Not simple BLDC controller It RUNS! :)
Re: Not simple BLDC controller
Postby Arlo1 » Sun Aug 21, 2011 11:20 pm
SO the optocoupler gate drives look very appealing but they need 15 volts or greater to run them? Because they use a LED to trigger the out put Mr Colton designed a half bridge drive like this to delay the turn on of each fet so the other fet gets shut off fully first. This is to prevent shoot though events!
(26.54 KiB) Downloaded 101 times
(21.82 KiB) Downloaded 101 times
(248.35 KiB) Downloaded 101 times
(27.27 KiB) Downloaded 101 times
And Dave who has some good deals on STUF
[color=#FF0000][b][size=150]Never above 4.2v never below 2.7v EVER!!!
Arlo1
Postby Lebowski » Mon Aug 22, 2011 1:44 am
Some stuff I learned the hard way :? when working with optocouplers: make sure your power transistors are
off when the LED part of the optocoupler is off !
Have you guys thought of using a class D audio driver like this:
http://www.silabs.com/products/audiovid ... i824x.aspx
if you look at the datasheet you'll see that a class D audio circuit is very (very !) similar
to the circuits that we use to drive one pin of the motor. See the datasheet (under documentation)
figure 38/39 on page 23. A class D amplifier uses square waves (like we do) of a few 100 kHz
to drive a speaker (which is like a linear motor).
With this particular IC the dead-time between the high and low side can be programmed by
chosing an external resistor, everything is taken care of inside the IC.
Interesting bit about this IC is that isolation is obtained not by using optocouplers but
by using radio signals.
Lebowski
Postby bigmoose » Mon Aug 22, 2011 6:48 am
Arlo as you get into the dspPIC you can set the dead time in software.
bigMoose's electronic pieces & parts (GENUINE IRFB4110Pbf's, Nomex 410, AntiCorrosion Grease, Current Sensors) available HERE.
Thanks to Justin ebikes.ca for securing the board then setting us FREE! Tech Tips in the WiKi: http://endless-sphere.com/w
"Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God..." all the best, Dave
bigmoose
Postby Arlo1 » Mon Aug 22, 2011 9:00 am
bigmoose wrote:Arlo as you get into the dspPIC you can set the dead time in software.
Thanks big moose I already have the IR2113 coming and they run a half bridge each with a Shut down pin as well. So basically exactly what I want. I will run them with isolated 12 volts as well. If you can you are almost always better doing a job with software from my stand point. Then I can program the turn on delay to what ever I want!
Arlo1
Postby jdb » Mon Aug 22, 2011 12:05 pm
Lebowski wrote:Have you guys thought of using a class D audio driver like this:
Just the other day I was looking at the SI823x line, which uses nearly (exactly?) identical technology to build a family of FET/IGBT gate drivers. What is the difference between a class D audio driver and a high/low phase leg driver? They look identical to me.
jdb
Postby Arlo1 » Mon Aug 22, 2011 2:20 pm
For the main bord power supply this is from page ten on the LOBO thread I was looking at this.
Luke wrote:Little cell phone chargers (from modern USB based charge phones) tend to output a stable 5v (at 500mA-1A), and handle an input range of ~80vdc to 250vdc. Methy found some vendors on ebay selling them for $1 shipped from China... And about 3/4th of the types he tried we NOT isolated, so they shock your face with 110vac if you answer the phone while it's charging. lol He let me find that out for myself when I asked if I could charge my phone.
BUT... a couple types were fully isolated, and $1 each shipped from China. Otherwise you can get known-good-isolated units for like $4-5 each.
You would need Methy to confirm (he has a box of every type offered on fleabay), but I think this model was indeed fully isolated:
http://cgi.ebay.com/1000mA-5v-USB-Unive ... 4108wt_905
This one also was isolated i think... but I can't remember exactly, they all look similar:
http://cgi.ebay.com/USB-AC-Power-Supply ... 152wt_1139
Unfortunately, while a genuine apple usb charger is totally isolated, all the units on ebay in the apply charger-cube format were unisolated face-shockers.
Arlo1
Postby Arlo1 » Mon Aug 22, 2011 2:49 pm
Would a guy not be smart to set a max on time as well eg if I build a system that reaches 600 phase amps in 41 uS and 600 phase amps is the max I am aiming for would I not want to program the max on time to 40 uS and try that to start?
Arlo1
Postby oldswamm » Mon Aug 22, 2011 2:52 pm
Arlo, I just discovered this thread.
You should look at the dsPIC30F4011. I don't THINK you lose anything. The extra memory might find a use, it usually does.
The CAN interface is easy to implement, and might be useful for an automotive ap?
The Runner will get 4wd, right?
I love it. I too am jealous.
Bob
oldswamm
Postby Arlo1 » Mon Aug 22, 2011 3:04 pm
oldswamm wrote:Arlo, I just discovered this thread.
Bob
I already ordered 2 dspic30F3010-301/SO and have the 2 pic18f2431 chips in my box. The Road Runner will burn something as long as I can hold out. The SRT4 is gettng hybrid assist electric rear wheels asap. For now this controller is to run collossus in my e-ysr and I want insane power!
Arlo1
Postby oldswamm » Mon Aug 22, 2011 3:40 pm
Arlo1 wrote:I already ordered 2 dspic30F3010-301/SO and have the 2 pic18f2431 chips in my box.
I know, I read the whole thread. I'm thinking down the road. The CAN would only require 1 8 lead IC added to the board
Actually I was going to suggest something similar to that for the Road Runner. It NEEDS front wheel assist, doesn't it? :twisted:
I knew that to. :)
oldswamm
Postby Arlo1 » Mon Aug 22, 2011 3:48 pm
oldswamm wrote:]
I knew that to. :)
The road runner is light in the front and getting lighter and will wheely when Im done! So like a drag bike NO front wheel assist=bad idea! I plan to make it burn hydrogen but the electric revalution comes first!
Arlo1
Postby Arlo1 » Mon Aug 22, 2011 3:56 pm
So im looking at the power supplies. The usb chargers will proly be ok unless somone points one better out. I am not sure what to use for the fet driver supply. I ordered these http://www.ebay.co.uk/itm/160460011494? ... 1439.l2649 and now Im looking at this DCP021212 http://www.datasheetcatalog.org/datashe ... 021212.pdf which might be better because its smaller and made by someone trust worthy!
As for the fet driver supply I want it iscolated and 12 volts with how much amprage? Where will I supply it from if I feed 5 volts to the brain? It would be nice to find a 110-240 volt ac/12vdc adapter isolated to feed all three fet stages!
Arlo1
Postby oldswamm » Mon Aug 22, 2011 4:26 pm
Either that part for dc-dc, or nme1212dc to isolate the high sides, but I still think a good 100-240v 12v supply could work for a cheap dc supply. The 5v regulator can run off this supply with no noticeable efficiency hit.
You might even consider a 40/44 pin PIC. The extra pins can be used for single drop (or multi) 1wire sensors or analogue temp sensors, or whatever you think of later. Like memory, you can find a use for more pins. (And make sure you leave a kluge area to make additions to the prototype easier.)
oldswamm
Postby bigmoose » Mon Aug 22, 2011 4:43 pm
I've used Recom RO-xx12S (4 bucks and change from Future Electronics) before in small/medium applications. They are a little under 100 mA output; but remember the peak driver output comes from the capacitor. You need to do the math on the coulombs dumped from your chosen FET(s) and your PWM rate to get the average current draw. A 5v supply of around 0.5 amps likely will be more than enough.
bigmoose
Postby oldswamm » Mon Aug 22, 2011 5:46 pm
Regarding the over current discussion. This is a redundant limit, for an uncommon event, right? You aren't going to run against this limit are you?
Couldn't you use comparators to trip transistors (crowbars) across all 6 gates, plus an interrupt input to the processor, so it could take action. <edit> Forgot you were using drivers with an enable. That's simpler if they will 'disable' quickly enough.<endedit>
This circuit especially should be kept simple. I don't use KISS. I avoid doing anything because it's what stupid people do. I figure that second S probably keeps 'it' from working! :) I prefer 'Keep it as simple as possible'.
Bob
Oh, the RO part is pin compatible with the nme part I listed, I just couldn't remember 'ro'.
<edit>I was thinking that a separate comparator would be connected to the fault input for 'normal' current limiting. It could be set up with enough delay to keep the pwm off till the interrupt routine could take action.
oldswamm
Postby oldswamm » Mon Aug 22, 2011 9:19 pm
That last post confused me. :)
2 comparators, could be on the same shunt, bit more complicated with 2 shunts instead of 3.
<edit>3 shunts? One, optimized for speed, for HW shutdown, the other two optimized for accuracy, for phase current.<endedit>
One comparator would drive the enable pins on the drivers, to off.
The other would be connected to the fault input on the PIC, and would be set to a lower current than the first.
Normally the first wouldn't trip because the fault input would take care of it, and the program would probably temporarily reduce the pulse width so it didn't happen again?
If the first trips, it would probably indicate a 'fault' of some sort, and, if there's an appropriate input, the processor would act accordingly. The fault input keeps the PWM off for the rest of the cycle, so the program would have time without resorting to RC delays like I implied in the last post.
The big question is 'how fast is the enable pin based shutdown compared to the fault input on the processor'. I find no delay specs for the fault input on the dsPIC30F4012. OK, I did find it in the 3011 pdf, 50ns.
I think maybe I'm still confused. :) Is redundant fault protection needed, or is the driver delay the problem, or just in case of processor or firmware faults.
oldswamm
Postby Arlo1 » Tue Aug 23, 2011 12:07 am
LOOK what came in today! Man im going to need a lot of chocolate to do all this thinking... luke??? Help?
(71.14 KiB) Downloaded 93 times
Arlo1
Postby Lebowski » Tue Aug 23, 2011 2:02 am
cool stuff 8) let us know how you get on with the included course, I'm very curious as to how good and elaborate it is.
Lebowski
Postby Njay » Tue Aug 23, 2011 4:33 am
It's a piece of cake Arlo, you'll see :)
Njay
Postby oldswamm » Tue Aug 23, 2011 12:13 pm
Njay wrote:It's a piece of cake Arlo, you'll see :)
Does this refer to the software, or getting it into the PIC? :D
<edit rather than make a new post>
Just wanted to mention to those who don't realize it, the ADCs on the PICs Arlo intends to use can do 2 simultaneous conversions at 500khz. Up to 4 @ 250khz. (Actually samples, the conversions are at 1mhz.)
oldswamm
Postby Lebowski » Wed Aug 24, 2011 1:17 am
Well, :oops: , in a 16F88 I run a control loop to control the current through a motor (so a current
based throttle control). This comprises a 1st order integrator implemented with 16 bit fixed point
math (including fixed point multiplications and in addition to this, for speed, an eeprom table),
this runs at 4 kHz sample freq. On top of this (via interrupts) it runs a noise shaper at 10 kHz sample frequency.
Definately not a piece of cake :D but lots of fun (and definately a case of: you can make stuff
as complicated as you want)
Lebowski
Postby Njay » Wed Aug 24, 2011 4:33 am
I was referring to learning to develop software :)
Lebowski, try an AVR, you'll like the 4x+ speed increase over the PIC ;)
Njay
Postby Lebowski » Wed Aug 24, 2011 5:56 am
Njay wrote:I was referring to learning to develop software :)
With the AVR I really dislike their datasheets, impossible to read while those of PIC
are very clear. Plus I didn't find any programmer on their site, same for good
assembler design environment...
Plus Microchip gives you free PIC's if you ask nicely, haven't found this option
on the AVR site...
By the way, with the 30F2011 and a standard motor stage (using only 2 out of 3 motor wires)
you can build a wickedly powerfull (kilowatt) audio amplifier :shock:
Lebowski
Postby bigmoose » Wed Aug 24, 2011 7:07 am
Njay, I would recommend a "system comparison." For a complex PWM controller we are looking for a combination of system features. First a PWM section optimized for 3 phase control. Deadtime inputs, period centering, etc.; then we need a good, fast AtoD, then some decent DSP features in single cycles for the PID loops, followed by user interfaces like free input pins RS232, USB, CAN features. Take the device I recommended and do a relevant feature comparison to your AVR's (which honestly I am not experienced with as one head can only hold so much manufacturer data... :| ) I am open to new an better devices!
bigmoose
Postby Njay » Wed Aug 24, 2011 8:14 am
BigM, my "AVR try" suggestion was only a comment on Lebowski's PIC16F88 project. I could rebate all of your points except the free samples Lebowski (which is the only advantage 8bit PICs have over 8bit AVRs, not considering some special peripheral a certain PIC model might have better over AVRs), but I suspect that would leads to kind of an avr vs pic argument :)
Nevertheless I guess this project already has a platform picked up, Arlo already invested in one. In the end I guess there won't be relevant BLDC control hw differences in comparable platforms.
Njay
PreviousNext
Return to Motor Technology
cron
