Bargain!
Complete sBike Kit for 26"
450w motor - 6/10HP
Wheel
rack
controller
throttle
battery - 24v SLA
charger
brake disconnect
etc
Currie-EZip eBike Kit - $289.88 w/free shipping
vanilla ice wrote:I think you can use "SPORTS20" to get $55 off too. You have to use an Amazon credit card though. Coupon should be valid until June 15th.
Noisy motor, but if you don't mind the noise its pretty good otherwise.
DrkAngel wrote:vanilla ice wrote:I think you can use "SPORTS20" to get $55 off too. You have to use an Amazon credit card though. Coupon should be valid until June 15th.
True ... The 2008 model was noticeably noisy.
By comparison, the 2009 model was, nearly silent!
Hopefully, the newer models, improved, even more. ... ?
I am guessing that this is a clearance price, on the 2010 model.
vanilla ice wrote:For a while you could get the whole bike for less than this price for the add on kit.. Not a bad motor but I think I'd rather do a small hub motor setup for 290.
neptronix wrote:disadvantages:
+ loud and whiny motor. Straight cut gears plus a brushless motor = loud.
neptronix wrote:+ more expensive and less powerful than a hub motor kit.
neptronix wrote:+ changes weight balance of bike to be biased leftward, bike will always want to fall to the left.
neptronix wrote:+ very little power potential, motor gets very warm on stock 24 volts
2009, and newer, controllers, have overvoltage protection, sonewhere between 29.4-33.1v.neptronix wrote:+ voltage limiter on stock controller keeps you from running more than 29.4v according to drkangel
neptronix wrote:+ when brushed controllers fail, they often do so by shorting the throttle and creating a 100% throttle condition.
neptronix wrote:+ Included lead acid battery is a paperweight after a year or two.
neptronix wrote:+ pain in the ass to change tire, way worse than rear hubmotor. Involves a lot of disassembly.
DrkAngel wrote:Brush motor - dummy! 2009 and later motors much quieter! You are 3 years out of touch!
DrkAngel wrote:Where can you get a 500w hub motor, with controller, brake cut-offs, rack, battery, charger + shipping included, for less than $300? ... With USA warranty and support?
DrkAngel wrote:Motor on left, battery on right ... balances almost perfectly!
DrkAngel wrote:I've run at 37v, (675w+), for thousands of miles, with no overheat problems!
DrkAngel wrote:2009, and newer, controllers, have overvoltage protection, sonewhere between 29.4-33.1v.
DrkAngel wrote:Documentation???
fechter wrote:When a brushed controller fails, it feeds full power to the motor instead of shorting out the battery. This is why there is frequently no visible damage. The motor keeps the FETs from exploding.
DrkAngel wrote:$60 a year would be damn cheap for an eBike battery!
neptronix wrote:neptronix wrote:+ more expensive and less powerful than a hub motor kit.DrkAngel wrote:Where can you get a 500w hub motor, with controller, brake cut-offs, rack, battery, charger + shipping included, for less than $300? ... With USA warranty and support?
Nowhere, but i can get a $150 hub motor kit shipped from a reputable vendor overseas with good support for about $225 total to the states and then add a real battery.
neptronix wrote:You also intentionally grandma your bike and run on batteries with massive amounts of voltage sag.
neptronix wrote:You even said you intentionally let air out of your tires to keep the speed down. lol.
neptronix wrote:There are many reports of motor failures at 36v. Don't pretend that you haven't heard of them. I saw the forum you came from.
neptronix wrote:neptronix wrote:+ when brushed controllers fail, they often do so by shorting the throttle and creating a 100% throttle condition.DrkAngel wrote:Documentation??? Never heard of any Currie product occurrence!
http://endless-sphere.com/forums/viewtopic.php?f=2&t=5345fechter wrote:When a brushed controller fails, it feeds full power to the motor instead of shorting out the battery. This is why there is frequently no visible damage. The motor keeps the FETs from exploding.
neptronix wrote:neptronix wrote:+ pain in the ass to change tire, way worse than rear hubmotor. Involves a lot of disassembly.DrkAngel wrote:Add my T-Plug mod. Makes disassembly about as simple as any wheel!Simpler than a hub motor!
See page 2: The New EZip "StepThrough"neptronix wrote:That's helpful but it only reduces the pain in the ass factor by a fraction compared to a hub motor.
I had a mongoose bike with a currie kit on it that i had bought used. It was a serious pain in the ass to change the rear wheel and my hands would always end up needing to be scrubbed afterwards, i think maybe the gearbox was leaking oil or something. I called that bike the lead sled and owned it for about 2 months before selling it.
DrkAngel wrote:Good support from overseas?
How much and how long for round trip shipping???
DrkAngel wrote:"Real battery" for less than $75?
DrkAngel wrote:I treat my 37v bikes with respect.
I typically run at the "legal" 20mph, 25.9v bike, after 35miles, 20mph, full throttle dips voltage to 25v.
DrkAngel wrote:So ... no occurrences with Currie kits?
DrkAngel wrote:Once again. With my simple mod. Simpler than a hub motor!
Simple unplug, then. Same as normal wheel. No torque arm, no wires!
neptronix wrote:We run our hub motors at 2-10 times their watt rating on here, whereas you have to worry about an additional few hundred watts blowing your eZip motor.
neptronix wrote:I run my 500w motor at 1500-1600w constant with no incident. It doesn't even get warm. No babying it, 5 mile hills, jackrabbit starts. I do pedal but only to increase my top speed to about 28-29mph or so.
DrkAngel wrote:At 500 watts, a 36v hub motor draws approximately 25 amps.
At 1500 watts, a 36v hub motor would draw approximately 75 amps.
That means that your Turnigy 20ah 36v pack would propel you for only 16 minutes, maybe 8 miles?
Your old 5ah Lipo, about 4 minutes, it could take you, less than, 2 miles.
If you are going to make stuff up ... try to be a little more realistic.
DrkAngel wrote:neptronix wrote:I run my 500w motor at 1500-1600w constant with no incident. It doesn't even get warm. No babying it, 5 mile hills, jackrabbit starts. I do pedal but only to increase my top speed to about 28-29mph or so.
stanz wrote:
Huh? Neptronix said he was running 41.4V, if he is pushing 1500W into his motor that means he's using 36.23 amps, not 75. W = V x A right?
I have pushed 837W through my 500W hub motor when my SLA pack was at 39 volts. If I was running more voltage I could provide more watts, my controller limits me to around 21 amps.
DrkAngel wrote:neptronix wrote:We run our hub motors at 2-10 times their watt rating on here, whereas you have to worry about an additional few hundred watts blowing your eZip motor.
That is crazy!
You are saying that you'all run your 36v hub motors at 72v - 360v!neptronix wrote:I run my 500w motor at 1500-1600w constant with no incident. It doesn't even get warm. No babying it, 5 mile hills, jackrabbit starts. I do pedal but only to increase my top speed to about 28-29mph or so.
So ... you run your 36v hub motor at 108v - 115v!!!
I do exactly the same speed with my 37v EZip!
Faster ... actually ... 30+MPH!
Either you have a very vivid imagination,
or you just don't have any idea what you are talking about!
gogo wrote:There is a couple in their 70's that live across the street from my parents in AZ. They ride their eZips all over and seem to love riding them.
