Cuda-E - 4000 watt Shumaker drive upgrade
Re: Cuda-E - 4000 watt Shumaker drive upgrade
Postby www.recumbents.com » Thu Jan 06, 2011 9:41 pm
I received the Cycle Analyst yesterday, and the shunt fits in with everything else, if I shoehorn it all in.
Because I may have to open this box up every week or two to balance the batteries, I decided to mount the ESC on the outside of the box. It's not quite as clean but still one self contained monolithic block and much easier to fit all the wires in the box.
The connectors from left to right are throttle, cycle analyst, bulk charging/accessories, motor phase wires (black) and power disconnect (red).
-Warren.
www.recumbents.com
Postby www.recumbents.com » Sat Jan 08, 2011 5:44 pm
I had a bit of a scare after wiring everything up with the CA and testing it in the basement. As soon as I turned it on the CA said I was using 8885 watts with no throttle. At full thottle no change. :shock: I got out the manual and found how to zero it. The CA then said 0 watts all the time. Hmm. I send Jason at GrinTech a note to see if he had any bright idea, and went to bed. The next day he replied that that's what happens when you splice the wires and don't hook up the blue one or white one. Ah. On my second temporary splice that I did not solder as I needed to figure out how long to make the wire on my recumbent, there was indeed a bad connection. Works fine, case closed. All is right in the world.
Today I made the bracket for the return idler and confirmed that I don't really need to braze in new rear dropouts. I'm using the bolt-on derailleur hanger from an ancient 10 speed instead. Works fine. I have a bit more tweeking to go on the electric and human powered drivetrains, but the end is in sight!
I also found a nice old laptop bag that this battery pack fits in nicely. One of the bags pockets slides right onto the shelf. This means I'll just be able to use the shoulder strap to hold the battery on the bike, making it easy to take with me for charging.
-Warren.
www.recumbents.com
Postby jmygann » Sun Jan 09, 2011 10:15 pm
Super Clean!
48 V Semi-recumbent
jmygann
Postby www.recumbents.com » Mon Jan 10, 2011 10:35 pm
Tonight I finished the human power drivetrain (at least enough to pedal), and mounted the CA. I wanted to see what the top speed was while the road was dry before the next snowstorm blew through tonight. I pedaled it up to 5 MPH before rolling on the volts. Wow, this thing really pulls hard up to speed. I blasted up to 27MPH in about 2 houses. That was at 25 degree F, with low pressure in the tires, in the dark. I'm pretty confident it will go a couple MPH faster. Fun.
The CA said the battery was at 29.1V, and top current was 80A.
-Warren.
www.recumbents.com
Postby recumpence » Tue Jan 11, 2011 4:22 pm
I am thrilled! It is so good to see another RC system up and running.
Now we have snow. :cry:
The acceleration is much better than you thought it would be, I bet!
Matt
1% of the world's population can think "Outside the box". The rest are firmly stuck within the box. Where are you?
recumpence
10 GW
10 GW
Location: On Earth right now. That can change at any time, though..........
Postby www.recumbents.com » Wed Jan 12, 2011 6:59 pm
Hi Matt,
Yes, this bike needs to be pedaled up to 5 MPH or so before powering up the drive unit, but after that it pulls like crazy! I can't wait to get it out for a bit longer test run so I can see what the watt/hour rating is at cruising speed (full throttle of course). That will tell me if I will be able to make it to work and back on a single charge.
I just weighed the bike. 52 lbs, Whoa. The battery weights in at 13 lbs, so 65 lbs total. I don't think this bike is any lighter than in it's previous incarnation, but it's got a bit more power.
Be careful out there guys. A guy I knew from bike racing was killed on Monday while out riding his fully faired red and yellow Lightning F-40 out West of Rockford, IL. According to reports a flat bed truck pulled out in front of him. He slid under the truck and it ran over him. It doesn't matter how brightly colored you are or how many lights you have. Never assume that a car sees you.
-Warren.
www.recumbents.com
Postby www.recumbents.com » Wed Jan 12, 2011 8:20 pm
Here's a spiffy video of testing the RC drive unit on the recumbent bike in the ice cold garage:
Last edited by www.recumbents.com on Sun Mar 27, 2011 8:36 pm, edited 1 time in total.
www.recumbents.com
Postby SoSauty » Wed Jan 12, 2011 9:08 pm
Exciting to here about that brisk acceleration Warren! One of the early builders said the Astro3210 has a 40mph top speed potential, now your saying its perky up past 27mph, do tell more :lol:
Used the same soldering technique, soldering a comparatively huge aluminum wire to an itsy bitsy copper wire gets squirrly; used a bread tie wire stripped clean to tie 'em in place.
I could of wired my build correctly the 1st time if I'd seen your wiring diagram beforehand, it's great! Hope you don't mind me linking to it. What program did you use to draw it with :?:
The compilation of key points of your thread is a great idea. Anyone searching for info. can reduce their reading/research time way down. Way to go :!:
Will aka SoSauty
http://www.ebikes.ca/index.shtml No.#1 Trusted E-bike online sales!
3 hardtail MTBs:
-48V Lith-ion 10.5amp hr-408 C-lyte
-BPM 8FUN[*STOLEN]
-run Century rides w/Q100 mini
3 folders:
-20" wife's BaFang,
-20" TurnigyMax50cc airline suitcase folder,
-24" Stewart/Hass 9C; 3.5K/40mph fun racer
SoSauty
Postby www.recumbents.com » Wed Jan 12, 2011 11:11 pm
Hi Will,
I'm happy to help. Once I get everything done I will compile all the how-to bits into one web page to allow people to build these RC drives more easily. There was kind of a steep learning curve but now that I have it all sorted out I am more comfortable with the system. Thanks Matt for the help!
I use Paint Shop Pro 7. Corel has a new version called Paint Shop Photo XP Deluxe Turbo Mark9 or something.
-Warren.
www.recumbents.com
Postby recumpence » Thu Jan 13, 2011 8:02 am
My problem is, I am busy developing and manufacturing things. Quite often installation and service information gets lost in the busy-ness of business. :)
I am glad you are willing to layout a page for these systems. That is one less thing for me to worry about.
It looks great!
Matt
recumpence
10 GW
10 GW
Postby www.recumbents.com » Fri Jan 21, 2011 8:28 pm
I have been thinking about lights. Bright lights. Lights that I don't have to replace batteries in. Matt told me about the CC BECs. They handle up to 12S of LiPo and have an adjustable voltage output. This is perfect. Here's what I have in mind:
I have built LED lights before, and it was fun but it takes a long time to build the housing.
http://www.recumbents.com/wisil/led_light/default.htm
Does anyone have a better solution?
-Warren.
www.recumbents.com
Postby www.recumbents.com » Fri Jan 28, 2011 9:12 pm
Hey all,
Today I learned something new about RC e-bike systems. If you connect up all the wires except the throttle, including power, you can accelerate/decelerate the motor just by getting close to, then touching the casing on the throttle wires. :shock:
-Warren.
www.recumbents.com
Postby AussieJester » Fri Jan 28, 2011 9:54 pm
www.recumbents.com wrote:Does anyone have a better solution?
-Warren.
Edward Lyen sells a dc-dc converter ~25 bucks input upto 70v output 15v IIRC (have one but not used it yet)
I saw a thread yesterday someone running a magic shine light from it...
KiM
AussieJester
Postby D-Man » Fri Jan 28, 2011 11:52 pm
www.recumbents.com wrote:Hey all,
-Warren.
Do you have a kill switch? I'd have one nearby. I don't trust those rc speed controllers yet. They seem to have a mind of their own. Nice build by the way.
408 front hub
11000+ miles on sla's.
Michelin pilot sport 2.3
Miles 50
Flats 0
Quality posts will not be sold.
D-Man
Postby recumpence » Sat Jan 29, 2011 11:38 am
-Warren.
You will trust them once you use them for a while. The only glitches I have ever had with throttle was related to the use of radio control receivers, not the controller itself.
Matt
recumpence
10 GW
10 GW
Postby www.recumbents.com » Sat Jan 29, 2011 12:04 pm
I just bought one of Lyen's DC to DC converters. 3A, adjustable with a trim pot and under $20. Can't go wrong!
I can't think of any reason why I wouldn't connect the throttle cable before connecting the power under normal circumstances, but I thought I'd throw that oddity out there as an FYI. I do have a switch of sorts - the PowerPole connector loop on the outside of the battery box. I moved the fuse inside the box so now it's just a loop of wire. Like Matt said, the RC system should be very reliable, but since this is my first one I may add a pull cord to it so I can yank the power in an emergency.
This weekend I will be mounting the battery pack to the bike, probably with a bracket made of bent and riveted aluminum strap.
BTW, I saw something somewhere about using a 555 timer to build an ESC controller circuit. I like 555 timers. Has anyone tried that here on the Sphere?
-Warren.
www.recumbents.com
Postby recumpence » Sat Jan 29, 2011 12:46 pm
Warren,
There is no reason to ever unplug the throttle. The only thing you need to do is connect or disconnect the battery. :)
Matt
recumpence
10 GW
10 GW
Postby www.recumbents.com » Tue Feb 01, 2011 10:34 pm
I put together an RC tutorial. Hopefully it will help people to build up their own RC systems. Please let me know if I missed anything.
http://www.recumbents.com/wisil/e-bent/ ... torial.htm
I built up the aluminum brackets to hold the battery on the bike and it's solid now, but kind of fugly. I also rearranged the connectors on the battery box for the third time. :roll:
-Warren.
www.recumbents.com
Postby katou » Tue Feb 01, 2011 11:01 pm
This is a great build, I'm so glad that I caught it! Super clean, and as Matt says, so nice to see another RC build running! It gives me hope that I will one day have my 8150 reborn in a similar setup!
Katou
katou
Postby SoSauty » Wed Feb 02, 2011 1:06 am
How'd this post double?
3 hardtail MTBs:
-BPM 8FUN[*STOLEN]
3 folders:
-20" wife's BaFang,
SoSauty
Postby SoSauty » Wed Feb 02, 2011 1:21 am
Wow Warren,
Your tutorial is near priceless and your diagrams worth a 1000 words each! You didn't miss any points on your outline did ya :o Clear diagrams along with concise explanations, have you, or do you teach elementary kids? Only a select few are as insightful as you, to producing a tutorial. The only little criticism I can come up with is those 3 little signal wires from the servo to the ESC. Think it's brown to black, red to red, and white to orange. Your wires are not the same color as mine or the diagram doesn't show that. Did I say, "Outstanding tutorial" :wink:
3 hardtail MTBs:
-BPM 8FUN[*STOLEN]
3 folders:
-20" wife's BaFang,
SoSauty
Postby Byte » Wed Feb 02, 2011 3:34 am
www.recumbents.com wrote:I put together an RC tutorial. Hopefully it will help people to build up their own RC systems. Please let me know if I missed anything.
-Warren.
Noooo! Oh my god! You spelled "Plettenberg" wrong! What a shame :lol: (Spelled it as "Plettenburg") Hehe, anyway, that manual looks fantastic! This link should be in some kind of sticky. Good work!
Bergli
Turnigy 80-100 130kv
10S 16Ah LiPo
Castle Creations HV 160
Byte
Postby jmygann » Thu Feb 03, 2011 4:33 pm
This is great ... much thanks
48 V Semi-recumbent
jmygann
Postby www.recumbents.com » Thu Feb 03, 2011 9:44 pm
Happy to help.
I updated the Pletty spelling so as not to offend those Plettenberg fans, added a note about the ESC throttle wire colors and that little plug that can be plugged in more than one way, and noted that you need a 5K resistive throttle to retrofit to the servo controller, not a hall effect one. :D
All important stuff to know if you don't know, k'know?
-Warren.
www.recumbents.com
Postby www.recumbents.com » Sun Feb 06, 2011 10:51 am
I'm not happy with the way the aluminum strap battery mount turned out. It's too cage-like.
I receive the Avid BB7 203mm disk brake, and bolted it on with a single 5mm bolt to check clearance. The stock bolts were not long enough to make through the chainring adapter, 1/8" spacer, and the disk brake.
As seen here, the huge brake entirely hides the chainring. The brake caliper is just resting there. I'll need to make a special bracket and braze it onto the rear dropouts.
Here's the top view showing the tight tolerances and spacer. The brake rotor definitely clears the frame, but may rub on the extra wide BMX chain. I will probably space the chainring in with some thin chainring shims to buy the extra clearance there.
-Warren.
www.recumbents.com
PreviousNext
Users browsing this forum: Google [Bot], kozmoto, motomoto, slayer and 10 guests
