Manned electric "quadracopter" takes flight!
Things that fly
Postby gestalt » Tue Nov 01, 2011 6:39 pm
- be seeing you
gestalt
Re: Manned electric "quadracopter" takes flight!
Postby AussieJester » Tue Nov 01, 2011 6:56 pm
Damn! theres some $$$'s in motors alone there....
KiM
AussieJester
Postby E-racer » Tue Nov 01, 2011 10:15 pm
AussieJester wrote:Damn! theres some $$$'s in motors alone there....
KiM
Yea I would have no problem trusting a couple Turnigy's to do the same thing.
Kona Stinky: custom swing arm w/ batteries
-13s3p Turnigy Li-po
-Turnigy 80-100 rewound 130kv (Burtie's optical board)
-Kelly KBL 48201
-Nuvinci Dev Kit
http://endless-sphere.com/forums/viewtopic.php?f=28&t=35341
Goped ESR750
-12s2p Turnigy Li-po
-Turnigy 80-100 HXT w/halls
-Kelly KBL 48201
http://endless-sphere.com/forums/viewtopic.php?f=35&t=20732
E-racer
Postby liveforphysics » Tue Nov 01, 2011 10:23 pm
Compared with the cost of any other electric helicopter prototype, which start in the millions, buying 16 hobby motors and controllers is nothing.
Bargain price for your own electric helicopter. I bet the whole rig is under $25k.
liveforphysics
Postby oatnet » Tue Nov 01, 2011 10:23 pm
Wow, that is stunning! 16 props? I love the redundancy, and Welcome to the age of the flying car! I'd want a grab bar between me and those props though, hate to have the craft tip forward and get sushi'd on the props.
Love the exercise-ball landing gear too.
-JD
Member 117 of 16,xxx
179v VW Camper © 164v Vectrix E-Moto © 72v Norco A-line/x5403 © 60v Specialized Enduro Comp/BMC © 72v x5tracycle © 48v TF IO/BMC © 36v Kepler Friction Drive © Spot-Welding a123 © Pelican Front Packs © Vectrix Battery Replacement © MORE !!
Image大鸡巴 Motors
oatnet
Postby whatever » Tue Nov 01, 2011 10:33 pm
it would be interesting to find out what motors and propellers they are using, also what voltage and amps,
I wonder what is total power they need to get off the ground,
they look very much like rcplane motors/propellers, a few pics of motors at bottom of this page
http://www.e-volo.com/Prototype.html
whatever
Postby mauimart » Tue Nov 01, 2011 10:47 pm
Does anyone recognize the manufacturer and/or have specs on the motors/props? Which Turnigy motor do you think would be equivalent? I'm trying to get an idea of how much thrust each motor/prop can provide. My guess is that the copter with pilot is under 400lbs. That makes 30lbs per motor to get the thing off the ground. I think with the right controller I can get 50lbs of thrust from my Turnigy 80-100 spinning a 30 inch prop. With 8 to 12 80-100's I could be in business. I may have to stop all work on my e-bikes and begin work on one of these. I must have one...
mauimart
Postby kfong » Tue Nov 01, 2011 11:08 pm
Too funny, been wondering when someone would put together a muti-copter setup big enough to carry more than cameras. Surprised they didn't use just the open source adruino drone software instead of starting from scratch. I would of designed it so the person sits below all that spinning mass. It would also make it easier to fly since the CG would not be top heavy. A bunch of the big can Turnigys would do it. I bet 6 is all you would need. I'm more interested in paramotors though, only 2 Turnigys needed.
kfong
Postby mauimart » Tue Nov 01, 2011 11:22 pm
After some investigation my guess is the motor is a Hacker Q80-8M or Q80-7M. Bigger than I thought.
mauimart
Postby E-racer » Wed Nov 02, 2011 2:28 am
I bet that thing has some serious power @ wide open throttle. I wounder what the max climb rate will be... I'm so jealous some one built one of these. Here is more info: http://www.suasnews.com/2011/11/9691/german-multicopter-makes-first-manned-flight/
-Kelly KBL 48201
-Nuvinci Dev Kit
Goped ESR750
-Kelly KBL 48201
E-racer
Postby AussieJester » Wed Nov 02, 2011 3:05 am
liveforphysics wrote:Compared with the cost of any other electric helicopter prototype, which start in the millions, buying 16 hobby motors and controllers is nothing.
Too true Luke...any idea what motors they are using? They look
alot like the Plettenberg's Predator series motor to me? Chances are they may have
had them specially made you thinkz?
KiM
AussieJester
Postby E-racer » Wed Nov 02, 2011 12:44 pm
AussieJester wrote:any idea what motors they are using? They look
KiM
They are definitely Hackers http://www.aero-model.com/Hacker-Brushless-Q80-8M.aspx I'm not 100% on the model but the make is for sure Hacker.
-Kelly KBL 48201
-Nuvinci Dev Kit
Goped ESR750
-Kelly KBL 48201
E-racer
Postby Samd » Wed Nov 02, 2011 4:38 pm
The nice thing is that all the parts are accessible (cash pending of course). Aluminium from the hardware store, fitball from the mall, and parts from hobbystores. This is accessible to tinkerers amongst us.
Modded Aprilia Enjoy 'Race' & Enjoy 'City -10Y/o brushed Crankdrives.
Globe single spd aluminium with Q100 & 10s bottlebattery.
Dual 1900W BPM/Ezee gear hub for offroad.
900W Ezee Bakfiets / Cargotrike.
"Take the risk of thinking for yourself, much more happiness, truth, beauty, and wisdom will come to you that way." - Hitch.
Samd
Postby strantor » Fri Nov 04, 2011 6:51 pm
http://www.eaa.org/news/2011/2011-11-02_evolo.asp
The custom, German-made electric motors produce 2 kilowatts each
That's pretty cool. I would fly it, but I would be worried about one of those props coming apart and taking out my kneecaps and/or groin.
strantor
Postby whatever » Fri Nov 04, 2011 8:45 pm
from the eaa link:
16 motors at 2kw each = total power 32kw
can still fly if two motors fail: so 28kw to keep it in the air
can land if 4 motors fail: so 24kw probably around minimum power needed
batteries weight: 25kg
whatever
Postby bobc » Mon Dec 12, 2011 3:40 pm
I'm looking at that thing and thinking "crane" or skyhook - is there a case for using this in the construction industry? it can clearly lift 100kg & costs a fraction of a helicopter to build & fly - I bet the running costs are comparable to a lightweight crane.....
It wouldn't take a lot of software to give it proper 3d (or 4d - rotation too) position control -
bobc
Postby Jay64 » Tue Dec 27, 2011 11:15 am
kfong wrote:Too funny, been wondering when someone would put together a muti-copter setup big enough to carry more than cameras. Surprised they didn't use just the open source adruino drone software instead of starting from scratch. I would of designed it so the person sits below all that spinning mass. It would also make it easier to fly since the CG would not be top heavy.
I was thinking along the same lines when I was watching the video, but reading the website, they did have a design goal for doing it this way.
In difference to other helicopters or multi-rotors, e-volo can use a safety parachute, as there are no propellers blocking the deployment area above.
Also, I was thinking you would have to have a cage around you to protect you from having the whole thing come crashing down on you in case of an emergency, which would add more weight. But I guess if I was going to be a safety pansy about it, I would probably want a cage around me even if I was sitting on top. :lol: Maybe at least a roll cage? 8)
I don't know that much about the physics of props, but would there be a difference in effectiveness if the props were pushing up from under the support beams rather than pulling up from on top of the beams? That might give a little more distance, different plane, between the operator and the props.
Johnson64.Com "The stone age didn't end because we ran out of stones."
EV Bikes:
'13 Zero S 11.4kwh.
GS500, ME0913, Sevcon Size 6 Controller, 90v40ah Lipo, GSXR suspension..
'87 Hurricane 600, ME0709, 48v/50a SLA, Kelly KD72400, Magura Throttle, High Current Cycle Analyst.
http://www.evalbum.com/2275
Raleigh beach cruiser: 9C rear hub, stock controller, 48v10ah lithium, Cycle Analyst.
Phat Chopper: 9C front hub, stock controller, 48v12ah a123s, Cycle Analyst.
Jay64
1 GW
1 GW
Postby fechter » Tue Dec 27, 2011 11:33 am
That's pretty cool. I can imagine using some gyro chips to stabilize the flight like most RC helicopters. Not sure I would trust a RC transmitter for control, but I guess it works.
I wonder what the flight time would be?
fechter
Postby Jay64 » Tue Dec 27, 2011 11:45 am
10-30 min depending on payload. But I guess they could alter that with putting some more lipo on there as well.
EV Bikes:
'13 Zero S 11.4kwh.
Jay64
1 GW
1 GW
Postby Ludo91 » Fri Dec 30, 2011 10:36 am
Really awesome! Tho I`d never like to be on the same plane as 16 spinning props :mrgreen: Only reason I can see for them being below me is the ability of using a parachute in case of emergency at a decent height :D
I wonder too why don`t they use Ardupilot! It reached an INCREDIBLE level of developement
Open source high power BLDC controller! ===> http://code.google.com/p/dc-brushless-open-source-controller/
Ludo91
Postby Jay64 » Fri Dec 30, 2011 10:46 am
Has anyone done any work with this drone type software?
EV Bikes:
'13 Zero S 11.4kwh.
Jay64
1 GW
1 GW
Postby bzhwindtalker » Wed Jan 04, 2012 3:35 pm
I built a tricopter with a hobbyking 24$ board and some motors and controllers. I'm now working on a quad with more lifting power and a fpv set-up :)
I had hard times making that tri fly well, because motors were held with zip ties and taht the angles were changing wile in fligth ;) I made another one using an old t-rex 450 frame that flew way better! Now manned fligth is another leage for sure, but those are super fun to fly!
Awesome vid if you did not see it yet, thta's what its all about
now lets wait until someone does that with a full sise quad haha :)
bzhwindtalker
Postby kiqnkf » Fri Jan 13, 2012 12:57 am
HAHAHAHA!!!
Looks like a quick way to deliver clean dried washing in a spectacular fashion!!! I love the exercise ball cobbled to the clothesline with occy straps!!!!
Dont fly over my back yard, my kids will be swinging straight off that, probably ending up with grass-stains on all that clean laundry!!!!
On a positive note, I was just perusing this looking to see how much power I would need to build myself a counter-rotating me-moving stand-in copter!!!
Looks like an option!!!!
Royce Union D/S Mountain Bike, 500w Chituma front wheel kit
Stealth Bomber, custom electric kit....
NHW10 Prius - Ask, I may be able to help!!!
kiqnkf
Postby Dauntless » Wed Mar 21, 2012 1:25 am
There are helicopter builds that qualify as an Ultralight, no license required if you keep it in out of the way places, and people put them together for well under $10k. That's a single gas engine of simple design that serves multiple purposes, not sure they're truly suitable for helicopter duty. 16 motors? So if several suddenly blow out you have 10 or more easing you back to the ground? I think I might actually feel safer in that prototype.
A helicopter is not an aircraft, it's 2,000 moving parts flying in formation.
Any sufficiently advanced technology is INDISTINGUSHABLE FROM MAGIC!
- Arthur C. Clarke
Dauntless
Postby slawek » Fri Mar 08, 2013 8:27 pm
This looks like interesting concept. If I am not mistaken this is next take by the same folks from Germany.
I like this one much better, looks safer and more stable.
http://www.dvice.com/archives/2012/06/sixteen-rotor-p.php
slawek
Return to Electric Aircraft
Users browsing this forum: No registered users and 0 guests
