Chopper with Cyclone kit
Postby commanda » Sat Jul 05, 2008 12:20 am
So I bought this chopper off eBay for $80.00. Unwanted Xmas present with very little use. Ordered a Cyclone 180watt kit direct from Taiwan. The battery mount is thin plywood, held on with cable ties, and not painted yet. The 2 x 12volt 7AHr SLA's I already had. Didn't use the Cyclone crank axle, as this bike's axle is already longer. Took it for a quick blast up the street, ran fine.
Problems at this stage:
1: the freewheel crank slides on too far, and fouls against the bearing cup. I shimmed the square taper with some heatshrink for now, just to get it going. But this will require further engineering to get it right. Possibly some very thin brass shim material.
2: The tubing where the motor is mounted will need some support tubes added through the bolt holes, to prevent crushing. The motor has already rotated, and the chain no longer runs straight over the motor cogs.
3: The rear dropouts are 170mm wide. I found a Sturmey Archer 3 speed hub specially designed for this frame, and am awaiting delivery.
http://www.choppersus.com/store/product ... Disc-SLVR/
Original weight 21Kg. Weight now 29Kg.
The intended use is the 6Km trip to work, which is a little bit hilly.
Amanda
EVT-4000e. 16x TS-LFP40 and custom BMS = massive EV Grin
Chopper with 180 Watt Cyclone kit & 8x 20AHr Foxx LiFePO4 and custom BMS
commanda
Re: Chopper with Cyclone kit
Postby knoxie » Sat Jul 05, 2008 4:08 am
Hi
Thats a nice looking little bike! well done, like the battery box as well will look nice painted up and plenty of room for more batteries as well, in fact if you are using lead you can stack a lot more lead inside that frame.
The cyclone is a good little kit for bike like this, the sturmey archer will make things better as the chain wont skip about as much.
Knoxie
Electric KMX 72V Lipo, USPD drive unit. BMX 72V, Puma BMC,
Raleigh 26 inch MTB Puma 50V Turnigy 25C Lipo 10AH, Trek MTB, X5 48V NIMH. Electric BMX
http://tinyurl.com/4vrmc8 http://tinyurl.com/3umm4n
knoxie
Postby AussieJester » Sat Jul 05, 2008 5:29 am
Nice to see a member of the 'fairer' sex into the e-biking gig AND an Aussie too boot :-) Neat lil setup to Amanda, Alan from ChoppersRus is excellent to FYI very quick response to emails and gets the product away promptly with very reasonable freight charges compared to some of the suppliers i have had quotes from in the USA... 107 dollars US delivery for a scooter shockie that cost 17 bucks for example :-| I would look at slipping in a couple more batteries if you have the room there Amanda just to be sure you make the return trip from work without having to pedal... Will you be painting the battery 'box' up when your finished with the design etc? or keeping with the 'ghetto' look?
Top job anywayz well done :-)
EDIT: The shim material (extremely thin brass sheet) your after can be picked up from Model shops (as in the planes/helicopters/cars/boat models) to FYI in case your not sure where you can pick it up...
AussieJester
Postby TylerDurden » Sat Jul 05, 2008 9:01 am
Looking good. :mrgreen:
(kinda like mine, before it was stolen by a gang) :(
re the motor mount: perhaps a metal plate (or two) that reaches as far back as the the chainstays.
Cheers...
Have a Nice Day,
TD
FYI: Adding pictures?
TylerDurden
Postby AussieJester » Sat Jul 05, 2008 9:20 am
Ah bugger TD what a pissa i gather you never saw it again? Curious how one of them 'gang members' you Americans have over there would actually get onto a bike in the first place what with the crotch of their pants hanging around their ankles with 27 inches of underwearz showing be a bit of a struggle to swing the leg over wouldnt it hehe ;-S
AussieJester
Postby TylerDurden » Sat Jul 05, 2008 9:53 am
FWIW Commanda,
You could perhaps mount the motor above the pipe and keep your orig ground-clearance.
@ Jester.. it's usually kids <18yrs. Part of our goals with the inner-city bike co-op is to teach kids how bikes can be a part of good citizenship.
Have a Nice Day,
TD
TylerDurden
Postby docnjoj » Sat Jul 05, 2008 11:01 am
Maybe give those "gang" members (not the real ones) summer jobs like they used to! Then they'll buy the bikes!! Nice job Amanda! Start saving for Ping,cause he's baaaaack!
otherdoc
E-bike stable at our house
Bike-e electric front brushed C/L
Steintrike Mad Max full suspension trike rear 9C
Sun USX delta trike 9C front wheel sort of front suspension
Frame of homebuilt trike in shed with Bafang still on it
New Agniusm/A123 on the Steini and old 10ah Ping paralleled with 12 ah Fatpacks on USX
My wife and I ride the trikes
docnjoj
10 GW
10 GW
Postby commanda » Sat Apr 09, 2011 9:11 pm
Time for an update & some fresh piccies.
The batteries are now 8s * 20AHr Foxx prismatics which cost me $300.00.
And you can't put the motor on top, because the idler will be under tension, and it will bend the shaft.
Peak current to the Cyclone 180 watt motor is 30 amps.
The Sturmey-Archer 3 speed hub works a treat, and is a great combination with the Cyclone in our power restricted Aussie nanny state.
The little rack at the back is used to support my back-pack, which is held on with bungee cord.
The handle bar supports 2 mirrors, a bell, a horn, a Watts-up meter, and a gps.
Gearing is now 52 tooth front, 16 tooth rear. Top speed is about 30Km/Hr on the flat with a little pedalling.
BMS is custom, same as in my EVT scooter. Charger is currently a 30volt 3 amp benchtop power supply, but I do have a 27 volt Meanwell which I haven't implemented yet.
Power is enabled with a keyswitch driving a 24 volt automotive relay.
Last 2 weekends I've taken it out, done about 20Kms and used 9AHrs.
I've also ridden it to work a few times over the last few months. Only 5Km each way, but still a pleasure to arrive at work not sweaty.
Still to-do is find some decent material for the battery box, and put a lid on it so it is more weather-proof.
And find a cure for the rust.
It does get a lot of looks when out riding.
Amanda
commanda
Postby Rassy » Sat Apr 09, 2011 9:36 pm
Bike looks nice. I had the same problem when I put a freewheel crank on my trike. My quick solution was to grind the "removal" tabs off the freewheel. Of course now I can probably never get the freewheel off again. :D
If (when) I have to redo it, I plan to just get a bottom brackett cartridge with a slightly longer axle.
-Rassy-
Two Tadpole Trikes, 6X10 9C mid drive, NuVinci CVT Auto Shift, 48V LiFePO4
viewtopic.php?f=28&t=18606
viewtopic.php?f=28&t=47043
Rassy
Postby amberwolf » Sun Apr 10, 2011 1:51 am
If you're removing a freewheel like that because it's broken, you can just tackweld across the core to sprocket line, and then use a chainwhip to take it off. ;)
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Users browsing this forum: MAGICPIE3FOCUSPOWER and 9 guests
