HF Harbor Freight Headzup Thread
Postby TylerDurden » Sun Nov 23, 2008 2:38 pm
OK cheapskates, Here is a topic just for y'all: interesting stuff at HF. Good, bad, great, whatever.
Recently saw:
http://www.harborfreight.com/cpi/ctaf/d ... mber=98674
$40, Includes SPL metering...
High current fuses are cheap, 3@ $3:
http://www.harborfreight.com/cpi/ctaf/d ... mber=65157
30A, 40A, 60A, 70A, 80A, 100A
Please add your comments/finds/queries.
Have a Nice Day,
TD
FYI: Adding pictures?
TylerDurden
Re: HF Harbor Freight Headzup Thread
Postby Doctorbass » Mon Nov 24, 2008 5:31 pm
TylerDurden wrote:OK cheapskates, Here is a topic just for y'all: interesting stuff at HF. Good, bad, great, whatever.
Recently saw:
When you say SPL metering... DO YOU MEAN SOUND PRESSURE LEVEL METERING????
Doc
________________
-Fastest speed record from now: 113 km/h measured on GPS
-Fastest ebike 106km/h on flat and managed to enter in the 19.875 sec on the 1/4 mile drag racing !
-0-70km/h in 5sec X5 5303 on 24"
TORQUE SETUP:
-Team Konion Member
113kmh Giant___http://www.evalbum.com/3406
Mongoose____http://www.evalbum.com/1947
E-trike_______ http://www.evalbum.com/3776
I speak FRENCH and english
Doctorbass
Postby TylerDurden » Mon Nov 24, 2008 7:54 pm
"Measure sound level, luminance, humidity, and temperature, as well as electrical current and voltage, with this digital multimeter."
Freak counter too. :mrgreen:
Have a Nice Day,
TD
TylerDurden
Postby JinbaIttai » Mon Nov 24, 2008 11:02 pm
It's got a thermocouple input too. Not too bad.
Am I the only one that has ever baked a chicken using the temp probe on their multimeter?
Chassis: Schwinn S-30 Engine: Ampedbikes rear hub Fuel system: Ping 48V 20AH V2.0 split in half
Lighting:One P7 flashlight, One SST-50 flashlight, Two Planetbike Superflashes
As of April 30:
Battery: 955 miles and 88 cycles--5 dead pouches replaced to date
Motor: 1215 miles
JinbaIttai
Postby TylerDurden » Tue Nov 25, 2008 5:39 am
JinbaIttai wrote:Am I the only one that has ever baked a chicken using the temp probe on their multimeter?
I used to use an oven and a paper bag coated in butter.
Interesting to see the DMM has luminance metering too, so with one meter you could check:
    LED headlight output
    Pack voltage
    Controller frequency
    Motor (or stereo) volume
    Motor (or chicken) temperature
Framebuilders might be interested in this tubing bender:
http://www.harborfreight.com/cpi/ctaf/d ... mber=99736
    Great for fabricating exhaust, roll bars, and more
    Includes 1/2", 3/4", and 1" tubing rollers
    Incrementally creates the bend for precise control
Unlike hydraulic pipe benders, this thing is for tubing.
Have a Nice Day,
TD
TylerDurden
Postby marty » Tue Nov 25, 2008 10:42 am
Bought metric tap and die set from Harbor Frieght. Forget which one? Used once and wore the threads off a tap. Junk :( Returned and got my money back. Bought single tap from local industrial supply place. Works fine.
ebikes.ca
Online resource for electric bicycle conversions
http://www.ebikes.ca
MARTY
Volt Electric Vehicles
http://www.voltev.com
marty
Postby TylerDurden » Tue Nov 25, 2008 11:17 am
Have a Nice Day,
TD
TylerDurden
Postby vanilla ice » Tue Nov 25, 2008 11:44 am
marty wrote: Used once and wore the threads off a tap. Junk :(
Thats the thing with HF, the big question for me would be this- did the tap get you through that one use? Whats the cost per use versus the real industrial supply item? Sometimes even though it is junk, for hobbyists HF comes out on top in the cost comparison. Professionals are going to go with the fancy stuff that feels buttery smooth in their hands, lasts forever, and rightfully so.. my buddy has nothing but snap on. I'll use a few tools every other sunday.. It'd be ridiculous for me to go snap-on, but he makes his living as a mechanic so it makes perfect sense for him.
75# ebike, 190# scooter, 370# motorcycle, 1900# car, 4900# truck..
vanilla ice
1.21 GW
1.21 GW
Postby D-Man » Fri Dec 05, 2008 9:36 pm
Need cheap steel for torque arms/safety arms? Here it is:
408 front hub
11000+ miles on sla's.
Michelin pilot sport 2.3
Miles 50
Flats 0
Quality posts will not be sold.
D-Man
Postby TylerDurden » Tue Jan 13, 2009 10:35 pm
Haven't got it yet, but if it's any good at all, it's a steal.
Makes faster and better crimping connections, and saves time and labor.
Crimps 12 to 00 AWG copper and aluminum wires
Includes 9 pairs of chrome-plated steel crimping dies
Dies can be used at multiple angles for easy crimping from any direction
On/off knob on handle for easy ram retraction
Vinyl-dipped grip for comfort and control
Powder-coated jaws
Ram travel: 3/8"; Maximum crimping force: 8 tons; Crimping range: 0-0.45"; Die sizes: 00, 0, 2, 4, 6, 7, 8,10 and 12; Overall dimensions: 12" L x 2" W x 7-1/4" H
Weight: 5.1 lbs.
ITEM 66150-0VGA
$59.99
http://www.harborfreight.com/cpi/ctaf/D ... mber=66150
Have a Nice Day,
TD
TylerDurden
Postby auraslip » Thu Dec 02, 2010 11:07 pm
Old thread......
But I wonder about the high amp fuses...or rather I wonder about what you stick them in. Aren't ATC fuse holders rated at 20amps? I've seen pictures of melted ones, so I'm just wondering...
auraslip
1.21 GW
1.21 GW
Postby marty » Tue Feb 21, 2012 10:51 am
Bought 6" Composite Digital Caliper Item # 93293
$9.99 I am happy.
Mine is black.
ebikes.ca
MARTY
marty
Postby itchynackers » Tue Feb 21, 2012 1:06 pm
I have that same caliper. Worked good for one summer. Then wouldn't turn on. Replaced the batteries. No go. To the trash bin.
9c 9x7f w/ 12awg phases
9c 8x8r w/ 10awg phases, temp sensor, vented
9c 6x10r w/ 10awg phases, temp sensor, liquid cooled, 3rd Place Pikes Peak 2012!
"Don't argue with the galactically stupid...they drag you down to their level and beat you with experience"
itchynackers
Postby chisixer6 » Tue Feb 21, 2012 9:47 pm
On the topic of rotary tube bender, warren B. or www.recumbent.com, who is building(has built) a chopper from scratch.
he has a video of using it.
Motobecane ..bafang front driver.. 42v
24" girls bike ..ebikekit 20" fwd..75v
24" Schweinn 9c 20"rwd 75v
26" Schweinn Yescomusa 48v 800watt dd
Easy Racer clone LWB.....24" rear e-bikekit 48v ..ready for testing
Hooligan clone , longer rear chain stay.. twin 20"...
fun bike...twin 16" wheels. small rear motor... ready for testing
convert my CLWB recumbent to a front bafung@48v..ongoing
chisixer6
Return to E-Vehicles General Discussion
