Rassy wrote:Thanks for the pics in "short" mode. Nice conversion job, looks pretty slick.
How do you like riding it in "short" mode compared to when it was in "long" mode?
How do you like the Over Seat Steering compared to the Under Seat Steering?
With the beefier tires does it still feel efficient pedaling up your hills?
How is your mid-drive treating ya?
Rassy wrote:Whether you use a hub motor, an RC motor, or something in between like he is doing, once you give the motor some gearing options via a mid-drive set up you can eliminate the lugging and over heating problems.
StudEbiker wrote:Rassy wrote:Whether you use a hub motor, an RC motor, or something in between like he is doing, once you give the motor some gearing options via a mid-drive set up you can eliminate the lugging and over heating problems.
I sure am looking forward to trying a mid-drive, but my machinist has had my motor mounting plates for almost a month now. Getting pretty itchy to get the Bike E on the road. You're build is looking great Li-ghtcycle! Looking forward to seeing this progress. Heck, you might have yours on the road before I get mine going.
Rassy wrote:How is your mid-drive treating ya?
It's been about 15 months since I set it up and I have no plans to make any changes at this time. It's not as fast as many bikes, but it will go the "legal" 20 MPH. And the 48V 10AH Ping seems to be holding up great.
I seldom pull over 15 amps, usually much less. When climbing hills in low gear it will maintain about 6 MPH and the amp draw is about equal to the grade %. I.e., if I am pulling 12 amps (low gear, full throttle) then I am on a 12% grade. The amount I add with light pedaling has little effect.
So my advice to anyone that has big hills and is having trouble keeping a hub motor cool while lugging it down and pulling high amps, watch this build that LI-ghtcycle is doing. Whether you use a hub motor, an RC motor, or something in between like he is doing, once you give the motor some gearing options via a mid-drive set up you can eliminate the lugging and over heating problems.
I really like how you just wrapped the chain around the outside of the cog to reverse the direction very elegant solution! Did you have to lock-tight the cog or is it kept on with just normal pedaling like that of a standard freewheel?
Rassy wrote:I really like how you just wrapped the chain around the outside of the cog to reverse the direction very elegant solution! Did you have to lock-tight the cog or is it kept on with just normal pedaling like that of a standard freewheel?
First, remember that the motor is flipped over, so when it runs it is spinning counter clockwise when looking at the cog side, and the cog is actually screwed onto the disk brake threads.
So the motor torque is trying to screw the cog on tighter. When pedaling without using the motor the cog would try to unscrew. But is doesn't, because I loc-tite'd a bottom bracket lock ring outside the cog. The motor, with peaks over 1000 Watts screws the cog on tighter than I could unscrew it with normal pedaling. In fact, I have a freewheel on my other 9C that I was using, and I can't get the freewheel off, even with a commercial removal tool I got from Sick Bike Parts. And there was no loc-tite used on it.
valsislav wrote:My Burley Canto with an old sensorless geared hubby.
sico wrote:Hi LI,
this is a cool looking project and well executed![]()
The stickers say 650W but the aspect and apearance of the motor mounts from this pic:
make it look more like the 800W. Do the dimensions of the motor you have agree with the dimensions for the 650W?
Just curious, maybe you got more watts for you buck after the Golden shipping mess up.![]()
Simon.
Sitting on the seat, it just barely bottoms out and touches the motor, not good!
Rassy wrote:Looking good LI. Hope that larger faster motor works out ok, sounds like a real pain to get the one you were after.Sitting on the seat, it just barely bottoms out and touches the motor, not good!
At least the motor can isn't spinning like my 9C does, which is mounted in about the same position.
Users browsing this forum: 3nslav3, Alastor, Bing [Bot], d8veh and 9 guests
