Moped Build
Moped Build
Postby TylerTrinh » Sun Dec 04, 2011 3:19 pm
Concept Futuristic Build
10" wheels the fold into a rectangular frame
So far I have 64 cells of Headway LiFePO4 38120P (M size) Cell: 3.2V 10 Ah, 100A Surge Rate, 32Wh with 6M screw Terminal. Squeezing around 64-100 headway cells) I arrangement of battery setup is unknown because the motor is unkown.
And i'm trying to get rid of the 5304 Crystalyte and controller 40amp and come up with a Direct Drive to 10" wheels. (Racing go-kart style)
No compromise in the size of the 10" wheel as design meets engineering again in a classic battle.
I'm looking at: Astro 3215 $540 http://www.astroflight.com/index.php?main_page=product_info&cPath=9&products_id=209
Astro 3220 $695 http://www.astroflight.com/index.php?main_page=advanced_search_result&search_in_description=1&keyword=3220
PMAC Brushless Motor $450 http://www.electricmotorsport.com/store/ems_ev_parts_motors_pmac.php
So much stuff out there that i find my myself drifting off topic and the sea of endless-sphere knowledge that there were the only motors i came up with.
Maximizing Efficiency, Power/Torque, and range(50miles) up speeds up to 45mph. Not to get too granular, but there many variables that determine speed mainly weight, incline, and wind resistance. I want to over engineer to meets the demands of fast acceleration, top speed, and when throttled sparingly or within city limits of 35mph to get the range desired.
I need an expert 2nd opinion on what motor and controller to buy, battery setup, and gearing ration.
TylerTrinh
Re: Super Futuristic Moped Build
Postby sk8norcal » Sun Dec 04, 2011 11:14 pm
do you have a sketch of how it's gonna fold ?
diblasi have a folding 10"er
sk8norcal
Postby TylerTrinh » Mon Dec 05, 2011 1:33 am
American Chopper Senior vs Junior the difference between the two is that senior uses a designer and like what he see on paper first and junior is also a visual designer but uses actual parts like a sculpture to pin down the final design. I'm kinda like junior. I tried putting things on paper and in actuality never turns out right. To me the concept can be better realize with parts at hand. I just started welding 8 months ago and i weld beads like the real deal.
As for that R70 just imagine 5-7 years into the future of what that R70 should look like.
TylerTrinh
Postby sk8norcal » Mon Dec 05, 2011 3:48 am
cool, cant wait to see the final product...
seen the honda motor compo concept?
the original one folds... sort of..
sk8norcal
Postby Hillhater » Tue Dec 06, 2011 9:56 pm
TylerTrinh wrote:Concept Futuristic Build
.... with a Direct Drive to 10" wheels. (Racing go-kart style)
No compromise in the size of the 10" wheel as design meets engineering again in a classic battle. .
Just to clarify..
By 10" wheels, ..you mean 10" OD of the tire ? . The "wheel" rim itself on a go -kart is 5" diameter.
.but you could have a larger rim with a smaller section tire, still with a 10" OD....is that an option ?
And by "Direct Drive" you are thinking of a motor coupled to the wheel via chain and sprockets ?
( Direct Drive in Ebike terms usually means a motor in the wheel hub :wink: )
Hillhater
1.21 GW
1.21 GW
Postby TylerTrinh » Tue Dec 06, 2011 11:19 pm
yes sir....10" OD on the tires and sprockets via chain or belt. I like the Motenergy ME0909 http://www.thunderstruck-ev.com/index.php?dispatch=products.view&product_id=4 and I think I'll just stay away from Astro. Motenergy uses expensive controller like Alltrax $350-$400 but may be better for wide range tuning. Generally speaking the smaller 10" wheel should get better torque and I need to find the appropriate gear ratio for sprockets.
TylerTrinh
Postby Hillhater » Wed Dec 07, 2011 12:59 am
TylerTrinh wrote:yes sir....10" OD on the tires and sprockets via chain or belt. I like the Motenergy ME0909 http://www.thunderstruck-ev.com/index.php?dispatch=products.view&product_id=4 and I think I'll just stay away from Astro. Motenergy uses expensive controller like Alltrax $350-$400 but may be better for wide range tuning. Generally speaking the smaller 10" wheel should get better torque and I need to find the appropriate gear ratio for sprockets.
There is a gear ratio calculator on the Thunderstruck site if you look.
It suggests a 2.5:1 ratio for 45 mph on a 10" wheel and 3800rpm motor speed.
Hillhater
1.21 GW
1.21 GW
Postby TylerTrinh » Wed Dec 07, 2011 1:13 am
cool i didn't know that....Thanks
The BMS from batteryspace has these configurations 36v 40amp, 48v 60amp, 72v 100amp. The Motenergy has 48v 100amps continuous. If i parallel 48v 60amp the 48v remains constant and the Ah doubles. Will the amp double as well because the controller is pulling 60amp from each pack that is connected in parallel? I'm aiming maybe 48v 30ah or 40ah(3 or 4 packs 16 cells each and each headway is 10ah @3.2)
TylerTrinh
Postby ioniscool » Tue Dec 20, 2011 11:23 pm
hey hillhater the unloaded is 3800rpm and load is 2500rpm would you use the 2500 for the gear calculation instead of 3800? what do you think about this motor on this setup?
ioniscool
Postby Jay64 » Tue Dec 27, 2011 7:28 am
ioniscool wrote:hey hillhater the unloaded is 3800rpm and load is 2500rpm would you use the 2500 for the gear calculation instead of 3800? what do you think about this motor on this setup?
http://www.thunderstruck-ev.com/gear-ratio-calculation/gear-ratio.html
Johnson64.Com "The stone age didn't end because we ran out of stones."
EV Bikes:
'13 Zero S 11.4kwh.
GS500, ME0913, Sevcon Size 6 Controller, 90v40ah Lipo, GSXR suspension..
'87 Hurricane 600, ME0709, 48v/50a SLA, Kelly KD72400, Magura Throttle, High Current Cycle Analyst.
http://www.evalbum.com/2275
Raleigh beach cruiser: 9C rear hub, stock controller, 48v10ah lithium, Cycle Analyst.
Phat Chopper: 9C front hub, stock controller, 48v12ah a123s, Cycle Analyst.
Jay64
1 GW
1 GW
Return to E-Scooter and Motorcycle General Discussion
