That's the photo I was looking for, thanks a heap Zenid. And thanks for shipping the controller out auraslip, looking forward to giving it a go.
Some help in working this LVC calculation or the formula involved would be appreciatedauraslip wrote:So I ended up installing a 2.2k resistor rather than the SMD resistors. Some napkin math calculation says it should hit LVC near 37v (or 2.3v per cell for 16s).
auraslip wrote:Anyways, rather than just fixing the LVC with a resistor, I installed a 5k pot inside the controller and set it to run 72v. This way you can adjust the LVC with ease if need be. I finally shipped today btw.
auraslip wrote:extra smd slot just gives them more options. this board could probably be used with voltages from 24v-100v depending on the build.
Good to know that the fets are only rated at 75v. I honestly don't know why these controllers are so popular. For the amount of work you have to put into them, and for the quality of them.... better to just spend twice as much and get a programmable controller.
I need to look into importing some generic infenions.
wesnewell wrote:The fets in the Hua Tong 72V 1500W controller are not 75V, but 100V fets. Zenids meltdown link showing the controller is not even a Hua Tong 72V 1500W controller.
The LiFePO4 bank also spends for more of its discharge at above nominal voltage, so I was seldom going below 80V, and running the bike typically at 81-84V. The fact that it survived two weeks running at about 115% of its rated value – continuing to work even after it began melting – is a testament to how rugged these units are…
You people are really screwed up. The fets in the Hua Tong 72V 1500W controller are not 75V, but 100V fets.
Even an SLA 72V battery pack has more than 75V output. Closer to 81V.
wesnewell wrote:You people are really screwed up. The fets in the Hua Tong 72V 1500W controller are not 75V, but 100V fets. Zenids meltdown link showing the controller is not even a Hua Tong 72V 1500W controller. The Hua Tong 72V 1500W controller does not use P75NF75 75V fets. If it did, I would have smoked them the first time I used a 100V pack. It uses 100V fets, 15 of them.
wesnewell wrote:I'm not doubting your fets, but that it isn't the Hua Tong 72V 1500W controller we are talking about. It doesn't even look close to it. The controller you show has 2 groups of wires coming out of the end, and the Hua Tong 72V 1500W controller we are discussing only has a single outlet.
wesnewell wrote:But if all the controllers you got were marked as 72V controllers with 75V mosfets then you should submit a complaint against whomever you bought them {...}
Zenid wrote:wesnewell wrote:But if all the controllers you got were marked as 72V controllers with 75V mosfets then you should submit a complaint against whomever you bought them {...}
What's to complain about? The controllers work, that's all that matters. What do you expect for $35-a-pop wholesale? I've had haircuts more expensive than that. If one breaks, I'll just chuck it in the bin and get another out the box.
If you don't want one then don't buy one.
wesnewell wrote:Hua Tong makes lots of different controllers. They make 48V, 60V, 72V, and probably other voltages. One person said they had a 48V version that had 63V caps. I don't recall if he mentioned the mosfets on it. But if all the controllers you got were marked as 72V controllers with 75V mosfets then you should submit a complaint against whomever you bought them from since they can't be rated as 72V controllers with 75V fets.
wesnewell wrote:Just curious what voltage you are running them at, I run mine at 100V. Give that a shot for a while and let me know how it works out for you.
Zenid wrote:As for trying to run it at 100V - why would I do a silly thing like that?.
bobale wrote:Well, why not? I like pushing thing to their limits (sometimes beyond), especially if they are cheap and/or easily repairable. Caps and FETs in ours HuaTong controllers are rated for 100V, so 100V would be pushing it really hard, but 90V would live you with a nice margin.
wesnewell wrote:That's what I'm talking about. A 72V controller shouldn't get that hot at only 84V. Mine runs cool as a cucumber on 100V. And for The Mighty volt, 4410 fets are rated for 100V not 75V.
Zenid wrote:A "72V" controller gets that hot at 84V because - as I ascertained from experiment - it is only suitable to be run at under 80V (at least this one from this batch).
Users browsing this forum: MattyCiii and 21 guests
