Part 1
Back-story:
In September of 1991 I moved to Austin Texas and quickly discovered that mountain bikes were the choice way of getting around. I bought a Specialized Rockhopper with (what I believe was) the first generation Rock Shox RS-1. Last year, 13 months ago I converted this bike over to electric using the Nine Continent 2806 FH motor purchased as part of a kit that included a 25A 6FET controller from ebikes.ca.
Reference Prototype Permutations: P0 Evolved
EOY 2010 - Last good build of P0; except for the gimpy shock – this was my best ebike configuration.
Slowly over the course of summer the front shock began to leak fluid on the right side, and the shock as a whole finally failed completely after a week of hellish storm activity mid-December. I purchased what I thought was a reasonable replacement shock for the 1-inch steerer however that assembly didn’t survive the trip home from the bike shop, a result that left me with now two broken shocks on New Year’s Eve and no way to get to work the following week.
P1 started out as a humble bare frame.
Fortunately I had been working away quite diligently early last spring on a 2WD replacement ebike – trying to get it ready for my summer road trip. Somewhere along the way I became a little bit frustrated with the 9C motors by the lack of support for disk brake and idled further construction in lieu of new motor development, a project that is taking longer than expected.
With one broken bike, another stalled bike, and a free weekend I made the prudent decision to retire original ebike and part it.
<Queue theme to Six Million Dollar Man: “We can rebuild; we can make it better…â€Â>
Like a horse with a broken leg, P0 was put down.
My old sig…
Into the Fire:
Starting at about 6:30 PM New Year’s Eve, I rolled up my sleeves, put on some good old rock music from the 60s and 70s when they made music worth listening to, with a pile of Cliff Bars & coffee, and just went for it!
The original idea was to assemble a rear-wheel drive but then I recalled all the issues that started it all with the ill-fitting rear 9C hub, and that thought was given way to creating a FWD nearly identical to the old bike. The first task then was to transfer over the front wheel. Although I had several new hubs available it was decided to keep the tried & true wheel and run with it, saving time from not having to goof around with swapping tires.
P1 (The Phoenix) is like a foal trying to get on its’ feet...
Most of the rest of the components were already loaded on the frame; pretty much starting with a good base of top-of-the-line Shimano, SRAM, Avid, and Tru-Vativ parts to pick and choose from. Intially this was going to be a 7-speed for the 9C hub, but then I got to thinking about making a FWD with a freehub in the rear as an 8-Speed, then a 9-speed, and they led to a well-stocked parts bin (and I’m still sorting this out). The bike as imaged below has the rear wheel from P0 mounted with an original 7-speed freewheel, and a new 7-speed Shimano chain. The rear tire doesn’t have a disk brake, and the new frame doesn’t support rim brakes so this would be a work item on Sunday Jan. 2nd when the stores open.
P1 with electrics in place sans batteries
Also migrated over where all the electrical features of P0, such as the CA, throttle, 3-Way current switch & Cruise Control, HP-LED lights, Modified 6FET controller, DC-DC converter, and Blinkies. New for this ebike was the mounting of the controller; I fussed about with this until I conjured up an idea of straddling the controller directly in front of the handlebars. This effectively removes all the nastly web of cabling out from the triangle except for power and rear lights: Simple.
Another change was how the front wheel was mounted. I didn’t have the Lawyer’s Lips (I have no idea why since I have just about every other little ebike doodad on the planet), and therefore had to figure out a way to make the quick-release fork work with the motor. I resolved to use heavy-gauge solid copper wire which would deform and fill the void; I just have to be attentive and tighten the nuts periodically the first week. Two torque arms were used; the clunky steel on the wire-side and the fancy adjustable stainless on the bolted side. Two would have to be enough. Since the clunky metal side pointed down I was puzzled on how best to secure it; this was resolved by scavenging an old pedal for metal which is clearly displayed in the photo above… See it? A pedal cut in half… Yes, yes, cheap thrills here in the hovel of Kingfish.
Close-up of the controller integration from the front; functional though not pretty.
Close-up of the controller integration from the back side; an inglorious rat’s nest.
Clean triangle area awaiting a battery pack.
More in a moment...
~KF
EDIT: Added reference to P0 evo
