hillzofvalp wrote:Is there a way of drilling perfectly spaced holes in aluminum without a jig? I just marked them with pencil but I can never get them all absolutely perfect in line. Is there a tolerance with hole placement? I haven't ordered my motor yet to test fit.
hillzofvalp wrote: Btw, if you think that posting in your thread is inappropriate, I will start my own thread. I see it more fit to start one when I actually have a prototype.
hillzofvalp wrote:Lastly, would it be possible to rewire a servo tester with a different form factor pot? couldn't I fashion a nice trigger I can mount on my handlebar out of an old rc remote and wire it in into a servo tester? This way you could incorporate a spring mechanism that is more practical than physically turning the pot down when you want to slow down, very similar to thumb throttles. Here's the assembly out of the stock Losi Mini t RTR:
am I missing something, or is this not the easiest way to go?
adrian_sm wrote:I rode with two 5s5000mah 20C LiPo's, in a little frame bag.
Here are the stats from the Watt Meter, for this little 11km ride which is a part of m normal commute to work, including the worst couple of hills.
2179.1 Wp - Peak Power
120.46 Ap
8.012 Ah
148.5 Wh
Ebikes are cool. This system really doesn't have much down sides. It hardly adds any weight to the bike, it has zero impact on the rolling resistance, your bike just feels like it always did. Then when a hill comes up, a little push of your thumb and it flattens out. It makes a bit of a whine to let you know it is working, but the pedestrians I passed didn't turn heads trying to find out what it was. Once I iron out a few more bugs, and bolt this on to my road bike, I think this may just become my main ebike.
adrian_sm wrote:Update:
Okay chance for John to say I told you so. My stair grip tape let go mid ride.
- Adrian
- Adrian
Kepler wrote:I decided to get serious and went to a 40 grit belt sander material. Works a treat and hardly wears. Also gives great tire traction and as long as the drive doesn't slip, causes no major wear on the tire.![]()
