
Needle thrust bearing. 20mm OD stainless steel shaft collar provides better surface contact for 1-way clutch bearing.
j3tch1u
Postby kfong » Mon Jan 11, 2010 12:25 pm
Excellent, that was what I was envisioning for my Currie gearbox. The motor I have is longer, so I was planning to put the gear box along side it, with a chain or belt to connect to it. How did you get the second stage connected to the first stage or are the matex gears setup to stack? Looks like I will need to create a connecting rod between my two stages and was thinking I might need to have bearings on that connecting rod. I like the cooling fins you put in. I'll have to remember that when I do mine.
kfong
Postby j3tch1u » Mon Jan 11, 2010 12:29 pm
Fixed sprocket and freewheel. 1-way clutch bearing press-fit onto threaded adapter. Fixed sprocket and freewheel torque in opposing directions so they lock tightly together under motor or pedal power.
j3tch1u
Postby j3tch1u » Mon Jan 11, 2010 12:32 pm
Locking cap with needle thrust bearing fixes the dual freewheel assembly in place. The motor drive is now ready to mount.
j3tch1u
Postby j3tch1u » Mon Jan 11, 2010 12:46 pm
kfong wrote:Excellent, that was what I was envisioning for my Currie gearbox. The motor I have is longer, so I was planning to put the gear box along side it, with a chain or belt to connect to it. How did you get the second stage connected to the first stage or are the matex gears setup to stack? Looks like I will need to create a connecting rod between my two stages and was thinking I might need to have bearings on that connecting rod. I like the cooling fins you put in. I'll have to remember that when I do mine.
the matex gears "mate" together--1 side is female and the other is male :oops: it will not be easy to attach pulleys on these gearboxes--you will need to find someone to broach the pulley for you. you will also need bearings to support the sun gear. If you went single stage with that HXT it would still fit between the cranks.
j3tch1u
Postby 12p3phPMDC » Mon Jan 11, 2010 1:16 pm
Thanks for posting those inspirational assembly pics!
"If you don't follow your dreams, you might as well be a vegetable." Burt Munro
The reasonable man adapts himself to the world;
the unreasonable one persists in trying to adapt the world to himself.
Therefore all progress depends on the unreasonable man.
-- George Bernard Shaw
12p3phPMDC
Postby kfong » Mon Jan 11, 2010 1:38 pm
Thanks for the info, now I have a some idea of what I need to do. I still want to try putting them side by side. I like the setup as narrow to the frame as possible. I'll have to put bearing blocks for the sideloads and will use a freewheel and chain, but plans may still change as they always seem to do.
12p3phPMDC wrote:the matex gears "mate" together--1 side is female and the other is male :oops: it will not be easy to attach pulleys on these gearboxes--you will need to find someone to broach the pulley for you. you will also need bearings to support the sun gear. If you went single stage with that HXT it would still fit between the cranks.
kfong
Postby j3tch1u » Mon Jan 11, 2010 3:30 pm
kfong wrote:Thanks for the info, now I have a some idea of what I need to do. I still want to try putting them side by side. I like the setup as narrow to the frame as possible. I'll have to put bearing blocks for the sideloads and will use a freewheel and chain, but plans may still change as they always seem to do.
You could cut one of these couplings in half (Matex part #U75-902) and bolt them onto your pulley or alternatively use a Shaftloc type bushing.
j3tch1u
Postby j3tch1u » Mon Jan 11, 2010 3:33 pm
12p3phPMDC wrote:Thanks for posting those inspirational assembly pics!
np 12p. i hope others find it useful and even improve on the design.
j3tch1u
Monoblock battery module
Postby j3tch1u » Wed Feb 03, 2010 1:08 am
original thread: viewtopic.php?f=14&t=15408
this is a first cut of my monoblock termination cap. it is for a 12s pack. the material looks like kraft chedder (not sure what it is called) but it is cheap and my machine cuts thru it like cheese. after i nail down the feed rates and optimize tool paths, i'll cut one out of delrin for better durability.
the cells fit thru slots in the back and stack on top of each other without any spreaders. there are thru-slots for the tabs which are folded over each other and clamped with a 3mm copper plate. i may add 1.2mm flat springs (with slight curvature) to even out the contact pressure of the tabs and eliminate any possible voltage drop. in the middle of the block are channels for the balance wires. there are grooves in the back along the outer edge to secure 2mm carbon fibre panels for the housing. a matching end cap will lock the assembly together.
assembling each cell is very fast, safe and solder-free.
j3tch1u
Postby j3tch1u » Wed Feb 03, 2010 1:10 am
12s fechter/goodrum bms v2.2 mounted.
j3tch1u
Postby recumpence » Thu Feb 04, 2010 1:23 pm
Ahh, it makes me smile. :D
Matt
1% of the world's population can think "Outside the box". The rest are firmly stuck within the box. Where are you?
recumpence
10 GW
10 GW
Location: On Earth right now. That can change at any time, though..........
Postby johnrobholmes » Thu Feb 04, 2010 1:37 pm
Oh yeah! glad I ran across this build! What kind of efficiency do you expect from the reduction units?
_______________________
Volt up, gear down!
http://www.HolmesBikes.com -- Custom 15 -12ga spokes
http://www.VoltRiders.com -- Custom wheels, ebikes, and Mopeds
johnrobholmes
10 GW
10 GW
Postby 12p3phPMDC » Thu Feb 04, 2010 7:52 pm
http://www.matexgears.com/index.html
From Matex:
"High Efficiency
The module design ensures that the planets in the Matex gearset always share equal loads, resulting in 98% efficiency at a single reduction and minimal heat loss and noise. For each additional reduction step, efficiency loss is only about 3%.
So I would say the j3 two stage planetary drive is at 95% efficiency. :wink:
j3, awesome job on the battery assembly!!! 8)
12p3phPMDC
Postby j3tch1u » Fri Feb 05, 2010 9:37 am
12p3phPMDC wrote:So I would say the j3 two stage planetary drive is at 95% efficiency. :wink:
that sounds about right--they feel very smooth. lubed vs unlubed also makes a huge difference in noise. imho, these gears are a good alternative to belt-drive reductions.
j3tch1u
Postby johnrobholmes » Fri Feb 05, 2010 9:51 am
If only the average person could mate them up! Looks like you have above average means there 8)
Volt up, gear down!
johnrobholmes
10 GW
10 GW
Postby j3tch1u » Sat Feb 06, 2010 10:14 am
8 gauge terminal wires and balance taps connected.
j3tch1u
Postby j3tch1u » Sat Feb 06, 2010 10:25 am
Aerial view. Still need to make a top cover that integrates the cell-logs, XLR charger plug, mains plug and kill-switch. I'm thinking thick polycarbonate.
j3tch1u
Postby cell_man » Sat Feb 06, 2010 11:45 am
Looking really good Ben, lovely work :!: Fancy making a few more of the battery packs :?: :mrgreen:
http://www.emissions-free.com/ has just come online. It's a bit naff at the moment, but it can only get better :)
Drop me a line on emissions-free_worldwide(at)hotmail.com if you want to discuss any products I stock or you would like to source in the future.
cell_man
Postby bigmoose » Sat Feb 06, 2010 6:31 pm
Ditto's Ben. Very elegant design and execution. The cleanliness of your assembly and machine tools is impeccable! You must have worked in the nuclear industry or in medical implants?
I have always liked the packaging of a two stage planetary. I look forward to your efficiency findings and durability report. I wish there were more "stock" planetary parts available for integration into unique/custom power heads. Great thread, great build. :!:
bigMoose's electronic pieces & parts (GENUINE IRFB4110Pbf's, Nomex 410, AntiCorrosion Grease, Current Sensors) available HERE.
Thanks to Justin ebikes.ca for securing the board then setting us FREE! Tech Tips in the WiKi: http://endless-sphere.com/w
"Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God..." all the best, Dave
bigmoose
Postby j3tch1u » Sat Feb 06, 2010 7:00 pm
bigmoose wrote:The cleanliness of your assembly and machine tools is impeccable! You must have worked in the nuclear industry or in medical implants?
or just really anal-retentive :D
thank you for the encouraging comments guys, i don't know what to say :oops:
haha they better not let me near isotopes or breasts..i'd run amok. actually i studied industrial engineering but ended up starting an internet company (this is me http://en.wikipedia.org/wiki/Ben_Chiu). my anal-retentiveness was probably trauma induced--coding 1.5M lines of C++ for our search engine. ahhh the good old days when Java was but a twinkle in Sun's eye. i'm gonna go reminisce now :|
j3tch1u
Postby j3tch1u » Sat Feb 06, 2010 7:23 pm
cell_man wrote:Looking really good Ben, lovely work :!: Fancy making a few more of the battery packs :?: :mrgreen:
you get #0002 off the production lot :!:
i know a prototyping house that will do small runs..but it may be a while before i'm ready to pull the trigger on a final design.
i suppose your time-frame is "yesterday". maybe offer a dev-kit monoblock pack to active es contributors and low-cost, low-hassle, low-man-hours pack to everyone else?
integration is very time consuming and labour/service intensive. if i were you, i'd just focus on moving as many loose cells i could and ramp that volume up. try to reach a point where "the company that shall not be named" would sell to you in case your other source dries up.
j3tch1u
Postby johnrobholmes » Sat Feb 06, 2010 11:58 pm
Very sound business advice there, and it looks like your life has been pretty interesting up to this point Mr. Chui :mrgreen:
Can't wait to see what you do next, this is quite the clean build. There is elegance in all of it.
Volt up, gear down!
johnrobholmes
10 GW
10 GW
PreviousNext
Users browsing this forum: crossbreak, Google [Bot] and 8 guests
