AussieJester wrote:For a frame that is 'supposedly' and e-bike specific frame, they didnt think to long and hard about the whole placement of batteries scenario did they...
oatnet wrote:AussieJester wrote:For a frame that is 'supposedly' and e-bike specific frame, they didnt think to long and hard about the whole placement of batteries scenario did they...
Actually, Tidalforce thought long and hard about battery placement - they put the battery in the front wheel, got a patent on it that has since stifled exploration of this design. This location neatly balances against the weight of the rear hub motor.It also lowers the center of gravity, and keeps the front wheel well planted, so TF are always surefooted, easy handling bikes.
-JD
...they put the battery in the front wheel, got a patent on it that has since stifled exploration of this design.
Hillhater wrote:...they put the battery in the front wheel, got a patent on it that has since stifled exploration of this design.
but patents dont prevent individuals using those ideas, ..and i dont recall many private builds with batteries in the front wheel. ! ..I wonder why ??![]()
..Lucky for us they got that patent though,...or some other foolish Ebike companies may have copied it !
Hillhater wrote: but patents dont prevent individuals using those ideas, ..and i dont recall many private builds with batteries in the front wheel. ! ..I wonder why ??![]()
Ypedal wrote:The TF was one of the biggest influences of me getting into ebikes in the first place, could not afford one at the time tho.. that goes back like 6 years !!
Don't forget that they had to issue a recall on those wheels too.
Ypedal wrote:I thought about it, but it's a very , very good fit, so much that the heat sink would have squeegied ( is that a word ? ) .. it right off while sliding onto the motor..
AussieJester wrote:wouldn't it be more effective to have these as thin as possible rather than
thick like they are Matt.S?
KiM
recumpence wrote:... But, my heat sinks run nearly identical to the motor temp. So, heat transfer is, at least, happening enough to help the motor.
Users browsing this forum: lcrewse and 9 guests
