New Bosch drive system
Re: New Bosch drive system
Postby boostjuice » Fri Sep 03, 2010 1:22 am
boostjuice
Postby markobetti » Fri Sep 03, 2010 2:47 am
Hey Miles, do you have anything you want me to take picture for you ? Or to ask ?
Tommorow im there so just ask
markobetti
Postby Miles » Fri Sep 03, 2010 3:04 am
Lots of close-up pics from different angles would be nice.
I'm more interested in the Pinion gearbox [Hall A2, stand 113]. Perhaps you could get a price for that?
Also, say hello to Doug White on the ENO stand, for me. :)
Miles
Postby Miles » Fri Sep 03, 2010 3:15 am
In case anyone's interested, here's the patent for the Bosch drive: http://v3.espacenet.com/publicationDeta ... cale=en_EP
Miles
Postby markobetti » Fri Sep 03, 2010 3:16 am
Miles wrote:Lots of close-up pics from different angles would be nice.
I'm more interested in the Pinion gearbox [Hall A2, stand 113]. See if you can get a price on that?
NO PROBLEM, I AM ON IT !
markobetti
monday morning , everybody check picts and prices i got here :) psssst....this is undercover ES covredge ...:) :)
markobetti
Postby Miles » Wed Sep 08, 2010 7:10 am
Miles
Postby Miles » Wed Sep 08, 2010 1:30 pm
Miles
Postby markobetti » Wed Sep 08, 2010 2:35 pm
thanks Miles, i havent seen Cannondale, hadnt enough time
markobetti
Postby jmygann » Wed Sep 08, 2010 2:51 pm
I wonder if there will be any 750-1500 watt drives for off road ?
A cannondale semi recumbent with drive would be nice ...
48 V Semi-recumbent
jmygann
Postby Hillhater » Wed Sep 08, 2010 7:42 pm
who will be first to get one of these and try an uprated motor ? :shock: :lol:
Hillhater
1.21 GW
1.21 GW
Postby Miles » Thu Sep 09, 2010 12:20 am
It sounds like it won't be easy to get hold of the drive, separately... "The new push assist will be exclusively shipped to OEMs; no upgrade kits are planned." Ref: http://www.bosch-ebike.com/en/downloads/PI7066.pdf
Miles
Postby Kraeuterbutter » Mon Sep 13, 2010 12:26 pm
jateureka wrote:This sounds similar to the Aprilia Enjoy, Giant Lafree and Panasonic pedelec type systems, but with the benefit of a speed sensor.
its not only this...
compared to the panasonic-drive it realy powers the shaft were the pedals are mounted (don´t know how to name it in English)
the Panasonic-systems needs a extra pinion, which is small as well... (11 or 12 teeth)
that means: a lot of wear to the chain and the pinion, dirt, ...
the Bosch-Systems does not has a additional pinion, the power goes directly to the shaft were the pedal and the big wheel for the chain is mounted..
perfekt
here a picture of another combilation:
Hai-bike (a German bikemanufactor and his version of a BOSCH-powered e-bike)
i.m.o.p. very nice
http://www.eurobike-show.de/eb-wAssets/ ... 100441.jpg
Kraeuterbutter
Postby Miles » Mon Sep 13, 2010 12:57 pm
Kraeuterbutter wrote:the Panasonic-systems needs a extra pinion, which is small as well... (11 or 12 teeth)
perfekt
Hi Kraeuterbutter,
I think you mean sprocket (or cog), rather than pinion... [If you're in doubt about English terms, do a search on Google images :) ]
The advantage of driving the chain directly is that it requires less reduction from motor speed, of course.
Miles
Postby Kraeuterbutter » Tue Sep 14, 2010 12:29 am
oh, you are right of course...
pinion = Zahnrad
sproket = Kettenblatt
and i meant the sproket
Kraeuterbutter
Postby MitchJi » Tue Sep 14, 2010 2:01 am
Hi,
Hillhater wrote:who will be first to get one of these and try an uprated motor ? :shock: :lol:
Miles wrote:It sounds like it won't be easy to get hold of the drive, separately... "The new push assist will be exclusively shipped to OEMs; no upgrade kits are planned."
Wouldn't be easy to fit it into a frame either. Buying it with a bike and either replacing the controller or the controller and the motor would be much easier and admittedly much more expensive .
Kraeuterbutter wrote:here a picture of another combilation:
Hai-bike (a German bike manufactor and his version of a BOSCH-powered e-bike)
i.m.o.p. very nice
I like that too. Thanks for posting it.
Miles wrote:I think you mean sprocket (or cog), rather than pinion...
It drives the crank using gears? Thats mainly (except for possibly a small loss of efficiency) an ease of implementation advantage which would be huge for Matt with a 4 turn Astro 3210. Not so much for Bosch developing a custom 250 watt system of integrated components. So from a users point of view I don't think that invalidates any of Kraeuterbutter's points.
Miles wrote:I'm more interested in the Pinion gearbox [Hall A2, stand 113]. Perhaps you could get a price for that?
Now I'm curious. What's the "Pinion gearbox"? Link please?
Best Wishes!
Mitch
MitchJi
Postby Kraeuterbutter » Tue Sep 14, 2010 2:35 am
here another bike from another German manufactor:
Rotwild:
http://www.pedelecforum.de/forum/imgcache/4163.png
http://www.pedelecforum.de/forum/imgcache/4164.png
here a video of the cannondale concept-bike you maybe already have seen:
http://www.youtube.com/watch?v=NWE43VkXXJk
here how the bosch looks like inside:
http://www.pedelecforum.de/forum/attach ... 1283709685
http://www.pedelecforum.de/forum/attach ... 1283709710
seems to have beveled gears at first stage for quietness
and also a relativly high reduction with that 2 stages
Kraeuterbutter
Postby Kraeuterbutter » Tue Sep 14, 2010 2:45 am
MitchJi wrote:Hi,
hmm.. of course you will loose the assist-features (torque-dependent assist) by doing that
250Watt the 25km/h version
and there will also come a faster version, with i bet 300 or 350Watt (maybe even 500Watt (??))
well: 500Watt for a drive that uses the gears is in my opinion anyway too much (drains the batteries too fast, too strong from feeling)
that was maybe one of the coolest things shown on the Eurobike 2010 !
http://www.pinion.eu/en/
(the English version of the page)
in short: 18 gears (!!!! no overlapping gears)
but: it will not be on the market so soon..
and: it will most likely be costing more than a Rohloff Speedhub
German engineering, what else to say ? ;)
Kraeuterbutter
Postby Kraeuterbutter » Tue Sep 14, 2010 2:49 am
http://www.pedelecforum.de/forum/imgcache/4140.png
nice bike...
this, combined with a motor would be killer...
maybe something like the Gruber-Assist, small, light, hidden in the lower tube of the frame, working together with the 18-gears-gearbox
the lowertube is mostly bigger in diameter than the shaft of the seat, so the "Gruber-assist"-like drive could have more diameter for more power, maybe 250Watt instead of only 100Watt like the gruber Assist.. and: lower rpm: it should be possible to make it much more silent too...
that would be dreambike for me ;)
Kraeuterbutter
Postby Miles » Tue Sep 14, 2010 3:22 am
Miles
Postby Miles » Tue Sep 14, 2010 3:35 am
MitchJi wrote:So from a users point of view I don't think that invalidates any of Kraeuterbutter's points.
I wasn't intending to imply that it did - just a possible reason for the decision....
Miles
Postby Miles » Tue Sep 14, 2010 3:37 am
Kraeuterbutter wrote:here how the bosch looks like inside:
Thanks a lot for the internal views, Kraeuterbutter.
Miles
Postby novembersierra28 » Wed Sep 15, 2010 4:37 pm
I agree...hear hear
rkosiorek wrote:
Mark_A_W wrote:Great.
Another useless 250w/25kmh system.
Completely pointless at that power level, unless you are disabled.
And it's already illegal here as it is too powerful :roll:
the able have the use of arms, legs and other appendages. the disabled do not. if any thing the disabled need even higher powered transport as most would be unable to assist the motor in any way.
i consider statement insulting and ill concieved.
rick
It is amazing how much you can accomplish when it doesn't matter who gets the credit
Harry Truman
Plasma Boy Jr.(11months ago) knew physics, several books later I built my first PCB balancer + A123 battery pack
Etek 300a Curtis 9.2ah A123 lifepo4 16s4p 59.5mph
crazy video 0-94km/h in 6 seconds http://www.youtube.com/watch?v=FEGyLBg0kDM
novembersierra28
Postby Matthijs » Mon Mar 28, 2011 7:04 pm
Matthijs
Postby mabman » Mon Mar 28, 2011 11:43 pm
Czech test here of the Haibike: http://translate.google.com/translate?h ... anek%3D902
I like the way they put the motor on top of the frame for protection. Nice to start with a blank slate I guess. Although Cannondale uses the Bosch and missed this feature it seems. Pricing 3500usd - 4600usd which is about a grand higher than BionX equipped EU spec bikes so it makes me wonder how much a Bosch system is selling for OEM?
mabman
PreviousNext
Users browsing this forum: No registered users and 6 guests
