NeilP wrote:Charging with the balance leads sounds like a painfully slow way to charge...what sort of charge current can you get...an amp or two at the most ...just not viable on a 20 Ah LiPo pack
amberwolf wrote:About the only thing I can see that it doesn't do besides make my teais make sure the BMS on a battery is disconnected, so taht the BMS doesnt' drain any cells in the pack it's attached to.
Not much you can do about that, unless you make a board with a FET for each cell's balance lead as well as main lead(s), and stick it in between BMS and battery, or remove the BMS and use only this (which I presume is the intent).
kfong wrote:I don't really have any high power setups.
wojtek wrote:kfong wrote:I don't really have any high power setups.
I would think this switch makes most sense for high power setups. That is where you get BIG spark and where extra safety features are wanted!
Personally i would be interested to get one for my high power 100v setup.
docnjoj wrote:Hey Kenny
Could I use this switch for my 36 volt Konion setup with 6P Fatpacks? I think it is genius and I want one. I would prefer that you built it since my eyes are getting bad!
otherDoc
Alan B wrote:Nice project. I've been thinking about making a similar unit myself with a keyswitch.
A question. It looks like you may be using a latching relay. It is my understanding that physical shock can cause a latching relay to switch. Is that a potential problem here? Hitting a pothole on a bike might turn the power on or off if the board was mounted firmly to the frame in any way?
kfong wrote:I trail ride, it has not been a problem, and I've mounted it directly to the frame, which had only front shocks and have been put in scooters with no suspension. If it can take the abuse I put it through I'm sure you won't make it fail. These have low mass and I suspect spring leaf tensioned. They are not the big relays you might be thinking of. The smart switch has been working for over a year on my cyclone build. I just needed more for other projects. Lots of uses for this switch. Just recently picked up a dc/dc supply Ypedal, pointed out. Will be hooking it up to my car battery and Hyperion charger to charge my spare pack while I trail ride, but I don't want to over discharge the car battery in case it's low. Smart switch to the rescue, same with my RC stuff.![]()
K-ray wrote:I too am intrigued by this simple solution cuz I liike to play with different cell counts![]()
So what would you recommend for cut-off (voltage per cell) for both Lipo and LiFePo4 to keep in the "safe" range?
And nice work
o00scorpion00o wrote:Hi kfong,
So basically this is like controller lvc, it will switch off or throttle the power based on pack voltage rather than individual cell voltage ?
Can the throttle on off switch be used to switch power on and off to the controller ? that would be very useful.
Motor temp monitoring would be very very continent, when the new chips become available would we be able to just replace the old one for the new features ?
Also, would you be able to install them in some kind of enclosure ? it would be handy for protecting it when throwing it in a battery bag!
Mark
