Nehmo wrote:I now have the bike, but I didn't get the Currie SLA battery. I used 2 U1(lawnmower) 12Vs in series. It's heavy at 105 pounds. Where did you, DrkAngel, get the cheap Li batteries?
`~- Nehmo
Homemade Battery Packs
`~- Nehmo
Solcar wrote:DrkAngel wrote:vanilla ice wrote:I think you can use "SPORTS20" to get $55 off too. You have to use an Amazon credit card though. Coupon should be valid until June 15th.
Noisy motor, but if you don't mind the noise its pretty good otherwise.
True ... The 2008 model was noticeably noisy.
By comparison, the 2009 model was, nearly silent!
Hopefully, the newer models, improved, even more. ... ?
I am guessing that this is a clearance price, on the 2010 model.
I've read that adding a plastic spacer inside the gearbox can quiet it down a lot.
icecube57 wrote:
2-10 times their watt rating. Meaning a legal 750w kit Double that is 1500w. 10 times that is 7500w. In no way did he say anything about 100+ volts or 72-360 volts
icecube57 wrote:But from a stand still the motor will draw whatever the motor wants as long as the controller current limit isnt hit. In a stall situation or coming off the line the 9x7 motor will draw up to 130A max at 36v at that point the windings can no longer accept any amps because its being limited by the resistance of the windings.
icecube57 wrote:So the increase in amp does increase wattage output up to the limitation of the winding in extreme cases.
DrkAngel wrote:The only way to increase watt output on a hub motor is to increase the volt input!
Unless you rewind it?
Volts is pressure, higher pressure = more power.
Volts x Amps = Watts
You can't force in more amps unless you up the volts..
Hillhater wrote: Errr ? .. have you never heard of the controller limiting the amps ???
a simple change of controller can double the power output from some stock Ebikes.
DrkAngel wrote:...
You can't force in more amps unless you up the volts...
icecube57 wrote:I can post the results for a 5303 that will clearly show an upgrade in amps clearly increases output power...
Hillhater wrote:Remember DA, we are talking of commercially sold Ebikes ...which have to meet the legal limits, so it is common for manufacturers to install a controller that limits the output to suit the requirements.
Change or modify the controller and suddenly you have more amps available at the motor for either performance.. (or smoke if there is a weak motor also)
icecube57 wrote:Output profile of a 30A controller and a 100A controller.
DrkAngel wrote:icecube57 wrote: In a stall situation or coming off the line the 9x7 motor will draw up to 130A max at 36v at that point the windings can no longer accept any amps because its being limited by the resistance of the windings.
Which would make them red hot! They add a fuse to prevent motor burn up.
neptronix wrote:DrkAngel wrote:icecube57 wrote: In a stall situation or coming off the line the 9x7 motor will draw up to 130A max at 36v at that point the windings can no longer accept any amps because its being limited by the resistance of the windings.
Which would make them red hot! They add a fuse to prevent motor burn up?
Do you mean to say that there are fuses in 3 phase hub motors?
I haven't found any in any of the motors i've pulled apart, where are those fuses DrkAngel?
Users browsing this forum: Bing [Bot], Miles, neptronix and 9 guests
