ES DIY Motor Challenge
Re: ES DIY Motor Challenge
Postby olaf-lampe » Sun Apr 18, 2010 1:32 pm
enoob wrote:
... wich if im correct may actually work i just havent spent enough time working all the possible connection combinations.
If you like, give me the number of slots and magnets and I work something out for you. My goal was always to have a motorwinding with a low I0 and low cogging. They didn't reach the highest possible power/weight ratio but had a broad band of useful RPM.
-Olaf
olaf-lampe
Postby enoob » Mon Apr 19, 2010 2:10 pm
welll. now theres an offer i wont refuse. even have enough parts laying round to send a copy (should we get is working) in lue of time spent on this with me.
thank you very much .
18 magnets . 42 slots.
the magnet count can be changed very easily the slot count would be a tad more time consuming but im willing to takle either one.
at this point i had intended to try a few combos i suspect may work and then commit to a rewind as that seems the best . to reduce magnet count ill have to increase the spacing between each .
the thread on how that little motor came around took a few turns but here it is . viewtopic.php?f=30&t=14264
M.E.N.S ex pres and charter member.
enoob
Postby olaf-lampe » Tue Apr 20, 2010 8:02 am
YUK!
42 slots mean 14 slots/phase. That doesn't leave much room for phantasy. You can either divide 14/2 or 14/7 or don't divide at all.
Following the non_divide route I found a minimum of 28 magnets ( 14 pairs ) as a useful combination. Winding scheme is A1B1C1...A14B14C14
That would also work with 7*2 tooth, scheme is then A1a1B1b1C1c1...A7a7B7b7C7c7
I hope you are familiar with this description?
The magnet diameter shouldn't be bigger than the head of the tooth.
You're not planning to build a hallbach array this time? Or did you think of 18 mag's where 3 mag's build a 45°hallbach trio?
I'll try to figure that one out...
-Olaf
olaf-lampe
Postby enoob » Tue Apr 20, 2010 11:28 am
no hallbach for a while . figured ill get some conventional stuff under my belt before i start down that path. do still like the idea though
thanks for the time. the winding scheme description is not my bread and butter but i am familiar with it. looking at my notes (wich are horrible) i was using to different info sources and at the time not seeing the whole picture . learned i did.
in an effort to maintain magnet fill and use the same magnets ill make a run at a custom stator.
If i could bother you one more time ? going with the 1/2 inch diameter mags x 18 what would be the optimal slot count. ? and winding scheme ?
thanks again olaf-lampe
enoob
Postby olaf-lampe » Wed Apr 21, 2010 8:54 am
enoob wrote:no hallbach for a while . figured ill get some conventional stuff under my belt before i start down that path. do still like the idea though
Always welcome, :)
with 18 mags, the best suitable number of slots would be 27. The diameter of the rotor is something above 93mm ( sorry no inches :oops: )
I would make the airgap as small as possible, because of the odd surface of the mags.
I would rethink the use of rounded mags here, because the inner ironring for the rotor is pretty difficult to build. Maybe you can build a simple ring and glue on the mags with ironpowder/epoxy mix up to the lower half of the mags. But I wouldn't bet on any high RPM capability...
As a prove of concept it would work, but how much would you pay for useable mags?
You can still use them as a charming bracelet :D
Olaf
BTW: If you want something easy to diy a BLDC check ebay for Studer / Revox A77 motors from old HIFI- bandmachines. I have some mags for them, too.
(206.04 KiB) Downloaded 1206 times
olaf-lampe
Postby Miles » Wed Apr 21, 2010 9:28 am
olaf-lampe wrote:BTW: If you want something easy to diy a BLDC check ebay for Studer / Revox A77 motors from old HIFI- bandmachines. I have some mags for them, too.
I used to have a Revox A77 MkIII :)
Miles
Postby olaf-lampe » Wed Apr 21, 2010 11:03 am
I used to have a Revox A77 :)
You meant, you had had 2 potential 4kW motors! :wink:
BTW B77 also works and some capstan motors have a different mount and shaft, but actually it's the same.
I have a dozen or so of these motors, shipping to UK would be no prob 8)
Olaf
olaf-lampe
Postby amberwolf » Thu Apr 22, 2010 4:40 pm
There's a Revox almost exactly like the one in Miles' pic about two feet from my head; can't recall the model#. Unfortunately A) it's not mine and B) I need it to continue the project of getting all my old open-reel stuff onto the computer. ;)
Another source of really nice BLDC motors is old Sony 1" VTRs used in studios. A friend of mine had a few of the VTRs scrapped from somewhere, and saved everything *except* the motors, which he tossed. :roll: If he'd thought about my bike project he'd probably have saved them for me, but it didn't occur to him for some reason. :cry:
I still have the driver boards for them; have salvaged a number of transistors, FETs, heatsinks, etc. Also some nice giant electrolytics out of the power supplies.
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Re: ES DIY Motor Challenge (was "competition")
Postby AussieJester » Thu Apr 22, 2010 5:56 pm
liveforphysics wrote:
My motor will be matching the KV of these motors, likely around 1/5th the weight, and easily half the inefficiency of these alternator/motor conversions.
So how is this motor going, been 4 months any progress? IIRC all the material have arrived?
Has anyone got a motor up and running yet? Besides enoob...
KiM
AussieJester
Postby karma » Thu Aug 19, 2010 8:08 pm
any updates :D
karma
Postby sackspeed » Tue Aug 24, 2010 1:12 pm
I´m new here in this forum. We have a projekt page in Germany called "Powercroco". One guy has
developt a bike motor few years ago.
http://www.powercroco.de/24N28P6530.html
These motor was not make of best material. So if it improfe by a few detail it will be very good to built a nice small motor. :D
Mario
NuVinci + 1200W, Full suspension
sackspeed
Postby Miles » Tue Aug 24, 2010 1:41 pm
Welcome Mario!
Coincidentally, I posted a link to that motor 3 days ago, as an example of a 24N 28P winding scheme... :)
Miles
Postby sackspeed » Wed Aug 25, 2010 5:24 pm
sorry Miles,
I see it. The problem of the design are the stator iron sheets. You can get only sheets of 0.5 mm. With 0.35 or 0.2 mm sheets the motor
will work fine. Perhaps you know this site at Powercroco?
http://www.powercroco.de/24N28P6520.html
sackspeed
Postby Miles » Wed Aug 25, 2010 5:39 pm
Mario,
Yes, I know the site. I actually corresponded with Dr Okon about this motor, five or six years ago.
Miles
Postby liveforphysics » Thu Aug 26, 2010 12:26 am
Great to have you here Sackspeed. :) I've used the powercroco site as a reference for various projects about a hundred times or so. :) Thank you for your work.
liveforphysics
Postby Arlo1 » Mon Aug 30, 2010 3:20 am
Luke you still working on this?
Ok so..... If my motor was liquid cooled for this chalange would we weigh it in dry?
And Dave who has some good deals on STUF
[color=#FF0000][b][size=150]Never above 4.2v never below 2.7v EVER!!!
Arlo1
Postby Miles » Mon Aug 30, 2010 3:27 am
Arlo1 wrote: If my motor was liquid cooled for this chalange would we weigh it in dry?
LOL! You'd weigh it dry and you'd have to run it dry :mrgreen:
Miles
Postby Arlo1 » Mon Aug 30, 2010 9:46 am
Then Im out cause I got a realy good idea! Like so good I cant belive its not already in use! :mrgreen:
Arlo1
Postby Miles » Mon Aug 30, 2010 9:54 am
There's usually a reason.....
Give us a clue......... :)
Miles
Postby existerion » Thu Nov 18, 2010 6:58 am
Hy,
We build such a motor in small series for our prototype scooters.
Data:
2,8kg
Continuous: 5,69Nm at 2395rpm and 1653W in 86,3% efficiency
Max: 8,58Nm at 2252rmp and 2482W in and 81,5%efficiency
We could probably sell them at 1000$ at this stage.
http://www.youtube.com/watch?v=FvOFFiFQ8I0
existerion
Postby modern_messiah » Thu Jan 06, 2011 5:59 am
Sorry if it's been covered but does it matter if it's a standard BLDC or a AF motor?
I'm building a AF motor and if it works I'll put the stats up here. Note that I did no maths for the design - I simply picked my desired size and went from there. Everything else is 'as much as I could fit within the desired frame'. Also nice and cheap material wise - no hallbach/litz wire craziness going on in this house!
modern_messiah
Postby Miles » Thu Jan 06, 2011 6:21 am
modern_messiah wrote:Sorry if it's been covered but does it matter if it's a standard BLDC or a AF motor?
No. All motor types allowed.
Miles
Postby AussieJester » Thu Jan 06, 2011 6:33 am
Would be great to actually see a motor, any motor LoL... been alot of talk since Sat Nov 28, 2009 5:05 pm
when this thread was started and IIRC not a single motor tested yet.
KiM
AussieJester
Postby Thud » Thu Jan 06, 2011 6:35 am
LOL AJ.
........WHO will be first?.........
get some......
Thud
Postby modern_messiah » Mon Jan 10, 2011 3:29 am
Money permitting I'll have mine done...this year lol. ASAP would be great (was aiming for May-ish), but I'm almost scared to send my design to the laser shop for cutting. It's fairly intricate $$$$.
modern_messiah
PreviousNext
Return to Motor Technology
Users browsing this forum: No registered users and 0 guests
